Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Audio driver failure after installing new hard drive
Forum Laptops & Notebooks : General Laptops & Notebooks - Audio driver failure after installing new hard drive
Using a gateway mx6421 laptop, installed a 7200rpm hitachi hd to improve performance over the old 4200rpm from the factory. retinstalled windows xp media center, downloaded all drivers from gateway for the mx6421. the drive is much faster and everything works fine with the exception of the audio. the audio driver "fails" during installation. the conexant driver i am using is specific for this laptop model from gateway's website. if i swap out the new drive and use the old one with all the preinstalled software and drivers the sound works fine. but under no circumstances can i get the sound to work with the new drive. i contacted gateways tech support and they were of no help. does anyone have any idea what is wrong? any help would be very much appreciated. thanks.
Sponsored Links
First, try going to the Windows update site and it MAY have a driver update for you.
If Not...
Was your last OS Media Center? If so...
Right Click MY COMPUTER and choose PROPERTIES
This will open the system properties window.
Click the HARDWARE tab
Next choose DEVICE MANAGER
Under SOUND VIDEO AND GAME CONTROLLERS
find your audio drivers and RIGHT CLICk, choose the DRIVER tab
Next click DRIVER DETAILS this will tell you where the existing (working) driver resides)
Go get the file tiger and drop it into your new drive.
Case closed.
http://www.killernotebooks.com/images/logos/forum_grey.jpg
Reply to killernotebooks
- 0 +
KillerNotebooks,
Like mp33, I have a Gateway MX6421 Laptop that came with Windows Media Center. Mine also fails to load the audio driver. I tried to view the driver details, but get the message "No driver files are required or have not been loaded for this device." Case still open.
Spanky
Reply to Spanky
- 0 +
KillerNotebooks,
Thanks for the link, but the problem is the driver doesn't work when you install it. I've discovered the problem is the driver needs to be installed manually. I opened the driver installation wizard and then did the have disk option and pointed to the driver. The driver installed manually and now I have sound. mp33, let me know if this works for you too.
Spanky
Reply to Spanky
Spanky... do you think you can elaborate on how exactly you did this.
I reformated the hard drive and installed all the drivers, but the audio one failed. Two tech support calls were both unsuccessful. I have the Gateway MX6421 too.
Reply to carreragt
Downlaod the driver from the link I posted above.
Unzip the contents to a folder on your hard drive I will call for the sake of instruction C:\Audio Driver
Choose Properties
Click HARDWARE tab
Click DEVICE MANAGER tab
Choose Sound, video and game controllers
Right click the device in question
Choose Update Driver
The wizard will ask you, "Can windows connect to Windows Update to search for software?"
Click No
Click Next
It will ask "What do you want the wizard to do?"
Click "Install from a list or specific location"
Click "Next"
Click the check box "Include this location in the search"
Click browse and browse to the location of the driver (in this explanation it was C:\Audio Driver".
Complete the wizard and you have manually installed the driver.
hello Killer.
Ok to get fixed you have to do following those steps.
Fist in my computer, right click and go properties, hardware, device managment, and look where is your uninstall deviced, with yellow warring ?. Right click on it and go to, NO, not this time.
And go next. and than go Install from a list specification location.
Next go to Don't search. I will choose the drivers to install.
Next go and look for you audio deviced and after that you will get another windows screen and show you Manufacturer and chose Conecant and you will see for the model next to it, on the model box. BUT YOU NEED YOUR DRIVERS TO BE IN YOUR HDD, AND CLICK NEXT AND YOU WILL SEE ONE WINDOWS AND WILL ASK YOU ABOUT cm6 something like that and than go to directory and find that file and clik open next if you have any pup up windows click yes and you will have sound card installed just wait untill finished.
thx Selim/Kosovo
seli_gl@yahoo.com
Reply to bigmiles
Ok, here's how I got the sound to work on the MX6421 with XP Media Center. Download the driver and extract it to the Cabs folder (it'll do this automatically). Run the Setup.exe which is in c:\cabs\D00377-002-001 folder. This will not get the sound to work but will get windows to at least see the driver later down. Here is the link to the driver...
http://support.gateway.com/support [...] =177779200
Go to Device Manager (see above posts on how to get there), click on the "multimedia audio controller", click "reinstall driver", click "no, not this time" on the wizard that comes up, check the "install from a list..." and click Next. Click "don't search..." and click Next. Scroll down to "Sound, Video, and Game controllers" and double click on it. Click on Conexant in the left pane and click on "conexant ac-link audio" in the right panel and click Next. You'll get a message saying "installing this driver is not recommended...", click Yes. It may ask to locate a file, if so browse to the c:\cabs folder referenced above. And that's it, sound should now work.
Reply to positronic
Thank you so much guys.. finally I got it! The key is to install Conexant driver instead of the recommended Realtek.
Thanks a lot!
Reply to lyapunov
- 0 +
Wow.... This solution actually WORKED! I reinstalled XP Home on a Gateway MX6438 and was stuck on this problem. I looked everywhere for this solution. Thanks for saving the small amount of hair I have.
Reply to gnattiv
Whoa it worked. Thank you very much m8!!
Reply to shibbiness
i had to format my gateway mx6421 and went to gateway and no drivers are working or i am choosing the wrong ones can someone help me with this 1 by 1 with the drivers need help bad my email is
miller764@comcast.net
Reply to scttmill
this thread is still very relevant and the fix still works. thank you toms hardware community!!!
Reply to konan1223
Thanks for your help ..I couldn't have installed it without the help of your information!! Keep up the good work.
Reply to Anonymous
- 0 +
its so great to see so many answers when the question is realy easy..have a try at the rest?
Reply to pcfixed
Choose Properties
Click HARDWARE tab
Click No
Click Next
Click "Next"
Click browse and browse to the location of the driver (in this explaation it was C:\Audio Driver".
he got it he got it he got it this works PERFECTLY ALL OVER THE NET this works it works odythanks for everyb
Reply to Anonymous
There are 1278 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
