I have bought my 1st laptop, so how shoud I take care of my battery?
(_1) Always use battery+AC adapter (_2) Either battery or AC adapter (the battery is OUT)
(_3) When I deplete the battery plug in the AC adapter (_4) Something else (explain)
U can answer only with a number if you don't want to complicate your life
I'm asking this because a friend of mine told me that he used his laptop pluged in AC adapt. for a year and after that his battery lasted for only 3 min.
And my laptop dosn't have a battery cover, which means that when the battery is out I got a big gap in the back it.
I have an older laptop, im going to be getting a new AlienWare m9700 soon though.
The first initial usage, drain the battery completely. Then charge it up fully. Then it doesnt really matter what you do. I usually have it plugged in if Im in the house, couch, bed or whatever unless im lazy. If im outside or at a friends house I usually run it without A/C adaptor and then plug it back in when im in the house.
My manual on my LT said to do 3 complete cycles, after that doesn't matter. My LT is 19 mo old and still has 80 % of the original capacity. I use AC 99% of the time.
If it's Li-ion (Lithium Ion), they last longest the fuller the battery stays, so plug it in whenever you can (1)
If it's Ni-Cd (Nickel Cadmium), then buy a new laptop, because it must be over 10 years old. Even so, drain the battery as much as you can each time you use it before plugging it in (and make sure it charges fully each time) (3)
If it's Ni-MH (Nickel Metal Hydride), then either 1, 2, or 3, depending on how good the laptop battery circuitry is. Most damage to batteries comes from overcharging, so if your laptop doesn't cut off the trickle charge once the battery is full, i'd suggest 3, or even 2 (but that means that a power cut will kill your work.)
Also, some laptops won't let you run without the battery out and the AC in, i know my gf's dell 1150 won't. That's probably a sign that it doesn't cut off the trickle charge when the battery's full. So, ironically, if you can run your laptop without the battery, you don't have to.
