I have an RCA SPDIF audio output on my PC. So I made up a 12m cable of
75-ohm coax with RCA on one end and XLR on the other end (earth pin shorted
to neg pin) to hook it up to a Behringer DEQ2496. No signal registers on the
DEQ. If I use the same cable between my CD player and the DEQ, it works.
Any explanations please?
P.S. the PC to DEQ connection works with a 1m interconnect made from
balanced mic cable. So there is output at the PC's SPDIF, and the DEQ can
detect it.
12m cable of
(earth pin
> shorted to neg pin) to hook it up to a Behringer DEQ2496.
No signal
> registers on the DEQ. If I use the same cable between my
CD player
SPDIF involves a signal that is bipolar around ground, and
has a peak-to-peak amplitude of about 1 volt. Open-circuit,
you might see more like 2 volts peak-to-peak.
AES/EBU involves a TTL-compatible signal that is runs
between 0 volts and about 5 volts, again under load.
Put in a coupling capacitor and presume some overload
capacity on the part of the SP/DIF input and you can see how
an AES/EBU device can easily drive a SP/DIF input.
However, when you hook a SP/DIF *output* (no more than 2
volts, and no more than +1 volt peak) to a AES/EBU input
requiring a TTL-like input (3-5 volt swing above ground
required) and I think you can see the potential problem.
made from
and the DEQ
> can detect it.
I think you got lucky. Are there any differences between the
1M cable and the 12M cable other than length?
"Arny Krueger" <arnyk@hotpop.com> wrote in message
news:FLOdnYo9T774BDjfRVn-1w@comcast.com...
> made from
> and the DEQ
> > can detect it.
1M is balanced mic cable, 12M is 75-ohm coax. I saw on a newsgroup that
75-ohm is optimum for SPDIF.
> 12m cable of
> (earth pin
> No signal
> CD player
The DEQ is switchable between AES/EBU and S/PDIF. The problem persists on
either setting.
In article <42a59b2b$1_2@news.melbourne.pipenetworks.com> nowater@grantsellek.com writes:
This is correct, but 12M might be a little too long given the cable
loss (unavoidable) and lower output voltage of S/PDIF compared to
AES/EBu. Generally 10 meters is considered the upper limit, but that's
greatly dependent on the output level of the source and the input
sensitivity of the receiver.
Can you move the DEQ closer to the computer?
You might have better results by using a matching transformer at the
computer end and switching to 110 ohm AES/EBU cable, but a transformer
is a relatively expensive item, and there's no guarantee that it will
work in this instance.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
On Tue, 7 Jun 2005 22:55:35 +0930, "nowater" <nowater@grantsellek.com>
>either setting.
I think Mike has the right idea. For the distance you are working at,
the cable is not quite up to the task. SPDIF is just usually not
meant to run that far driven by most devices. You should be driving
your longer cable with AES/EBU and use the AES/EBU settings on your
input. While a matching transformer might do the trick or then again
maybe not, this $85 converter device by HOSA will definitely solve
your problem and you'll probably have a lot more reliable connection
in the future:
Julian wrote:
> ...While a matching transformer might do the trick or then again
> in the future:
> http://www.macmidimusic.com/prod.itml/icOid/1359 >
> If that's too much, I've seen web sites how you can do this for $20 in
> parts, but after I factor in my time, I'd rather just buy the
> converter.
On 7 Jun 2005 23:14:21 -0700, "nowater" <nowater@supernerd.com.au>
wrote:
>How about this matching transformer for $20?
>http://www.westlake-electronic.com/cgi-bin/store.php?search=yes&detail=yes&category=AUD&SUBCAT=CAN-&item_no=CAN-BCJ-XP-TRB
>Is that a solution?
That's exactly what Mike suggested. In his words: "...there's no
guarantee that it will work in this instance..."
Someone correct me if I'm wrong, but I believe the BNC connector on
this transformer while unbalanced is actually designed for a higher
voltage than the RCA SPDIF output jacks you have. Basically it is AES
unbalanced device and you have SPDIF unbalanced. It might possibly
work here especially because you had some success with plugging your
CD player directly in, but there is no guarantee and even if it does
work your voltage is going to be marginally low and the whole system
will possibly be prone to failures.
That's why I suggested the other box. It takes what you have, RCA
SPDIF, and changes it to what you need, XLR AES, which can be run 100
meters or more.
Where do you live? I go to the main branch of West lake Electronics
here in Seattle all the time.
On Tue, 07 Jun 2005 23:44:17 -0700, Julian
Duh! I just realized I overlooked something. The transformer you
linked to is designed for the opposite direction - adapting a device
with a balanced XLR OUT to a device with an unbalanced BNC IN. You
are going unbalanced RCA OUT to XLR IN.
Maybe if you bought two of them and a BNC cable and an XLR RCA
adaptor...and... you'd still have too low a voltage :-(
BTW they are saying this device allows you to run longer cables, but
they mean longer than AES XLR type 110 ohm cable which you can already
run much longer than you need. AES 110 ohm can run like up to maybe
100 m, but on the 75 ohm BNC type cable you can run maybe 300 m or
more. I don't remember the exact specs, but I do remember that is one
of the main usages for the 75 ohm cable, very long runs.
In article <444da15u3t9f9e5rduiqqnijv6mt0o4rpp@4ax.com> JulianPAdamsNo@SpamHotmail.Com writes:
I didn't bother to paste together the long link (people should use
tinyurl.com for this) but I think you're right, at least in principle.
These adapters are meant to convert between unbalanced 75 ohm AES-3
(S/PDIF but at AES/EBU voltage level) and balanced 110 ohm AES/EBU.
The voltage ratio of a transformer is the square root of the impedance
ratio, so it only steps up the voltage by about 1.2. That might be
enough if the present level is just marginal, but it might not.
