G
Guest
Guest
Archived from groups: microsoft.public.games.zone.simulation (More info?)
Does anyone here use (or know) if CFS3 and the nVidia Quadro4 980XGL can
work together?
I can use FS2004 in conjunction with the Quadro with no problems but CFS3
will not load.
AFAIK the Quadro is the workstation CAD/CAM version of the standard nVidia
NV28 ala GeForce4 Ti 4200 chipset so should be compatible.
Failing an answer to the above is there any other forums/websites that I can
check out this type of question?
Thanks & regards,
-pp-
work together?
will not load.
Thanks & regards,
-pp-
