I have a Sony TCD 7 portable DAT and when I try to fast forward tapes,
it often says the tape is blank, when I know it's not. This stops the
machine from fast forwarding.
Has anyone else experienced this problem, can anyone give me any
pointers or recommend a repair centre in the UK?
I have never cleaned the heads - could this be causing the problem?
<lubaloo@gmail.com> wrote in message
news:1118916063.788847.254740@g49g2000cwa.googlegroups.com...
> Hi -
> Thanks for your advice
> SM
With any DAT problem, cleaning the heads should be the first thing you do to
either eliminate the problem or to find out whether the problem is
elsewhere. You won't be able to easily get inside the machine to clean them
manually, but you could buy a DAT head cleaning tape which may well do it
for you.
I find it strange that owners of a reel to reel will clean their heads on a
regular basis, whereas DAT owners seem to think they can get away with never
cleaning them EVER!
> to either eliminate the problem or to find out whether the problem is
> them manually, but you could buy a DAT head cleaning tape which may well
> do it for you.
> a regular basis, whereas DAT owners seem to think they can get away with
> never cleaning them EVER!
> Cheers,
> Gareth.
Sorry, forgot to answer the question - yes, dirty heads could cause this
problem if the frequency response of the heads have been affected by dirt.
Various tracking and other data could disappear at the higher speeds (and
frequency) of fast forward and reverse.
This is one of MANY common problems with those machines. That one is
caused by the control head not contacting the tape properly. There
are a lot of things that can cause it.
These machines are mechanical nightmares. I don't know anyone in the
UK offhand, but I can say that several friends of mine have had terrible
experiences with Sony factory service in the US with them.
It wouldn't hurt, but it probably is a tape tensioning issue. Those
machines are no fun to work on.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
a guy on ebay has offered to repair for £40, but I'll try the head
cleaning 1st!
i want to sell the unit anyway, but want to make sure it's in tip top
condition for the buyer.
> > do it for you.
> > Cheers,
> > Gareth.
There isn't any control head as such. The track finding pulses and subcode
are written at the ends of the tracks, with the subcode data outside the
ATF pulses. If the tracking angle is slightly out, the subcode is first to
go. The disappearance of A-Time and missing start IDs etc is usually the
first a user notices.
If a cleaning tape doesn't solve the problem, then the machine probably
needs alignment.
Noel Bachelor noelbachelorAT(From:_domain)
Language Recordings Inc (Darwin Australia)
thanks Noel - do you know how I would go about doing this? I've tried
the head cleaning...
> needs alignment.
"sm" <sammenter@gmail.com> wrote in message
news:1119431570.057308.233510@z14g2000cwz.googlegroups.com...
Even if the alignment is out, the machine should play back tapes recorded
itself. Misalignment means it won't play back tapes from another machine
(or tapes made on your machine some time ago when the alignment was better)
Maybe, but those machines have such tiny head drums that you can find
all kinds of tape-to-head contact problems as well. And if the tape
isn't touching the head, it won't record or play properly.
You can't believe how much I hate those things.
--scott
>>better)
> --scott
Not as much as I hate them. I attempted a repair once and vowed never to go
anywhere near them again. Also the reduced head size means a greater angle
of tape wrap (and drag) and I seem to remember reading somewhere years ago
that this threw up all sorts of design issues and compromises. Basically
it's a rubbish idea.
hi gareth
it plays / records perfectly
even this problem is only sporadic
thanks for your advice
> >>better)
> > --scott
> Gareth.
That's the thing about digital systems. They work perfectly until they
fail completely. You can have really terrible eye pattern coming off
the heads and everything locks up and seems just fine... and then it
gets just a little bit worse and stops working altogether.
--scott
