Hello, I have a serious problem with an CD-rewriter LG GCE8520.
Each time i burn a cd comes this error.
Plz i need a solution.
Piñeiro
PISA
5508-0383-4006-5001-0128-6535
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 23/12/1997 2:23:24
ahead WinASPI: File 'F:\Archivos de programa\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 29/01/2003 22:37:36
Nero Version: 5.5.10.28
Recorder: <HL-DT-ST CD-RW GCE-8520B>Version: 1.04 - HA 1 TA 0 - 5.5.10.28
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <HL-DT-ST CD-RW GCE-8520B>Version: 1.04 - HA 1 TA 0 - 5.5.10.28
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 4D060H3 atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST34321A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : HL-DT-ST CD-RW GCE-8520B atapi Port 1 ID 0 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261600kB)
Free physical memory: 68MB (69652kB)
Memory in use : 73 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: Off
8.7.2003
CD-ROM (ISO)
20:11:07 #1 Text 0 File Isodoc.cpp, Line 7579
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO/96
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
20:11:08 #2 Phase 90 File dlgbrnst.cpp, Line 1655
Buffer Underrun Protection activated
20:11:08 #3 Text 0 File Reader.cpp, Line 115
Reader running
20:11:08 #4 Text 0 File Writer.cpp, Line 125
Writer HL-DT-ST CD-RW GCE-8520B running
20:11:08 #5 ISO9660GEN -11 File geniso.cpp, Line 4571
First writeable address = 0 (0x00000000)
20:11:08 #6 Text 0 File Burncd.cpp, Line 3735
Turn on UltraRaw 96-Mode, using CD-R/RW media
20:11:08 #7 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 354524 (354524) = #354524/78:46.74
relocatable, CD pos for caching/writing not required/required, no patch infos
20:11:08 #8 Text 0 File DlgWaitCD.cpp, Line 221
Last possible write address on media: 359846 (79:59.71)
Last address to be written: 354523 (78:48.73)
20:11:08 #9 Text 0 File DlgWaitCD.cpp, Line 226
Write in overburning mode: FALSE
20:11:08 #10 Text 0 File DlgWaitCD.cpp, Line 1678
Recorder: HL-DT-ST CD-RW GCE-8520B;
CDR code: 00 97 32 19; OSJ entry from: Prodisc Technology Inc.
ATIP Data:
Special Info [hex] 1: E0 00 B0, 2: 61 20 13 (LI 97:32.19), 3: 4F 3B 48 (LO 79:59.72)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
20:11:08 #11 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder HL-DT-ST CD-RW GCE-8520B for write in raw writing
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_ULTRARAW96_MODE1, 2448/0x4, ISRC "", FilePos 0 367200 868241952
20:11:08 #12 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (after recorder preparation)
-> TRM_ULTRARAW96_MODE1, 2448, config 0x4, wanted index0 0 blocks, length 354524 blocks [HL-DT-ST CD-RW GCE-8520B ]
20:11:08 #13 Phase 24 File dlgbrnst.cpp, Line 1655
Caching of files started
20:11:08 #14 Phase 25 File dlgbrnst.cpp, Line 1655
Caching of files completed
20:11:08 #15 Phase 36 File dlgbrnst.cpp, Line 1655
Burn process started at 48x (7.200 KB/s)
20:11:08 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1978
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
20:11:08 #17 Text 0 File Mmc.cpp, Line 13410
StartDAO : CD-Text - Off
20:11:08 #18 Text 0 File Mmc.cpp, Line 17895
Set BUFE: supported -> ON
20:14:38 #19 Text 0 File WriterStatus.cpp, Line 115
<HL-DT-ST CD-RW GCE-8520B > start writing Lead-Out at LBA 354524 (568DCh), lenght 6750 blocks
20:14:39 #20 SCSI -1135 File Cdrdrv.cpp, Line 1416
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x024F0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x05 0x6C 0xB8 0x00 0x00 0x1A 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
20:14:39 #21 MMC -1135 File Writer.cpp, Line 333
20:14:39 #22 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
20:14:41 #23 Phase 38 File dlgbrnst.cpp, Line 1655
Burn process failed at 48x (7.200 KB/s)
20:14:41 #24 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.57 (1008), size=23936 bytes, created 23/12/1997 3:02:46
File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 24/08/2001 12:00:00 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
