I'm looking for a vocals mic (only for vocals). I read about somewhere
about a mic that was actually 2 mic's in one (1 shaft with two tiny
mic's attached to it), for doing vocals in stereo. It presumably has
both left & right output. Oh yea, and it could be battery powered so
no need for phantom power.
If anyone can remember which mic this might be, can you let me know?
My goal here is to reduce the # of wires around my computer: I won't
need multiple mic's, and I won't need a phantom power source == less
cords == wife is happy
Why would you want to do vocals in stereo?
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Well the idea is that there are 2 singers... I'm trying to get
something flexible enough that I don't have to keep layering vocals
onto vocals.
I remember what it was, the NT4.
Anyhow, I just realized another issue. If I went with the NT4, I spend
a lot of $$ and come out with something that won't work if a single
person sings straight down the middle, since its x-y arrangement is
really made for people singing from the side...
This is confusing Alright maybe I should forget about having 2
people sing at the same time, and just get a decent battery powered
condenser mic for vocals, like the C1000...
Thanks Scott
> --scott
"xz" <jasonshohet@gmail.com> wrote in message
news:1119031792.826235.249210@g44g2000cwa.googlegroups.com...
> onto vocals.
So you'll have a single person singing from the side. And you'll record that
side only, in mono.
You might want to re-examine that particular choice.
>onto vocals.
So, put them around a single mike. Or put them around two mikes if
you want to pan them.
The NT4 is a microphone intended for far-field miking. It's not a vocal
mike.
Stereo miking vocals is possible, but it's only useful if you are in the
far field and trying to get the sound of the room, where stereo imaging is
important. And if you do it, everybody has to stay rock-solid and not
move a fraction of an inch. This is rather difficult.
I can't imagine a worse choice for anything. If you want two people
singing at the same time, you have no phantom power, and you have a
decent room and no budget, I'd try the EV 635A to begin with.
--scott
Yes I see the NT4 isn't what I need for vocals, thanks for the
clarification on its usage.
Lets say i can go up a bit in $$, still want the battery-power, and
will be doing recording inside a room at home. And afterwards will be
adding delay etc. Perhaps something other than the EV 635A & the
C1000, perhaps something which can even make my voice sound better than
what it is...
Thanks
I did a google search, I didn't see tons of people using the EV 635A
for vocals, although someone indicated Elvis may have used it ... (is
it that old )... But perhaps its a good mic for the job.
Do you have a recommendation if I go up to $200, and still want the
battery power?
In article <1119030806.435911.294100@g14g2000cwa.googlegroups.com> jasonshohet@gmail.com writes:
There are several mics like that. It's called a single point stereo
mic. Audio Technica makes several, with a wide range of prices (and
quality). See this page for their line. http://tinyurl.com/85po6
Sony has a couple, Aiwa used to have a few and maybe still do, and
there are more serious ones from Shure, AKG, Neumann and Studio
Projects, to name a few.
I'm not sure why you'd want a stereo mic for vocals though. These are
sometimes used for live man-in-the-street interviews to pick up the
ambient sound in stereo, but generaly solo vocals are recorded in mono
unless you're after a pronounced ambient effect that you can't get
from a box (or program).
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
news:1119032858.377014.156080@f14g2000cwb.googlegroups.com...
> Ok i'll re-examine Can you recommend a battery-powered mic for
> vocals, that won't break the bank, that has generally better vocals
> than the C1000...
> Thanks
> vocals, that won't break the bank, that has generally better vocals than
> the C1000...
I'm sure somebody, somewhere, has made one at some time or other. But I'm
ricking my brain & I can't think of a single battery powered mic I'd
recommend for much of anything.
But there are a BUNCH of perfectly good dynamic mics that don't even need
batteries & will do a much better job for less money than a C1000. The
635a (like Scott said), ND/767, AE6100, OM3, hell, even an SM57 or SM58
into a Mackie will beat a C1000.
>what it is...
How about the EV RE-20? You can only put one person on mike at a time,
though, so you'll need two.
--scott
It's been around since the fifties. It's an omni, so you can easily
put two people on one mike, but you need a good room. Everybody has
used it for something at some point, and it's a very popular voiceover
mike.
>battery power?
The 635A. At least if you want to put two people on a mike.
--scott
In article <1119037591.064860.299670@f14g2000cwb.googlegroups.com>,
>Thanks
Actually, let me correct that. The 635A has been around since the late
sixties, but the capsule design is a miniaturized version of one that
is a decade older. It's a lot easier to make a good cheap omni than a
good cheap cardioid.
--scott
>> the C1000...
What about the old U87?
Well, it's not under $200....
--scott
>>I'm ricking my brain & I can't think of a single battery powered mic I'd
Yeah, and I almost mentioned a Crown/Realistic PZM. But it's not really
that good until you get rid of the battery. And I'd sooner take a
beating than use one on vocals. (but I know SOMEBODY's gonna say they love
it for vocals).
On Fri, 17 Jun 2005 13:53:26 -0400, xz wrote
(in article <1119030806.435911.294100@g14g2000cwa.googlegroups.com> ):
> cords == wife is happy >
> Jason Shohet
AT 822.
Ty Ford
-- Ty Ford's equipment reviews, audio samples, rates and other audiocentric
stuff are at www.tyford.com
In article <1119037591.064860.299670@f14g2000cwb.googlegroups.com> jasonshohet@gmail.com writes:
> it that old )...
Yes, it IS that old, but then "Elvis used an XYZ mic" is kind of like
"George Washington slept here." But whether Elvis used it or not is
irrelevant to whether it would be a good choice for you. It's a
perfectly reasonable mic for vocals, even duo or group vocals. No
power required.
> battery power?
It sounds like you're fixated on condenser mics. Understand that
condenser mics with internal battery power are generally fairly low
grade mics. You can do better with a decent dynamic mic (which is what
the EV 635 is).
NT4, I
> spend a lot of $$ and come out with something that won't
work if a
> single person sings straight down the middle, since its
x-y
> arrangement is really made for people singing from the
side...
Where did you get that idea?
One of the benefits of coincident mics is that you get very
good mono compatibility. IOW, a source that is right down
the axis of the pair is well-reproduced if you simply sum
the two mic outputs together.
having 2
battery powered
The C1000 - one of the most widely despised mics of all
times?
jasonshohet@gmail.com says...
> Thanks
> battery power?
I have gotten good vocal recordings with an Audio Technica ATM31a. It's a
battery powered electret condenser mic, and it's around US$150. Of
course, it really depends on the voice..
The reason I'm fixated on condenser mics is, I have a PCR-A30 keyboard,
and a laptop. I don't want any other devices to clutter up things. I
have an external firewall 410 (m-audio) which can do phantom power, but
I'm trying to reduce the # of wires -- for my wife So my PCR-A30 keyboard does NOT provide phantom power (which is sinful,
for such an expensive keyboard), just has a 1/4" mic inlet. So with my
dynamic mic - which I already have - I have to record, then normalize,
then I have all this hiss that I have to remove, which is difficult to
do without distorting the sound. So my thoughts are "To avoid extra
cables, a battery powered condenser mic would do the trick"... Thats
what has led me down this path... I know its a silly reason - but my
wife is on my case about the cables...
In article <1119459828.016199.242070@z14g2000cwz.googlegroups.com>,
>I'm trying to reduce the # of wires -- for my wife >So my PCR-A30 keyboard does NOT provide phantom power (which is sinful,
If your converters are noisy, using a higher output microphone might
help hide the noise, but to be honest if they are that noisy, they are
probably lousy in other ways as well.
--scott
