Tom's Hardware > Forum > Audio > Pro Audio > Quality mics using electrets?
Forum Audio : Pro Audio - Quality mics using electrets?
Archived from groups: rec.audio.pro (More info?)
What quality mics use electrets instead of voltage charging?
I won't attempt to define "quality."
Thanks,
Bob
"Things should be described as simply as possible, but no
simpler."
A. Einstein
Sponsored Links
Well, the first decent ones were the Shure SM-81s.... Shure did a really
nice job of designing clean and stable electret elements that didn't leak
the way most of thier competitors did. All of the Shure condensers are
still electret designs as far as I know.
The DPA recording series microphones are electrets. That's probably the
best example. The new AKG 451 reissues are electrets.
The Sennheiser MKH-series microphones aren't either electret or voltage
charged capsules, but a wacky RF discriminator circuit. If you are looking
for electret mikes because of humidity problems, they do just as well.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
In article <d90rm7126hb@enews4.newsguy.com> arcane@arcanemethods.com writes:
Shure SM-81.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
> Thanks,
> Bob
> simpler."
> A. Einstein
What about some of the Audio Technica microphones, like the AT4033?
Reply to Anonymous
"Step Sequencer" <djohanessen@gmail.com> wrote in message >
AKG C4000 is electret, and is less offensive than it's lesser electret
cousins.
geoff
Reply to Anonymous
DPA, I think.
Karl Winkler
Lectrosonics, Inc.
http://www.lectrosonics.com
Reply to Anonymous
The Sony ECM377 looked like the Sony C37, but was an electret.
Harvey Gerst
Indian Trail Recording Studio
http://www.ITRstudio.com/
Reply to Anonymous
The ubiquitous Sennheiser ME66 short-shotgun/hypercardioid.
Philip Perkins
Reply to Anonymous
charging?
Much of the CAD/Equitek line.
Reply to Anonymous
There are 1316 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
