Tom's Hardware > Forum > Audio > Pro Audio > Problem with Altec Lansing Select 641 400 system
Forum Audio : Pro Audio - Problem with Altec Lansing Select 641 400 system
Archived from groups: rec.audio.pro,rec.audio.misc (More info?)
About two years ago I bought the above described system and now only the
bass speaker and two satellites work - one front and one back. I tried
different cables but it
didn't help.
I contacted the manufacturer for help and parts and had the following
comment:
"Unfortunately we do not have any parts for the 641 and the replacement
system for this model is the MX5021."
Do the idiots expect me to buy the replacement?
I guess I could take the rear panel off the bass speaker, where the
connections are made, and look for loose connections?
Any other suggestions for trouble shooting?
TIA
rf
Sponsored Links
>didn't help.
>comment:
Yes, this is cheap consumer gear. It's supposed to last about two years,
so you got about the expected lifetime from it.
You could, but more likely something has gone wrong with the amplifier
module. Get out the scope, see if you have signal at the driver... then
work your way back one stage at a time until you find where it's gone
wrong. Could well be a bad cable or connector, but you need to measure
signal level at each point and see.
The problem is that it will cost less to replace it than to get a tech
for a couple hours to fix it. That's the way disposable gear is.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
- 0 +
Thank you Scott for your knowledgeable reply.
"Scott Dorsey" <kludge@panix.com> wrote in message
news:d9riir$mre$1@panix2.panix.com...
> >didn't help.
> >comment:
This sure is a surprise to me. What similar speaker systems are expected to
have a
lifetime of about 10 years or thereabouts?
Unfortunately I don't have a scope. I do have a multimeter. I'll take the
back off the
woofer and look for any signs of loose cables or burnouts.
This is amazing. The woofer, that contains the circuitry, is very heavy. I
would guess
about 20 lbs. Is that just concrete ballast? ;-) The four small speakers
appear to work ok.
Is there any such thing as a standard circuit board for speaker systems?
TIA
RF
> --scott
C'est vrai? :-)
Reply to Redfox
Kludge writes:
>have a
For the most part you probably want to go with seperates if you're looking
for something that sounds good and is solid.
If you want something solid with an integrated amplifier, you're going to
have to pay for it. The NHT M-00 is maybe a good starter unit, or something
like the Tannoy powered Reveal speakers. You will pay money, however.
The problem is that quality electronics have now become a very small
niche market and most folks are happy buying junk that falls apart.
This just drives up the price of the good gear since the economies of
scale are no longer there.
>back off the
How about a signal tracer? A signal tracer won't cost much and will
probably be the most convenient tool. Worst case you can take a pair
of dollar-store headphones, attach an alligator clip to the ground and
a test probe to the center pin. Tie the clip to the chassis ground
and now you can go poking around with the probe listening for signal.
Don't do this on hot chassis gear, but on the multimedia speakers you
are probably fine.
>would guess
>appear to work ok.
Open it up and see.
No, although with the standardization of Chinese stuff, we may soon be
getting there. Note that the manufacturer will probably laugh at you
if you try and get a service manual or schematic for this sort of gear
today.
--scott
Reply to Anonymous
- 0 +
Thank you Scott :-)
When a little time drops by, I'll do as you suggest.
It's great to have a genius around who is happy to offer so much help :-)
Many thanks again.
RF
news:da0p4a$1ht$1@panix2.panix.com...
> Kludge writes:
years,
to
> >have a
something
then
> >back off the
> are probably fine.
I
> >would guess
> >appear to work ok.
> Open it up and see.
> today.
> --scott
Reply to Redfox
There are 1257 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
