The small studio I work in has the opportunity to pick up a pair of
Wright passive monitors. Wright (now defunct) suggested 250 watts per
channel minimum to drive these monitors. We currently have an Alesis
Matica 500 (150 watts/channel at 8 ohms). At some point we would
upgrade to a better and more powerful amp but i'm wondering if in the
mean time we're asking for trouble using this combination. The
monitors would be used in a near field setup in a very small control
room at resonable listening levels. I know we won't be squeeing the
best out of these monitors with this amp but i'm more concerned about
damage to the speakers. Any thoughts...
You won't damage it if you don't clip the amps.
Use your ears and don't be stupid.
If you have customers who are stupid, maybe you don't want to let them
use the Wrights anyway.
Honestly, though, you can get an Adcom GFA-555 for not much money....
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
> --scott
Sound advice. Thanks. I've never come close to clipping this amp yet
so I don't anticipate that being a problem, unless the Wrights are very
hungry, which I won't know until I try them.
The Adcom is going for $300-$400 on ebay. Looks like a solid piece of
gear although it is still rated lower (200w @ 8 ohms) than Wright
reccomends (250w @ 8 ohms), but maybe i'm being unnecessarily
paranoid...
>paranoid...
The difference between 200 watts and 250 watts is only
1/3 octave.
But seriously, how old are the Wright's?
Good fortune,
Chris Hornbeck
"Chief Assistant to the Assistant Chief" -F&S
In article <dmi6c11aqop1ihhjlm7pnucfatfdb9dl88@4ax.com> chrishornbeckremovethis@att.net writes:
> 1/3 octave.
Uh, how many ohms would that draw?
I'd guess 8-10 years by now. They were pretty nice monitors, but a
very limited distribution product (as well as Wright's microphones,
also good for the time). It's one of those pretty much forgotten
companies. Not something that a lot of people should be worrying
about.
A friend of mine had (probably still has) a pair and brought them over
to my place to mix one of his projects. We hooked them up to my DH220
(120 watts or so per channel) without a thought about the Wright power
"requirements." They worked just fine.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
