Shuttle system help
I purchased the Shuttle system SN41G2. I installed an AMD Thour 2600+ cpu and also installed 768megs of DDR PC3200 ram. I set aside 128megs of that ram for the integrated videocard.
My problem is, I can't get nowhere near the scores on 3D Benchmark 2001SE that tom's hardware got. The reason i purchased this system is because i really liked the scores and the review of this system. Now i know the system on the review is a 2700 cpu but i dont think the 2600 would make that much of a difference.
My scores on 2001 was an average of "2736". And the scores according to your review (using the integrated card) was "4855".
Is there any possible way i can get the detailed information of how you setup the bios on the system you ran your review and tests on??
Im going from a 1.3T-bird/Geforce2mx system to this shuttle. mainly for the size of the shuttle and the system upgrade of course.
but right now my old system is ourperforming my new system.
any help would be GREATLY appreciated. I'm almost ready to return this thing.
p.s. both systems have winXP, the same videocard drivers (im using nvidia's 30.82), both set up the same way, and they both are running the save version of directX as well
software wise they are the same systems the only differcence is hardware.
15 answers Last reply
More about shuttle system help
  1. Did you run your benchmark with a Monitor resolution of 1024x768 or 1280x1024?
    The bench used 1024x768
    The loving are the daring!
  2. Yea i ran the same test the review did. (which is the default test)
    i know its not running right because i play Quake and inside quake, with the exact same game settings and video options, im getting better Frames Per Second (FPS) on my old system than i am on the shuttle.
  3. Returning.
    Did you notice that with a graphics card there was a huge difference in performance?
    Don't know if the benchmark would care about the hard drive but out of curiosity did u put in a 7200RPM drive?
    And is/are your Bios and drivers are up to date?
    The loving are the daring!<P ID="edit"><FONT SIZE=-1><EM>Edited by Flinx on 07/22/03 01:50 PM.</EM></FONT></P>
  4. "Did you notice that with a graphics card there was a huge difference in performance?"
    I'm not sure what you are asking. In the review, they tested it stand alone, as well as with a Ti4600 in it. Of course the Ti did a much better job than the integrated card did in the benchmark.
    I have not stuck an additional video card in the shuttle.
    Yea i have a 7200RPM hd in the new shuttle as well as a 7200RPM hd in the old pc.
  5. OK,
    A) Did you check for an updated BIOS?
    Did you check for better drivers?
    B) I have no more ideas. Wait till later.
    People come in at different times and someone
    else may know or have better ideas.
    C) I don't think the people who set up the benchmark
    hang around here but I could be mistaken.
    About the graphics card: Your frustration seemed to
    be about the graphics performance. I didn't think that
    the difference between the bench and your results were
    going to make you happy so I was hinting that you might
    want to consider buying a graphics card.
    Good Luck. I hope someone else can give you the
    answer.
  6. I was hoping i didnt have to flash the bios but that may be my only alternative to see if it helps (if there is an update). Im frustrated because its not performing as it should according to the benchmark results. That and i know its a better system than my first one. There shouldnt be a reason to upgrade to another videocard when "as is" the shuttle system should be outperforming my old system.
    I know its something simple, I just have not found it yet.
    Is there a way inside the BIOS to see what revision im using? Or do i have to catch it in the bootup sequence?
  7. Use the pause key on boot. That should help you catch it.
    Then use a key like <Esc> to continue.
    I don't recall ever seeing the info show up any bios setting panels.
    And check for updated drivers first.
    The loving are the daring!<P ID="edit"><FONT SIZE=-1><EM>Edited by Flinx on 07/22/03 07:19 PM.</EM></FONT></P>
  8. i downloaded the latest drivers from the shuttle website
    the nforce went fine
    the video drivers are another story
    its hanging up while installing the drivers for a good 3 minutes be4 installing the drivers
    then i reboot and it hangs at the "winXP" screen for 3-4 minutes b4 booting up (seems right after setting up the videocard cus the screen flashes a little)
    i tried to use other versions of drivers from nvidias archive but still hangs up alot
    any ideas ?
    oh yea
    after finally rebooting it will run ok and give me a somewhat decent score in the benchmark
    but it has blue screened on me once
    i guess ill keep trying all the versions of drivers b4 i flash the bios
  9. Well it seems you have some progress, glad to hear it was a driver problem.
    Did you search the drivers forum? I haven't yet.
    Ideas
    Start up in safe mode. Delete the device. Reboot and windows might find the proper stuff to install. Sounds like there was a problem with the install because it was in use.
    I would try variations of that on Windows 98 I don't know my way around XP that much.
    Good luck!
  10. where is the driver forum?
    still tryin to find my way around this place
    all i usually do is read reviews ..dont usually ahve to dig too deep.
  11. found the forum...im off to tell them my sad story and hope for help lol
  12. haha, that's worse than saying "dude, I got a Dell".
    <font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
    <font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
  13. wow i cant even get the thing to run the benchmark without locking up...even after going back to the original setup i was complaining about.
    hmm
  14. Did you know that you can get Dell computers with an AGP slot and PCI slots?
  15. Dell Hell!!!
    My company did a deal with Dell that allowed people in the company to lease a Dell for 3yrs. Effectively $15/mth Cdn or about $10/11 U.S.. That's not a bad deal ($30/mth with 56kb internet included). Course soon as someone wanted a better graphics card things got kind of "limited".
    Some people swear by Dell, great when your kid sticks a pencil in the floppy drive! Just call them up and replace it. Something not working, they send a tech.
    Guess it depends what you want your computer for. Certainly no bragging rights :smile: ! Hehe
Shuttle Components
