Windows 7 has some problem with auto-rollback and driver installing, please help
Last response: in Windows 7
July 16, 2012 10:35:24 AM
Hello guys,
My machine uses Windows 7 and it has encountered a strange issue recently.
If I delete a file or uninstall a program ( and I make sure they are gone ) then I restart the machine, right after the restart that file/program will still be there, like it is being rolled back :(  Now I can't modify anything like change wallpaper, delete files, etc. because after restart, they will be back.
Moreover, I can't install any new driver for my graphic card too ( I use Nvidia Quadro 4000 )...
Please help me with this issue, thank you.
July 18, 2012 11:50:53 PM
Try to delete or uninstall a file like Administrator.
Goto Start-- Run... -- Type cmd.
Then type net user administrator /active:yes
Restart
And try to delete or reinstall drivers.
Good Luck!
m
l
July 26, 2012 9:16:00 AM
many thanks, I will try that way :D
m
l
