Tom's Hardware > Forum > Audio > Pro Audio > mic question (bass boost/phase)
Forum Audio : Pro Audio - mic question (bass boost/phase)
Archived from groups: rec.audio.pro (More info?)
hello everyone,
some mic designs like large-diaphragm cardioid condensers will have the
bass response boosted if you put the mic very close to the sound
source.
is this because of phase issues?
i learned that the presence peak that many mics have is due to phase
stuff inside the capsule, so i was wondering if this is somehow related.
Sponsored Links
>source.
It's because of the cardioid pattern. I think how the proximity effect
works is discussed in the FAQ. I know there was a long discussion of
this here a couple years ago.
EV used to also have a nice discussion of this on the glossy sheet for
the RE-20.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
wow, thanks for the link!
that's some thick, meaningful reading. i will read it bit by bit.
Reply to Anonymous
David Satz wrote:
> Now if a wave is more nearly spherical when it strikes one side of the
> capsule but more nearly plane when it strikes the other side, there
> will be a greater resulting force than if the wavefront had the same
> shape on both sides. The output of a pressure-gradient transducer is
> proportional to the difference between the sound pressure at the front
> and back of the capsule. So ultimately it's that discrepancy in
> wavefront shape between the front and back of the capsule that causes
> the bass boost.
I'd thought this too but came to wonder why the effect, as
described, would be at all frequency dependant.
Bob
"Things should be described as simply as possible, but no
simpler."
A. Einstein
Reply to Anonymous
There are 1398 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
