New build AMD FX8120 based, won't boot ... please help
  • Cooler Master
  • DDR3
Last response: in General UK & Ireland Discussions
December 19, 2011 7:30:34 AM
I am building the following configuration:
CPU: AMD FX8120 http://www.amd.com/us/products/desktop/processors/amdfx/Pages/amdfx-model-number-comparison.aspx
MB: GA-990FXA-UD3 http://www.gigabyte.com/products/product-page.aspx?pid=3894#ov
RAM: Mushkin (996991) - 8GB (2x4GB) DDR3 PC3-16000 (2000MHz) http://www.mushkin.com/Memory/Blackline/996991.aspx
VGA: Saphire 6870 1Gb http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1037&pid=1270&psn=&lid=1&leg=0
Storage: OCZ Agility II 60Gb http://www.ocztechnology.com/ocz-agility-series-sata-ii-2-5-ssd-eol.html
Cooling: Cooler master Hyper 612 PWM http://www.coolermaster.com/product.php?product_id=6728
PSU: Cooler master GX-550W http://www.coolermaster.com/product.php?product_id=6641
Case: Cooler master HAF 932 http://www.coolermaster.com/product.php?product_id=5363
Ok, now to my question. I have installed all the things and when I turned it on for the first time, nothing came up on the screen and there was no BEEPing from the CPU.
I then repositioned the RAM from slots DDR3_1 and DDR3_2 to slots DDR3_3 and DDR3_4, still nothing.
I changed the VGA from 16xPCI_1 slot to 16xPCI_2, still nothing.
I cannot get any display. What could be the problem ??
I was thinking maybe the RAM is not compatible, since it is rated at 1.65V and the MB is 1.5V , but I did see RAMs in the approved list on gigabytes site when were rated for 1.65V. So I'm confused now.
Any help will be grateful.
More about : build amd fx8120 based boot
December 20, 2011 7:10:48 PM
Have you followed the instructions on Gigabyte's web site and made sure you have the F3 (or latter) BIOS?
December 20, 2011 7:37:40 PM
yes , i figured that out yesterday. The stupidity in this is that i now need an old AM3 processor so that i can boot up the system to upgrade the bios. :-| and then i can get the new processor up and running.
I figured it out by looking at the MB manufacture date which happens to be in May 2011 and the FX supporting bios (F3) was released in Aug ..
