Tom's Hardware > Forum > Audio > Pro Audio > Reduce Noise from the power outlet?
Forum Audio : Pro Audio - Reduce Noise from the power outlet?
Archived from groups: rec.audio.pro (More info?)
Hello Everyone,
I just moved my rehearsal and digital and non digital setup down to our
renovated basement.
I'm finding that the outlets down here seem to be very noisy. I'm hearing a
loud hum that I didn't hear upstairs.
Even if I just have just the PA on (small Yamaha EMX) it's noisy through the
speakers.
What can I do to reduce the noise? Is there an special adapter or a better
surge protector that will help?
Any advice would be appreciated!
Kim
Sponsored Links
Might not be the power outlet; when you relocated you may not have
grounded/shielded everything properly, or may have introduced a ground loop.
Reply to Anonymous
If your equipment consumes less power than your fuse can handle, try
connecting all equipment to the same power outlet. If the noise was due
to a ground loop, it should go away.
If you use several outlets, you may be able to solve the problem by
breaking the ground loop (for example, some DI boxes have a 'lift
ground' switch). Proper shielding of cables may help. If the noise is
mainly in (electric) guitar, you can alter the orientation of the
instrument to give the smallest amount of noise. If you play electric
guitar and the noise goes away when your hand touches the strings, use
a small crocodile clamp to ground yourself to the guitar (which is not
unlike those antistatic bracelets that computer technicians wear).
A surge protector or stabilizer might not solve the ground loop
problem, but is a good idea anyhow to protect your equipment.
Good luck!
Reply to Anonymous
"K Milai" <kmilai@dinobone.com> wrote in message
news:Uc7ze.55243$iU.45156@lakeread05
> Hello Everyone,
setup
> down to our renovated basement.
noisy.
> I'm hearing a loud hum that I didn't hear upstairs.
That would probably be a ground loop, which really has
nothing to do with noise at all. You could have the cleanest
power on the planet and still have noise from a ground loop.
> noisy through the speakers.
What do you have plugged into that PA?
adapter
> or a better surge protector that will help?
Nope and nope.
http://www.smr-home-theatre.org/Ground-Loops/
http://www.epanorama.net/documents/groundloop/
Reply to Anonymous
In article <Uc7ze.55243$iU.45156@lakeread05>,
K Milai <kmilai@dinobone.com> wrote:
>Hello Everyone,
>renovated basement.
>speakers.
Are you sure you have not created a ground loop in the process of moving
the system?
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
is your system setup the same downstairs as up?
go to the harware store and get a cuircut tester.
they have one that is generaly yellow in color and has three lights on
the front
you plug it in and the lights by how they come on confirm details
to tell you very simply if the cuircuts are wired correctly
it also could be that your basement cuircut has an electrical motor on
it
(freezer, ac, sump pump???)
while the one one upstairs didn't.
or maybe you have the setup in too close proximity of your electrical
service panel
Reply to Anonymous
"K Milai" wrote ...
> Hello Everyone,
> renovated basement.
Did you do the renovation? Was the wiring done properly?
Inspected? Have you tried using a circuit tester (the kind with
three neon lights from the home/hardware store)?
> a
Loud hum is the prime symptom of a ground loop. Has nothing to
do with power-line noise.
> the
> speakers.
You can go through the classic ground-loop troubleshooting
process. Disconnect all the audio cables and start backwards
from the speaker and work towards the other end to see where
the problem starts.
http://www.epanorama.net/documents [...] index.html
Reply to Anonymous
a
You might have to filter out that 60 Hz on the line.
Completely OT...on last night's Myth Busters, they did an experiment with
the "brown note", the low frequencies that purportedly cause bodily
distress. With a guy standing in the middle of a huge stack of large
subwoofers, he easily tolerated 5, 7, & 9 Hz at 90 dB, or maybe even louder.
He was unfazed. (reference to a couple messages a few weeks ago)
-John O
Reply to Anonymous
Thank you all for your grea observations and suggestions. Will get to work
on it right away.
Kim
news:Uc7ze.55243$iU.45156@lakeread05...
> Hello Everyone,
> renovated basement.
a
the
> speakers.
> Kim
Reply to Anonymous
> a
> the
> speakers.
What else is connected to the PA? Even if switched off, try removing all
connections to the amp except the speakers. There should be no hum. After
that, try working backwards, adding other pieces one at a time, as I believe
Arny suggested.
For an excellent paper on dealing with the most common cause of hum in sound
systems, see Hum & Buzz in Unbalanced Interconnect Systems at:
http://www.jensen-transformers.com/apps_wp.html
Stuart
Reply to Anonymous
Even more great suggestions and website info. Thank you so much.
I did already notice that when I pulled out the cable leading to my turned
off malletkat, the hum was softer. Thanks for your pointing to that. Will
continue working on it.
Kim
> Hello Everyone,
> renovated basement.
a
the
> speakers.
> Kim
Reply to Anonymous
John O, that was a very sneaky joke (suggesting that the person filter
out the 60 Hz coming from their AC power line ...). I wish I could
think of a way to top it, but at present I can't.
--best regards
Reply to Anonymous
On Thu, 07 Jul 2005 17:21:35 GMT, "John O"
From this article, it was MUCH louder:
http://en.wikipedia.org/wiki/Brown_note
"The experimenters on the show tried a series of frequencies between 5
and 10 Hz at 120-160 dBSPL,..."
I recall an old story of some famous inventor had a platform that
vibrated at the 9 Hz "brown note" and after one stands on it for a
short time it caused the alleged results. This would be much more
efficient than generating the note in the air, as the air's coupling
to the much more dense mass of a human body is very inefficient,
whereas direct vibration of the feet will put significant vibration
throughout the body, and specifically into the trunk area.
The inventor was Tesla, and googling tesla vibrating platform (no
quotes) brings up many links repeating a story starring Samuel Clemens
(perhaps better known by his penname Mark Twain) as the willing
subject/victim, despite Tesla's warnings to get off of the machine.
>-John O
http://www.mindspring.com/~benbradley
Reply to Anonymous
Plug *everything* Edison into *the same* ordinary working
safety-ground-not-defeated outlet strip. If you still
have hum, you have a serious, possibly dangerous problem.
Unplug and report back.
If everything's copacetic, cool beans.
Chris Hornbeck
"Watch the dying day, blushing in the sky,
Everyone is up tight; So, come on night.
Everyone is gone, home to oblivion." -E.S.
Reply to Anonymous
There are 1369 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
