Hi. I'm thinking of getting an M-Audio FW1814 interface, which is
Firewire-based. What would you recommend as a cheap but stable, reliable PCI
Firewire card? I don't need that many ports (two or more would be nice
though) but stability and speed are important, on a budget. I'm running
WinXP with an Athlon XP 1800 on an Elite motherboard. Thanks!
> tj hertz
How about the Lacie Firewire 800 PCI card ...
>> reliable PCI
>> tj hertz
> http://www.lacie.com/products/product.htm?pid=10173 >
> RME recommends this interface with their firewire product.
Word. i can vouch for the Lacie FW800 card as well. Very stable, never
had a problem. Not the cheapest though. In fact it's overpriced at about
100 dollars Cdn. Their FW400 card is likely just as good and cheaper.
Keep in mind that a FW800 connector is a different size and shape than
the 400 connector. So get whateve the FW1814 supports.
>> reliable PCI Firewire card? I don't need that many ports (two or
>> more would be nice though) but stability and speed are important, on
>> a budget. I'm running WinXP with an Athlon XP 1800 on an Elite
<genericaudioperson@hotmail.com> replied (at least I think (s)he did,
there was nothing quoted, so who knows?):
> my experience with m-audio stuff is that it works. the drivers work
> and the stuff works. it never sounds "amazing". but it works.
My 2000 Jetta gets better mileage than the 1982 LeBaron it replaced.
I just figured as long as we were throwing out comments that have
absolutely nothing to do with the question, I'd chime in too.
To the OP: look for anything with a TI or NEC chipset. I've had better
luck with those than the VIA chips. YMMV.
"It CAN'T be too loud... some of the red lights aren't even on yet!"
- Lorin David Schultz
in the control room
making even bad news sound good
> better luck with those than the VIA chips. YMMV.
ADS Pyro cards are the way to go - TI chipset and very very nicely
constructed, especially the "64 bit" compatible one (has the second slot for
64 bit PCI slots)
"it's very dangerous to fall asleep in the bath, I keep myself awake by
constantly making toast"
On Sat, 09 Jul 2005 17:30:31 -0600, Chip Borton
You want the chipset to be either Agere or TI.
If you can't see or the manufacturer doesn't say and the retailer won't
let yo look, don't buy.
I've seen similarly branded Firewire cards (Belden) selling for the same
price, one of which had a TI chipset, and the other someone else.
