Tom's Hardware > Forum > Computer Peripherals > Printers > How to print a Monitor's signal
Forum Computer Peripherals : Printers - How to print a Monitor's signal
I need to print the monitor's screen, through the VGA signal itself,(There is a printer with a wierd interface called SeikoII, but it cost much in paper and ink) so is it possible to convert the VGA signal to a Video in signal and take it by any Tuner or VGA cards as a Video in, and thus be able to print it through a PC??
Thanks in advance!
Sponsored Links
I'm not sure if I understand fully but I'll take a shot at it.
Are you just wanting to print certain frames or every frame of a video from a tv or tape? For printing certain frames you can feed the video to the computer via a tv tuner card and take screenshots of the video as it runs. Then you can print those screenshots.
If you are just wanting to print what is on the monitor of a computer just hit print screen (takes a screen capture of exactly what is on the screen), paste that into mspaint or something, and print it.
<A HREF="http://www.folken.net/myrig.htm" target="_new">My precious...</A>
Reply to folken
There are 1255 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
