Tom's Hardware > Forum > Audio > Pro Audio > Sound Effects Libraries
Forum Audio : Pro Audio - Sound Effects Libraries
Archived from groups: alt.radio.broadcasting,rec.audio.pro (More info?)
Does anyone know where to buy the Hannah-Barbera and Warner Brothers
sound effects libraries that they use for their cartoons?
Sponsored Links
"mcp6453" <mcp6453@earthlink.net> wrote in message
news:SpiCe.3651$oj4.120572@twister.southeast.rr.com...
Years ago, I worked at a place which had the Hanna-Barbera sound effects
(and character voices!) and the disk had licencing information on it which
explicitly cleared its contents for air. So apparently they recognised
that these sounds were so familiar that it would be better to let them be
heard anywhere someone had a need to use them. This disk is probably ages
out-of-print...it was already 15 years old when I saw it....but I don't
have a copy of it, and I didn't make a tape of it. You might find it
somewhere, though.
As for W-B...it's my belief that they've held tighter control on their
sound, and lifting it for your own use without licence might raise a fuss.
Men born to freedom are naturally alert to repel invasion of their liberty
by evil-minded rulers. The greatest dangers to liberty lurk in insidious
encroachment by men of zeal, well-meaning but without understanding." --
Justice Brandeis
For direct replies, take out the contents between the hyphens. -Really!-
Reply to Anonymous
I would presume that (a) they've had many years to develop their own
libraries, which (b) aren't for sale and (c) are extended at need by
sound effect artists on staff.
Develop your own? Buy generic? (Or, if you're a hobbyist and think you
can get away with cheating on copyright, "borrow" a copy out of their
existing material?)
Reply to Anonymous
> somewhere, though.
They're commercially available, or at least they used to be. I know some
people who have them, but they were at the station long before the
employees arrived, so they don't know where they came from. Quite a few
recording studios have them. As I recall, they were quite expensive.
Reply to Anonymous
- 0 +
On Sat, 16 Jul 2005 21:48:27 -0400, Joe Kesselman
>existing material?)
http://soundfx.com/hannabarbera.htm
http://soundfx.com/warnerbros.htm
Reply to David
>>existing material?)
Awesome! Thanks.
Reply to Anonymous
On Jul 16, 2005, mcp6453 <mcp6453@earthlink.net> commented:
>------------------------------snip>------------------------------<
Yeah, the rights to both were purchased by Sound Ideas in Toronto:
http://www.sound-ideas.com/wb.html
http://www.sound-ideas.com/hb.html
Note that they also have the Rocky & Bullwinkle library, which is very
entertaining. In addition there's a "Cartoon Express" 10-CD library, which
has another 1000 effects not in the WB or HB libraries (though this is one of
the few I don't own).
You might also check out the Hollywood Edge stuff, which includes several
animation-oriented effects:
http://www.hollywoodedge.com/categ [...] y_ID=12039
All of these packages are fairly expensive -- typically $500 each -- but
Sound Ideas does have sales from time to time. They also pop up on eBay once
in awhile, too.
Don't forget that you also need "traditional" SFX for any animated show.
Sometimes, in the right context, a straight effect can be very funny; I'm
thinking of, for example, a "bowling strike" effect when a cartoon character
staggers down a sidewalk and then knocks down three people. Sometimes, sound
effects are funny in situations; the effect itself doesn't always have to be
cartoony.
--MFW
Reply to Anonymous
The Hanna-Barbera library is licensable. Used to be you got it directly
from H-B for a media fee plus needle-drop charges. We had the set on
LP when I worked in Atlanta.
Warner Brothers is probably a lot more closed about that sort of thing
but you can call them and ask. They can only say no. A lot of their
older cartoons were done with live effects, though.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
>--scott
never mind this, as previously mentioned in this thread, WB and
hannabarbera SFX libraries as well as universal, lucasfilm, and many
of the other major studios can be bought through sound ideas, they
have been that way for years, for BUYOUT licensing.
www.sound-ideas.com
some of the best SFX out there, short of miking them yourself.
SD!
Reply to Anonymous
"Marc Wielage" <mfw@musictrax.com> wrote in message
news:0001HW.BEFF44F10030BCF9F0437550@news.giganews.com...
which
of
once
> in awhile, too.
character
sound
be
> cartoony.
> --MFW
Reply to Anonymous
There are 1186 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
