<A HREF="http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=361129#361129" target="_new">http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=361129#361129</A>
and
<A HREF="http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=77529#77529" target="_new">http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=77529#77529</A>
That should help give you an idea.
Here are additional references:
<A HREF="http://www.anandtech.com/showdoc.html?i=1841" target="_new">http://www.anandtech.com/showdoc.html?i=1841</A>
<A HREF="http://www6.tomshardware.com/howto/20021021/index.html" target="_new">http://www6.tomshardware.com/howto/20021021/index.html</A>
I'm no expert on the power requirements of all your equipment but lets do some rough numbers, ok?
Let's try to take the info the guy gave us in the first link
and see how it works out. If I understand some of what he's saying correctly then.
Video card 30W
Floppy 5W
Disk Drive 40W (2x20)
CDRom 20W (2x10)
Case Fans 12W (4x3)
Mobo 25W
Ram 20W (3x8 = 384MB)
Processor 50W
PCI cards 15W (3x5)
Roughly 215W When everything is running at the same time.
Considering you should be at 60%-70% of max I'd say you should have 350W.
Also, depends on which voltage rails this stuff is on and how the PSU is configured but anyway....
Lets see who corrects this
cause I'm sure I'm not right.
The loving are the daring!
