In article <dbnrk7$fje$1@paperboy.si.eunet.at>, GG <gg1@gmx.net> wrote:
>I am desperately looking for a users manual (info/download ) for the above
>mentioned unit.
>Got this used item with 7 days warranty/return, but I am not sure how to
>checkout
>the condition/workflow without a manual.
Call Dolby in the UK. They will send you a manual, and they also should
be able to to a rebuild on the unit.
>Maybe a kind soul can give me a short form description, just to make sure
>the unit is working fine.
If it hasn't been totally rebuilt and realigned in the past few years,
it won't be working fine. These things need a lot of care and attention
and they are packed to the gills with tantalum capacitors. If you buy
any of them, expect to spend some time getting them up to speed.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
