Tom's Hardware > Forum > Audio > Pro Audio > Edirol R1 / R-1 Portable Recorder MAJOR PROBLEM
Forum Audio : Pro Audio - Edirol R1 / R-1 Portable Recorder MAJOR PROBLEM
Archived from groups: rec.audio.pro (More info?)
I recently purchased an Edirol R1 portable recorder to record jam
sessions with my band. Just FYI, the internal mics ARE NOT suitable for
very loud sound sources as I had hoped. I thought that's why the unit
was more expensive than other portable recorders such as the iRiver and
Nomad that also offer line inputs and recording to MP3, but alas, I was
wrong. The audio is severely distorted no matter what input gain
setting I use, even when the level meter is far below hitting it's
maximum value. I am very disappointed and am still looking for a
portable recorder with a built in stereo mic that will allow me to
record a heavy rock band in the room with them without distorting.
Ability to record to MP3 and with a USB connection would be ideal.
If anyone has any ideas for how to fix the Edirol (muffling?) let me
know, or else I will be returning the unit.
Sponsored Links
http://www.soundsketcher.com/
i have this and the built in mic works fine under loud conditions.
it also hasa smart card and usb...
The overall sound is not that great but nothing is distorted and you
can always hear all the instrument. For practice it is all I need....
Now for taping shows I always thought the Edriol was the best, but
maybe not......
You could try getting one of those sony stereo condensor mics that have
the 1/8 jack.
http://cgi.ebay.com/ws/eBayISAPI.d [...] 48680&rd=1
That might fix your distortion problem...
Reply to Anonymous
I generally don't buy gear with misspelling on the promo page, even if
it is Yamaha.
Or is that the way they spell "cappuccino" in Japan?
Reply to Anonymous
In article <1122491111.620548.72670@g49g2000cwa.googlegroups.com> googlemyass@undertone.com writes:
> maximum value.
Turn it upside down. Move it farther away. Turn down your band. With
no input attenuator there's nothing you can do. I doubt that you could
get anyone to modify it for you.
If you use an external mic and preamp and go in to the line input,
you can use the controls on the preamp to set the record level
properly. But I recognize the value of having everything
self-contained. As long as you want to use the internal mics, you'll
have to rely on acoustical ways to attenuate the input level.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
Email or phone Edirol. You are doing something wrong or the device is
not working properly. If the meter is mowhere near its max then
attenuation is sufficient and you should not be hearing distorted
output.
Reply to Anonymous
In article <1122515207.798950.59140@o13g2000cwo.googlegroups.com> nowater@supernerd.com.au writes:
> output.
He's having a common problem with recroders like this. My Nomad
Jukebox 3 is the same. When the audio coming in (in this case from the
built-in mics being close to a loud source) is high enough so that the
input stage clips, when you turn down the record level, you're just
making a more accurate recording of already distorted audio.
Reply to Anonymous
There's got to be some kind of material that you could physically place
over the mic that would attenuate the signal without coloring the sound
too horribly. Can anyone think of a relatively "flat" substance or material?
Jonny Durango
Reply to Anonymous
In article <fbCdnTGDH8cRk3TfRVn-vw@comcast.com> jonnydurango1BUSH_FROM_OFFICE@comcast.net writes:
Yes. Air. About 20 feet of it. The Inverse Square law works wonders. I
don't know of any practical acoustic attenuator that has reasonably
flat frequency response.
Reply to Anonymous
Ah yes, but unfortunately air isn't a very good attenuator, supposing
most practice spaces don't have 5 extra feet of space let lone 20....and
most concerts/venues keep everything inside right around 110db. You
could probably get the same relative attenuation with a piece of .005"
paper than you would with 20' of air.
How about those fancy expensive earplugs that claim very flat response
like the Etymotic (sp?) ER-15's? What are they made of? I know they
start to drop off in the highest octave but are otherwise relatively
flat, nothing a little high shelf wouldn't fix in post. Maybe not ideal,
but better than distortion.
Jonny Durango
Reply to Anonymous
On Thu, 28 Jul 2005 19:23:55 -0700, Jonny Durango
<jonnydurango1BUSH_FROM_OFFICE@comcast.net> wrote:
>....and
"Doctor, when I hit myself on the head with this
hammer, it hurts. Can you fix the hammer?"
No magic bullets, Mon. Sorry; ain't happen'n.
Chris Hornbeck
Reply to Anonymous
>> place over the mic that would attenuate the signal without coloring
>> the sound too horribly. Can anyone think of a relatively "flat"
Shame about that damn direct/reflected ratio thing though. Maybe if the
band played outside in an open field away from traffic noise...
> I don't know of any practical acoustic attenuator that has reasonably
Hell, we can do it for light, why not sound? Why isn't there an ND
filter for audio?
"It CAN'T be too loud... some of the red lights aren't even on yet!"
- Lorin David Schultz
in the control room
making even bad news sound good
(Remove spamblock to reply)
Reply to Anonymous
In article <afudndFcR_1XD3TfRVn-3Q@comcast.com> jonnydurango1BUSH_FROM_OFFICE@comcast.net writes:
> Ah yes, but unfortunately air isn't a very good attenuator You
But what would it do to the frequency response? I know the tales of
tissue paper over the tweeters of NS10 speakers to tame the high
frequency response, but that's not quite the same thing. Distance is a
great attenuator. Alternately, you could replace the air with a lower
density gas, but that woudl make it hard to breathe.
That doesn't sound like what the R1 was designed to record. The people
in that space, with that sound level, should be wearing ear plugs.
Rubber, with carefully crafted holes. Want to drill ear-shaped holes
in your R1 to install ear plugs? It would be more practical to modify
the electronics, and far more effective. But that's not a job for an
amateur. You could try sticking some gaffer tape over the microphones,
though, and see what it sounds like.
Reply to Anonymous
"Mike Rivers" <mrivers@d-and-d.com> wrote in message
news:znr1122548652k@trad
> In article
>> max then attenuation is sufficient and you should not be
>> hearing distorted output.
Nomad
case from the
enough so that the
you're just
> audio.
Mic attenuators anybody?
Shure, Proco, and Audio Technica have 'em.
Reply to Anonymous
I think the original poster was talking about the built-in mics.
Jonny Durango
Reply to Anonymous
In article <euadnTwfQo4G2XffRVn-oQ@comcast.com> arnyk@hotpop.com writes:
Sure, but how do you put one in line with a built-in mic?
Reply to Anonymous
On Fri, 29 Jul 2005 10:34:30 GMT, "Lorin David Schultz"
>filter for audio?
Probably could be done, but might need to be similarly
large compared to a wavelength. Acoustic "lenses" and
such need to be at least comparable to a wavelength.
Interesting question; thanks,
Chris Hornbeck
Reply to Anonymous
"Mike Rivers" wrote ...
Right. It might even be happening inside the 89-cent electret
mic capsules themselves (before you even have access to the
electrical signal.)
See http://sound.westhost.com/project93.htm in the section
"Sound Pressure Level" at the bottom of the page, for the
Linkwitz modification to improve dynamic handling.
Reply to Anonymous
You might consider a set of our Low Cost Binaural mics with the low sensitivity
option. Under $100.
http://www.core-sound.com/lcmics.htm
Len Moskowitz PDAudio, Binaural Mics, Cables, DPA, M-Audio
Core Sound http://www.stealthmicrophones.com
Teaneck, New Jersey USA http://www.core-sound.com
moskowit@core-sound.com Tel: 201-801-0812, FAX: 201-801-0912
Reply to Anonymous
There are 1263 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
