Tom's Hardware > Forum > Audio > Pro Audio > Weird sound on PC
Weird sound on PC
Forum Audio : Pro Audio - Weird sound on PC
Archived from groups: rec.audio.pro (More info?)
I am having an odd sound problem on the kid's computer. It's an older
machine - P450 w Win 98 ES1868 sound card. They use it for listening to
music and IMing.
The sound has always been fine until a few days ago. Now it has a weird
tone to it. It's a bit trembly, but the odd part is the mix. For
example when playing a song, the music and the background singers will
be loud and clear, but the main singer will be faint and hollow
sounding. It works this way for mp3s and video sound. Wavs seem fine,
but they have no music so I can't tell for sure. It's like some parts
are comong through and others aren't (or are very faint)
I've checked the headphones and speakers, uninstalled and reinstalled
the drivers, and checked for any conflicts under system properties, and
looked at multimedia properties. Nothing is showing as a problem.
I checked the net for this problem, but all I found was endless pieces
of advice about what to do if you get no sound at all.
Anyone?
Sponsored Links
>music and IMing.
You're listening to the difference between the two channels. This can
happen if a ground line comes loose somewhere. I take it this happens
if you plug headphones into it, OR speakers? If so, it's not the speakers,
so I would check the PC board of the soundcard for a damaged ground trace
around the connector. This happens when people manhandle those cheesy
1/8" phone plugs... they provide no mechanical support whatsoever and it
is very easy to damage the board traces as a result.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
<joanne__king@hotmail.com> wrote in message news:1122910258.697620.265360@g44g2000cwa.googlegroups.com...
> music and IMing.
> Anyone?
I'm with Scott... the card is probably damaged. If this is the PC's only
purpose, a cheap SoundBlaster PCI card would be a fairly acceptable
replacement.
DM
Reply to Anonymous
There are 482 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
