Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > ATI HDTV WONDER-compatible monitor; please advise
Forum Computer Peripherals : Flat Panels/ LCDs - ATI HDTV WONDER-compatible monitor; please advise
I'm looking for a good price on a 20" (or bigger)flat panel, with a fast response rate, which will take advantage of the HDTV Wonder (which I haven't purchased yet). I'm not familiar with how the resolution #'s relate to the "Wonder". Will standard lcd resolution work well, or do I need a special monitor? Thanks
Sponsored Links
Isn't there a wiz-kid out there who can help me with an answer about what larger-sized flat panels (19"+) that would work well with the HDTV Wonder? And perhaps explain the type of HD resolution required??
Reply to mark1
I believe HD TV will dispay correctly on any monitors with resolutions of 1280x1024 or greater. But 16:9 is preferred.
They start at 17" and go up to Plasma 60".
I would be interested in NEC LCD3000 30 in. HDTV Television.
_____________________________________________
<font color=red> And the sign says "You got to have a membership card to get inside" Huh
So I got me a pen and paper And I made up my own little sign </font color=red>
Reply to RichPLS
Thanks for your reply, Rich; I'm sure a 30" would be way too expensive, so I was thinking more along the lines of a 20-21". This will have to double as my computer monitor and my TV. Any other suggestions??
Reply to mark1
How much do you wanna spend
benq makes a 23 inch hdtv with i believe a 16ms respocs time
apple has 20 23 and 30 inch medels
nec has 20 inch 20ms responce time
The lcd300 only has a 350 contrast
the nec lcd4000-e is nice 20ms respoce time
600 contrast 350 brightness
<A HREF="http://www.freewebs.com/lb19984/" target="_new">My Rog</A>
Reply to lb19984
There are 1210 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
