Tom's Hardware > Forum > Audio > Pro Audio > home vinyl cutter... opinions?
Forum Audio : Pro Audio - home vinyl cutter... opinions?
Archived from groups: rec.audio.pro (More info?)
http://www.discjockey101.com/jul2003.html
how bad would something like this stink?
or if you were an underground dj who wanted to cut some beats to vinyl
for a show Saturday night to scratch the pants off of, would this be a
sensible gadget?
one thing i can't figure out is how much the blank vinyls cost, which
you have to buy from Vestax apparently.
Sponsored Links
My suspicion is that the cogging will be a real problem, especially given
the extra drag of the cutting stylus. But you can ask the guys at
vinylium.ch, who actually designed and manufacture it. They also make
some higher end models.
>sensible gadget?
Probably, but I wouldn't want to cut classical work on it, and you are
very limited in pitch control. On the other hand, it is a big step up
from an old Presto.
No, I think you can use standard blanks from Apollo or Transco. Any
lacquers should be fine. Of course, they won't last very long if you
treat them like dub plates.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
> >sensible gadget?
> from an old Presto.
> --scott
FWIW I shagged both last year's Vestax US distributor, Korg USA, and
this years dist, AM&S (I sell quantities of the Vestax 'Handi-Trax' at
a local vinyl dealer: LoveGardens in Lawrence KS, so I'm a 'Vestax
Retailer') for the blanks (purportedly two kinds being available, 'long
lasting' and 'regular'); unobtainium in the US. I was told both times
how the product (the cutter itself) was a significant hassle to support
by the retailers, and was effectively 'not being sold' to the US
market.
My goal was (is) inexpensive blanks only, as one of my techs has a
Presto w/Altec electronics that I got for him from a local
studio/collector; the remaining blanks he got with it being rather
'precious' (FWIW a mono machine, but his minimal experiments being very
positive!)
Thanks for the heads up- now a Goggle search for 'Apollo' and
'Transco'!
-Robert
QTS
http://www.Braught.com
Reply to Electron
>market.
I'm not surprised. I'm really not sure why Vestax picked the line up
anyway... I think they liked the idea of having something neat like that
in the catalogue more than they liked actually selling and supporting it.
>positive!)
If it's got one of the later cutting heads (I don't think ANY of the Presto
heads had feedback, but 1-D was linear than most), it can be adapted for
hot stylus operation. Hot stylus allows you to glide through the acetate
instead of tear through it. Frayne and Wolfe has some information on the
process and is worth reading.
>'Transco'!
Don't know how much you will see, but they are two of the three acetate
manufacturers today. The third is in Japan and I forget their name
but Paul at Brooklynphono has used their discs.
In a pinch, you can cut overhead transparency material. You have to
be VERY careful about groove depth, and the chip curls and tends to clog,
but you can do it, at least with a hot stylus. Whether it'll work with
a cold stylus, I don't know.
I don't know if you can get microgroove styli for those things either,
but Al Grundy at International Cutterhead might know.
--scott
>-Robert
>QTS
Reply to Anonymous
In article <1123011063.893631.286310@g14g2000cwa.googlegroups.com> genericaudioperson@hotmail.com writes:
[the Vestax disk cutter]
> sensible gadget?
Well, I've watched it work. It seems to be well made, but it's by no
means a mastering lathe. It's designed exactly for that sort of
project. But it's expensive to buy and expensive to use, so you really
need to have some very well paying gigs in order to justify it.
This isn't something you can run out to your friendly local Guitar
Center to pick up a couple for the night's dance, so you'll probably
end up buying them by the carton. Cutting styli, too. The web site
says they're available from "Vestax VRX-2000 Retail Centers" but you
probalby need to e-mail them to find out where the nearest one is.
Pretend you're really interested and ask.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
In article <1123025555.270838.286980@g47g2000cwa.googlegroups.com> electron@grapevine.net writes:
> market.
That sounds to me like this should be the end of the story.
Reply to Anonymous
> >market.
> >positive!)
> >'Transco'!
> --scott
> >-Robert
> >QTS
Thanks!
-Robert
Reply to Electron
There are 768 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
