can you use phase to create an a capella track?
Last response: in Home Audio
Archived from groups: rec.audio.pro (More info?)
hello,
i've been listening to my old Ella Fitzgerald cd's on headphones. I
notice that the instrument groups are often very separated into the
left and right channels, with the vocals dead center. i think this has
something to do with "3 track" recordings that were done for a while.
could you apply some sort of phase processing in a daw to cut out the
background tracks and keep the vocals.
there are software plugins that remove the vocals by eliminating info
that is common to both channels. i'm looking to do the opposite: keep
the stuff that is the same in both channels, and eliminate the
different stuff.
No this does not work. I suggested to someone who asked this question
in the past to do just what you describe and see if it works. I was
ridiculed by some dude who had way to much free time on his hands and
did a math proof to show how brilliant he was and thump his chest.
However, he was correct and it made sense after looking at his proof as
to why it does not work.
Do a scan of the newgroup and you may find it.
genericaudioperson@hotmail.com wrote:
> hello,
> different stuff.
Interesting question....
please ask it over at comp.dsp.
Mark
Related ressources
<genericaudioperson@hotmail.com> wrote in message
news:1123090217.904962.56810@g44g2000cwa.googlegroups.com
> hello,
> headphones. I notice that the instrument groups are
> often very separated into the left and right channels,
> with the vocals dead center. i think this has something
> while.
> cut out the background tracks and keep the vocals.
You probably can't eliminate the instrumentals but you might
increase the prominance of the center-channel vocals by
pushing the stereo signal through a Dolby Pro Logic decoder
and capturing the center channel.
On 3 Aug 2005 10:30:18 -0700, genericaudioperson@hotmail.com wrote:
>hello,
>different stuff.
Of the three things (left, right, center), you can only remove one
by choosing channels and polarity, leaving the other two. There might
be some 'advanced processing' stuff that does a rolling FFT on the
left and right channels, and reconstructs the signal that's common to
both, but I don't know how well that might turn out.
http://www.mindspring.com/~benbradley
On 8/3/05 1:30 PM, in article
1123090217.904962.56810@g44g2000cwa.googlegroups.com,
"genericaudioperson@hotmail.com" <genericaudioperson@hotmail.com> wrote:
> hello,
> different stuff.
Best you can do is run it through a DOLBY Pro-logic decoder and listen to
the CENTER channel
On 8/3/05 12:30 PM, in article
> different stuff.
Yes, this is possible, quite easily. We sometimes do this in mastering. The
results will vary from "almost perfectly isolated" to "better than the full
stereo, but not by much".
You need to run the stereo mix into a Mid/Side decoder. This will actually
encode it into a Mid (center info) and the Side (both left and right only
info). From there you can just kill the Side and you're left with what ever
is left in the center.
If the Ella material is vocal right down the center and the instruments on
the hard left and right as you describe, then you should have a very clean
"vocal only" track. If it's more like a mix of today, where instruments are
panned not only hard left or right but also mid left/right and center, than
you'll still hear those instruments.
Does that help?
Allen
Allen Corneau
Mastering Engineer
Essential Sound Mastering
Houston, TX
In article <BF168817.25AAF%allen@esmastering.com>, allen@esmastering.com
says...
This doesn't make sense. A "mid-side decoder" does nothing but output
L+R (mid) and L-R (side). Subtract side from mid, and you get:
L + R - (L - R)
L + R - L + R
2R
Don't trust the math; make yourself a simple "left - center - right"
track and hear it for yourself. If you're hearing a "perfectly isolated
vocal" in mastering, it was mostly on one channel to begin with.
The Dolby Pro-Logic decoder is a bit more sophisticated. Below are
results I obtained from it, as posted back in August 2004:
Experiment 1: A CD track of me saying "left, right, center" panned
appropriately. At first blush, only "center" is heard from the center;
upon closer investigation, "left" and "right" are still present, but at
a much lower volume and with nothing present over (guessing) 250Hz.
Interestingly, some of the background noise and breath right before each
word appear to be present, full spectrum, in the center.
Experiment 2: If I take the above and mix in continuous sounds panned
left, right, and center, the "main vocal" *still* is panned mostly to
the appropriate speaker. However, the "background vocals" are still
present in the center speaker. My surround setup is horrible - the
center speaker's actually a different type of speaker altogether - so I
can't be sure if it's at the same level as the side speakers or not. It
seems to be either slightly softer or slightly rolled off.
Adobe Audition does have a fairly fancy FFT-type center-extraction
function, and there's also some plugin called "CenterCut" that does it.
Jay Levitt |
Wellesley, MA | I feel calm. I feel ready. I can only
Faster: jay at jay dot fm | conclude that's because I don't have a
http://www.jay.fm | full grasp of the situation. - Mark Adler
>> different stuff.
Adobe Audition 1.5 has a plugin that makes a fair go at extracting as
well as suppressing centre channel. Simple phase tricks can only
suppress it.
On 8/3/05 3:41 PM, in article BF168817.25AAF%allen@esmastering.com, "Allen
>> different stuff.
Ummmm... IIRR the MID of MS is L+R ...
Not sure how you derive both C-L -and- C-R without first deriving
C-only... Which is the thing you're trying to get at in the first place.
How does the math work to get from
L+R
And
L-R
To
Anything ressembling Center-Only?
On 8/3/05 6:39 PM, in article BF16CDDC.DD33%ten@nozirev.gamnocssj.com,
> L+R
> And
> L-R
> To
Actually, a M/S decoder works like this:
M=L+R
S= L+(-R)
If you put a stereo signal into this device then you get:
M= The sum of the left and right (mono)
S= What's left over after the left channel is added to a polarity-reversed
right channel. Anything common between the two will cancel out (to varying
degrees), leaving you you left-only and right-only information. If you turn
off the Side signal, you get what's left as "center" information.
Don't get me wrong, I'm NOT saying that all you'll be left with is only the
information the the EXACT center, just that center info will be strong and
things are panned away from center will be reduced in volume to where
anything hard left or hard right will be gone.
Does that help explain it? Perhaps I should send you some small clips of
audio to prove it to you.
Better yet, try it out for yourself.
Allen
Allen Corneau
Mastering Engineer
Houston, TX
no, that trick doesn't work.
This and more is explained in detail here
http://www.csp-audio.com/vocalremoval_article.htm
<genericaudioperson@hotmail.com> schreef in bericht
news:1123090217.904962.56810@g44g2000cwa.googlegroups.com...
> hello,
> different stuff.
> M=L+R
> S= L+(-R)
No it won't. A signal panned hard left or right will at most be
attenuated 6dB relative to a signal at the same level in both L and R.
-6dB is hardly "gone" ! In fact it will be exactly what you get when you
listen to the mono mix on (for example) an AM radio.
To get it to vanish completely in the mono mix a signal would have to be
in equal level and opposite polarity in L and R, and that's not what
panned hard left or hard right means.
Anahata
anahata@treewind.co.uk -+- http://www.treewind.co.uk
Home: 01638 720444 Mob: 07976 263827
On 8/4/05 5:08 PM, in article BF17EDFA.25C49%allen@esmastering.com, "Allen
>> L+R
>> And
>> L-R
>> To
> M=L+R
> S= L+(-R)
Well, in a word... No.
M = L+R
Simple
ALL-left and ALL-right is there, no 'reduced levels' are there.
Levels get reduced L or R when you do the recombining.
Again, M is NOT the same as C.
You can if you want, I could also send you 20 years of various MS work and
we could compare/contrast... But that won't change the math.
On 8/4/05 7:02 PM, in article BF1816DF.DF8A%ten@nozirev.gamnocssj.com,
Just a note, what you describe here is pretty much the trick that Dolby
Pro-Logic pulls off to derive a fairly believable CENTER channel from a
stereo pair. It doesn't quite happen the simple way you described though.
Ask the community
