Tom's Hardware Forums » CPU & Components » Sound Cards » line-in sound quality SB-Hercules
Add a reply
 Word :   Username :
Bottom
Author
 Thread : line-in sound quality SB-Hercules
pat
Profile: Forum Veteran
More Information
I want to buy a new sound card. I can have the SB audigy2 or the Hercules Fortissimo III 7.1. Both of them should play good, but what matter to me is sound recording quality with my Radeon AIW 8500dv. Is the Hercules has good recording (no hiss, crackling, noise,...) in order to get very good quality capture? Or should I go with the Audigy2.
Will be use with a nforce2 board, if that help.
Thanks
-Always put the blame on you first, then on the hardware !!!
Related Pr oduct
Profile: old hand
More Information
Both are okay, but you'll get some noise in either case. I'd go Guillemot just because I'm a fan of their products. Just make sure you use the external connector, not the internal AUX connectors. Less noise that way. And keep the cable away from the monitor and power cables.
umheint0's phat setup --> <A HREF="http://home.cc.umanitoba.ca/~umheint0/system.html" target="_new">http://home.cc.umanitoba.ca/~umheint0/system.html</A><--
Add a reply
Google Ads
