Tom's Hardware > Forum > CPU & Components > Sound Cards > Choosing home cinema receiver to go with Audigy 2
Forum CPU & Components : Sound Cards - Choosing home cinema receiver to go with Audigy 2
I have had the Audigy 2 soundcard for 8 months now and I am looking into getting a 6.1/7.1 home cinema receiver to go with it. At the same time I thought it about time to get a whole new hi fi make over for the living room as the PC is in the same room as the Audio system and TV. Also with Sky+ supporting Dolby Digital I thought now would be the best time to get involved.
However I have a plethora of brands to choose from and I cant find one with THX support. My request is that someone could put this list of hi-fi separates brands into ranking: best at the top worst at the bottom because I just want an idea of where each manuafacturer stands in the market.
Sony
Technics
Panasonic
Yamaha
Denon
Wharfedale
Bose
If you have any other brands please include and rank as appropriate. I am not fussed about how much I spend but I dont want to go nuts.
Secondly which brand would you go for if you were selecting hi fi separates and home cinema receiver and why.
Last but not least could someone suggest a home cinema receiver which is 6.1/7.1, has THX support and enough inputs for TV, Video, two Tape Decks, CD Changer, Turntables, a DAB radio connecting via Coaxial, a Sound Blaster Audigy 2 connecting via Coaxial, Sky+ connecting by Coaxial or optical not to sure though :-s, 2 opticals for PS2 and Xbox. Also the reciever must be able to decode Dolby Pro Logic I & II, Dolby Digital & EX, DTS & ES, NEO.6, 24/96.
Thanks for your time
Just cos I am a semi skinhead it does not mean that I am a semi PC Guru. I am 25% PC Guru, 15% Thug and 10% Alcoholic!!!
Sponsored Links
I think your in the wrong forum for that. I would go to avsforums.com and http://www.htguide.com
As far as receivers I would look first at separtes, Like Rotel, if that is out of your range I would go to the nicest Marantz you could afford(others really like dennon its a preferance thing). For all in one receivers though Marantz is known for having the best 2 channel audio for music, that is why I like and own them. Don't worry about thx support just make sure the reciever you buy has flexible crossover settings.My Rotel 1066 does not have the thx stamp, but I picked it over the top of the line dennon or marantz.
Ranking
1)Rotel separates (for under $2500usa)
2)Rotel Reciever 1065 then 1055
3) Marantz 9300 then 9200 then8300 then 8200 etc down to your price range
4) Dennon or yamaha they both have a different sound go with what you like. I prefer the yamaha many prefer dennon.
5) Pioneer elites are up there too.
6) I would not look at anything else, Unless your going over 2500usa.
Reply to mattburklund
I've always been a fan of NAD Electronics. Powerful, powerful amps for the money. I also liked the minimalist approach.
Well things have changed. Not so minimalist now.
<A HREF="http://www.nadelectronics.com/av_receivers/T762_frameset.htm" target="_new">http://www.nadelectronics.com/av_receivers/T762_frameset.htm</A>
I don't know how good it is but I think it's worth a look/listen.
You have quite a shopping list but I think the NAD has everything you listed.
<b>56K, slow and steady does not win the race on internet!</b>
Reply to phsstpok
- 0 +
First and most important recommendation ever: Listen before you buy. Audition the equipment you're buying and don't just go for looks, whiz-bang features and the brand. You'll forever curse yourself if you happen to not like the sound you're hearing from an amplifier/receiver. And remember, the speakers you're choosing are very very important in this regard. Always audition the combination before a purchase.
Now with that out of the way, I suggest you look into NAD and Denon for an entry-level thingie. Denon especially have very good receivers across the range and the NAD sound is fab IMHO and frankly no other budget amplifier or receiver I've tested can match their equipment's sound characteristics (IMO only Denon comes close). Marantz gear are great but beware of their warm character. Their amps were excessively warm sounding to my ears (when I was buying my own amp, a Denon).
Reply to r2k
Thank you for your suggestions. I was going to look at Yamaha or Denon. How do Denon's sound different from Yamaha? I was also going to get some proper speakers to go with the receiver. Perhaps order four bookshelf speakers and two centre speakers and a nice kick ass subwoofer.
Also I was looking into Sony's ES series - are Yamaha's and Denon's separates & speakers better than Sony's ES series? Also if I was to mix and match different brands, would their be any effect on performance?
Also whilst I apprechiate the help your giving me, please remember I am from the UK so we dont get some brands that you guys from the US get
Thanks for your help so far!
Reply to marshahu
Definitely audtion before you buy if you can. Go to a specialty store and ask if they have loaners. Auditioning stuff at home is the way to go.
Loudspeakers are the most important part. Put a large portion of your budget toward speakers.
I didn't realize you are in the UK.
Here's some new links.
<A HREF="http://www.nad.co.uk/av_receivers/index.htm" target="_new">http://www.nad.co.uk/av_receivers/index.htm</A>
<A HREF="http://www.nadelectronics.com/ht_amplifiers/S170_framset.htm" target="_new">http://www.nadelectronics.com/ht_amplifiers/S170_framset.htm</A>
<A HREF="http://www.nadelectronics.com/ht_amplifiers/S250_framset.htm" target="_new">http://www.nadelectronics.com/ht_amplifiers/S250_framset.htm</A>
Search the site for dealers near your locale.
Reply to phsstpok
I a/b'd a Yamaha 2300 to a dennon 3803, and I preferred the sound of the Yamaha to the dennon. I would describe it as saying that the Yamaha had a little more treble energy. Others would say that the Yamaha could be a little brighter in sound, I general do not prefer bright, but with the speakers that I was listening to I preferred the Yamaha. Basically you have things that sound bright, neutral or a little dull. You do not want a bright sounding receiver with a bright sounding pair of speakers, or dull with dull. I just read the new What Hi Fi magazine, Out of the UK, and for under 350uk they loved the new pioneer. So, you see there are many factors. You need to figure out: 1.How much are you going to spend for the whole set up? 2. Do you like the bright sound, or more dull/accurate? If you don’t know you need to figure that out on your own, just go to any hi quality hifi store and they can help you.
It is ok to mix and match brands
I have also heard many good things about the NAD systems,
I don’t think you would be going wrong with them.
When you ask if the Sony es series is better, you need to realize that we are talking about sound and what I think sounds better you may not think sounds better. You also have to ask what’s most important, all the bells and whistles or the best sound period. The new pioneers and the new Yamahas (will be out in a few months) are great. They have a feature that automatically configures the sound based on the acoustics of your room. You put a mic in your seating position and the receiver adjusts the output to each speaker automatically. So, is that a feature you want? Others like myself like the sound of the rotel so much more, that we sacrifice a cool feature like that because we can calibrate it ourselves with a decibel meter. My rotel has all the decoding features you mentioned in your first paragraph, but they all do, even a 300 pioneer. Are you going to use it just for movies or movies and music? Because one receiver may be great for movies, but horrible for music, while the other is ok at each.
Good Luck, go to the other web sites I mentioned, tell them your budget, and you will be ok.
Thanks guys for all your help. I am going to be using this setup for music, movies and games. Can the Audigy 2 output Dolby Digital EX, DTS ES digitally? If it can only output Dolby Digital 5.1 then I might as well save a couple of hundred pounds and buy a Pioneer setup with a receiver with RDS tuner, decodes Dolby Digital, DTS and Dolby Pro Logic II, has a Twin Tape, 6 disc changer, Record player, a coaxial input for the Audigy 2 and two Optical inputs for Sky+ and PS2 when I bring it down. I was also thinking of getting a DAB radio that plugs in via Coaxial. Is there any way I can get a splitter for the one Coaxial socket so that I can have the Audigy 2 and DAB radio plugged into the same socket hearing sounds from both sources.
The speakers are all magnetically shielded which is what I need because I plan to put these near a TV. There are 5 speakers but there is no subwoofer. It seems to be built in to the front two tower speakers but I still think I'll get one anyway - probably just a cheap £50 one from Acoustic Solutions or maybe a decent one from Pioneer - depends on how much dosh my dad has. He is really iffy about spending £1000 on a whole hi-fi. He's half deaf so the surround sound means squat to him. Total price for the Hi fi setup with turntable - £999 (I save £100 without)
Is this Pioneer set up good and worth the money? Also is the Audigy 2 capable of digitally outputting 6.1 sound and Dolby Digital EX/DTS ES soundtracks.
Reply to marshahu
- 0 +
Audigy2 can output Dolby Digital EX 6.1 streams digitally but for DTS/DTS ES you should wait for the upcoming Audigy2 ZS series.
Reply to r2k
Oh damn! I already have the Audigy 2. Is the ZS series an addon or a completely new soundcard? The box says it can only output Dolby Digital in 5.1 through the digital socket. Do I need to download any updates to enable 6.1 Dolby Digital EX through the digital socket.
Whats the difference between an amplifier with THX and one without. I thought that the Audigy 2 could already decode DTS/DTS ES. What updates can I get to enable DTS/DTS ES.
Reply to marshahu
If you want to play games in surround with your audio rig make sure you get a receiver with discrete 5.1 anolog inputs.
Only the Force 2 motherboards with Soundstorm have 5.1 encoding for games and other PC generated sounds.
Most motherboards and sound cards can do 5.1 passthru (DVD, DIVX, etc) but only Soundstorm can encode computer generated sounds into digital 5.1.
Reply to phsstpok
R2k I read about that new audigy 2 and did a little research.
I found this
http://it.asia1.com.sg/reviews/car [...] 30827.html
beside the snr what are the differences between the audigy2 and the audigy 2ZS
Thank you very much for that information. Very informative. Creative never stop rolling them out do they! Now that I am still trying to put together my hi fi rig, I realised the reason why the market has switched to 7.1 so quickly. People who want to build their own hi fi rigs need to buy that one rear centre and many dealers are not willing or simplying can't afford to break open packs to get that single speaker. With 7.1 you can just buy a pair and no packs need to be broken.
In regards to your question what is the difference, the SNR is one, but also the fact that it has moved to 7.1. Astonishing! Creative have stuck with 5.1 sound cards since 2000 yet they havent even lasted a year with 6.1. Also the new soundcard supports more standards than just THX and Dolby Digital EX. It supports DTS, DTS ES, neo 6.1 as well as Dolby Pro Logic 2. The Audigy 2ZS also has support for EAX 4.0 - sounds like yet another format. One last difference is the high price.
The other day my friend had only £20 to spend on a soundcard and since his PC is in his bedroom, he only wanted 4.1. Besides his PC is Windows 95B so there is no support for DVD and he cant afford to upgrade. He got the SB Live! Value series and it came with some really cool software like Prody Parrot 1 and Creative's Keytar and Rhythmania.
So I though I'd try and install them on my PC which has an Audigy 2 - wrongfully I assumed that it will automatically work on my PC. First the Keytar and Rhythmania programs failed to find a MIDI out device - the card is fully installed and the MIDI comes from the Audigy 2 Synth A which is the only hardware MIDI synth that actually works - the others are Directsound Software synths which only work in games and dont always work with MIDI files.
Then when Prody Parrot installed it aborted because it could not detect any SoundBlaster hardware despite the fact that its sitting right there clearly labelled a Sound Blaster Audigy 2.
How can I fool these programs into thinking they are running on a SB Live! card and will there be any reduction in performance or final output. Or on the other hand are these programs avalible in versions which dont require an SB Live! card and still give the top performance expected from an Audgy 2. Bear in mind that I would like to be able to donwload a FULL version for FREE. Please NO SHAREWARE or TRIALWARE AND ESP. NO DEMOS. Those types have been the cause to my cripped system.
Thank you for your time once again and thank you all for pitching in! ;-)
Reply to marshahu
- 0 +
Remember though that for both the Audigy and the Audigy2, you can enable passthrough for the digital output i.e. the card will pass any signal to this output without doing any processing (such as Dolby EX decoding) on it. So if the receiving end can decode Dolby, DTS or whatever, they can all be passed through the digital output.
Reply to r2k
Matt,
I have just received a Denon brochure through the post today. I refferred back to this post to check what you said. You said Denon's were rather Dull but accurate sounding yet Yamaha's are very bright sounding with lots of treble energy. I looked atr Denon's speakers and not only are they only stereo but they don't even have enough power to handle their low end amplifier which outputs at 80w!
So I thought since Yamaha do surround sound speakers at least at 80w, I thought I'd get Yamaha speakers. You said Yamaha speakers sound bright so if I couple them with Denon, will the sound be equal - not too bright and not too dull or will it be really poor quality sound?
Please let me know what the results would be like using my rig. Also may I direct you to my above question. If possible please answer that as well
Reply to marshahu
I never spoke to you about speaker sounds, only the receiver. As far as the speakers that is a wholenother ball of wax, as far as speakers I would go with a company that just does speakers, like B&W, M&K, and the list goes on and on, but you have yet to give a budget so I really cant help you unless I knew that. I would not buy yamaha speakers or dennon, but that is me. Check the other fourms and ask them: "If you had $___.00 What speakers would you buy for 5.1, they would be used with this receiver______ and be used for music and movies.
Matt,
My budget for the whole rig is about £1000 but I am willing to give a £500 leeway. What are the websites for decent speakers that will compliment the sound of my 6.1 Denon receiver and separates.
If anyone else can help then suggestions are welcome. Also if possible please answer my previously posted questions.
Thank you all once again!
Reply to marshahu
There are 638 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
