General speed advise
Forum Laptops & Notebooks : General Laptops & Notebooks - General speed advise
I'm looking for a relatively cheap laptop, and have found several alternatives in my price range with the features I want.
I'm a real novice at laptop CPUs though; could someone knowledgeable help out here? Thanks
My first two choices (as they fit my price) are:
http://www.dabs.com/ProductView.aspx?Quicklinx=4B86
Sempron 3400
http://www.dabs.com/ProductView.aspx?Quicklinx=4CFJ
My last choice (which I know is fastest) is:
http://www.dabs.com/ProductView.aspx?Quicklinx=4BLC
Sponsored Links
The sempron (click link) looks to be a Socket S1, because of the DDR2 memory used. However, I cannot state anything about its performance characteristics because I am unfamiliar with mobile AMD. It is 64 bit capable (look at link).
The Core Duo is a good processor, I have one in my Dell E1405 that is similar at 1.66 Ghz and 2MB L2 cache. This processor, Yonah (Core Duo), is not 64 bit capable however. It looks to be a good offering because there are other Yonah's (as well as Meroms) with reduced L2 cache and Front Side Bus (FSB) speeds.
The Merom is a 64 bit capable processor. From what I have read about it, it is up to 20% faster than yonah. Click on this link for comparison of Yonah and Merom.
Here are additional informative links: link 1, link 2, link 3, link 4, and link 5.
*Other information should exist besides THG and Anand Tech, however.*
For link 3, you may have to extrapolate from Yonah to the AMD K8 architecture. Link 4 unfortunately does not include the mobile Sempron but may be useful if you consider other mobile AMD Cpu's. Link 5, although it does not seem useful, presents an attempt on comparing the Turion X2 and Merom. Look through the comment criticisms of Link 4 for additional, and valuable insight
Finally, if you consider Mobile celerons and Mobile Sempron think about the lack of CPU throttling: Speed step (Intel), and Power now! (AMD).
The notebooks look good with the XP OS, instead of Vista. :P
Reply to phase_22
You actually have those notebooks ordered correctly in terms of speed. As far as laptop CPUs go the general rule is:
Pentium/Celeron M<Sempron<Turion<TurionX2=CoreDuo,Core2Duo.
slowest------------------------------------------------------------->fastest
The Sempron will by far be the slowest of the three.
Reply to lostandwandering
Thanks for the replies, i've learnt a fair bit from that :) I'll go for the core duo I think
Just 2 questions now;
I'm used to a speedy desktop where programs open instantly.. I know how to create a very optimized setup of Windows, but will the raw power of the core duo and 512mb ram (;p) be enough to make it fast?
That brings me onto my second point, is 512mb ram gonna be enough? Of course I only plan to use the internet, work, and listen to music, but I've heard lots of people state 512 isn't enough anymore.
Thanks.
Rich
Reply to Whilding87
The RAM that is installe is 667mhz which is a good match for that CPU. You will definitely want to upgrade to 1 gig though even in XP.
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > General speed advise
There are 639 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
