Error log:
Sam
1502-4240-1125-0482-1088-9784
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 29/01/2003 10:37:36 PM
Nero Version: 5.5.10.32 (Nero Express)
Recorder: <PIONEER DVD-RW DVR-106D>Version: 1.05 - HA 0 TA 1 - 5.5.10.32
Adapter driver: <viadsk> HA 0
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <PIONEER DVD-ROM DVD-116>Version: 1.09 - HA 1 TA 0 - 5.5.10.32
Adapter driver: <viadsk> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : ST380021A 3.19 viadsk Port 0 ID 0 DMA: ?
CdRomPeripheral : PIONEER DVD-RW DVR-106D1.05 viadsk Port 0 ID 1 DMA: ?
CdRomPeripheral : PIONEER DVD-ROM DVD-116 1.09 viadsk Port 1 ID 0 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 767MB (785904kB)
Free physical memory: 490MB (502612kB)
Memory in use : 36 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: On
27.8.2003
ISO compilation
8:24:36 PM #1 Text 0 File Isodoc.cpp, Line 7576
Iso document burn settings
Determine maximum speed : FALSE
Simulate : TRUE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
8:24:36 PM #2 Text 0 File Reader.cpp, Line 115
Reader running
8:24:36 PM #3 Text 0 File Writer.cpp, Line 125
Writer PIONEER DVD-RW DVR-106D running
8:24:36 PM #4 ISO9660GEN -11 File geniso.cpp, Line 4571
First writeable address = 0 (0x00000000)
8:24:36 PM #5 Text 0 File Burncd.cpp, Line 3736
Turn on Disc-At-Once, using DVD media
8:24:36 PM #6 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 2296224 (2296224) = #2296224/510:16.24
relocatable, CD pos for caching/writing not required/required, no patch infos
8:25:07 PM #7 Text 0 File DlgWaitCD.cpp, Line 222
Last possible write address on media: 2298495 (510:46.45)
Last address to be written: 2296223 (510:16.23)
8:25:07 PM #8 Text 0 File DlgWaitCD.cpp, Line 227
Write in overburning mode: FALSE
8:25:07 PM #9 Text 0 File DlgWaitCD.cpp, Line 1679
Recorder: PIONEER DVD-RW DVR-106D, Media type: DVD-R
Disc Manufacturer: PRINCO -
Disc Application Code: 64, Disc Physical Code: 193
8:25:07 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder PIONEER DVD-RW DVR-106D for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 408006656
8:25:07 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2296224 blocks [PIONEER DVD-RW DVR-106D]
8:25:07 PM #12 Phase 24 File dlgbrnst.cpp, Line 1655
Caching of files started
8:25:07 PM #13 Phase 25 File dlgbrnst.cpp, Line 1655
Caching of files completed
8:25:07 PM #14 Phase 32 File dlgbrnst.cpp, Line 1655
Simulation started at 1x (1,380 KB/s)
8:25:09 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1978
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
8:25:09 PM #16 Text 0 File DVDR.cpp, Line 1421
Recording mode: Sequential Recording Mode
8:25:09 PM #17 Text 0 File Mmc.cpp, Line 18003
Set BUFE: supported -> ON
8:25:09 PM #18 Text 0 File DVDR.cpp, Line 1535
Start write address at LBA 0
DVD high compatibility mode: Yes
8:25:11 PM #19 Text 0 File Cdrdrv.cpp, Line 7877
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
8:25:14 PM #20 Text 0 File Writer.cpp, Line 316
20:25:14.846 - PIONEER DVD-RW DVR-106D : Queue again later (Intervall : 47msec)
8:25:40 PM #21 SCSI -500 File Cdrdrv.cpp, Line 1416
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03480000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x03 0x10 0x00 0x00 0x10 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
8:25:40 PM #22 Text 0 File Writer.cpp, Line 453
20:25:40.783 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 32768 Bytes
8:26:26 PM #23 Text 0 File Writer.cpp, Line 442
SCSI-Layer send CDRERR_BUFFER_TO_BIG to writer
8:26:26 PM #24 Text 0 File Writer.cpp, Line 453
20:26:26.979 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 30720 Bytes
8:26:27 PM #25 Text 0 File Writer.cpp, Line 424
Writer-Buffer for PIONEER DVD-RW DVR-106D reduced to 30720Bytes
8:26:29 PM #26 Text 0 File Writer.cpp, Line 453
20:26:29.954 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 28672 Bytes
8:26:30 PM #27 Text 0 File Writer.cpp, Line 316
20:26:30.004 - PIONEER DVD-RW DVR-106D : Queue again later (Intervall : 47msec)
8:26:30 PM #28 Text 0 File Writer.cpp, Line 453
20:26:30.004 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 26624 Bytes
8:26:30 PM #29 Text 0 File Writer.cpp, Line 453
20:26:30.054 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 24576 Bytes
8:26:30 PM #30 Text 0 File Writer.cpp, Line 453
20:26:30.094 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 22528 Bytes
8:26:30 PM #31 Text 0 File Writer.cpp, Line 453
20:26:30.144 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 20480 Bytes
8:26:30 PM #32 Text 0 File Writer.cpp, Line 453
20:26:30.194 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 18432 Bytes
8:26:30 PM #33 Text 0 File Writer.cpp, Line 453
20:26:30.234 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 16384 Bytes
8:26:30 PM #34 Text 0 File Writer.cpp, Line 453
20:26:30.284 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 14336 Bytes
8:26:30 PM #35 Text 0 File Writer.cpp, Line 453
20:26:30.334 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 12288 Bytes
8:26:30 PM #36 Text 0 File Writer.cpp, Line 453
20:26:30.384 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 10240 Bytes
8:26:30 PM #37 Text 0 File Writer.cpp, Line 453
20:26:30.424 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 8192 Bytes
8:26:30 PM #38 Text 0 File Writer.cpp, Line 453
20:26:30.474 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 6144 Bytes
8:26:30 PM #39 Text 0 File Writer.cpp, Line 453
20:26:30.524 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 4096 Bytes
8:26:30 PM #40 Text 0 File Writer.cpp, Line 453
20:26:30.564 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 2048 Bytes
8:26:30 PM #41 SCSI -31 File Cdrdrv.cpp, Line 1416
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02264000
Status: 0xE6 (0x0E, SCSI_BUFFER_TO_BIG)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x03 0x10 0x00 0x00 0x20 0x00 0x00 0x00
8:26:30 PM #42 Text 0 File Writer.cpp, Line 446
Recorder-Buffer cannot be reduced any more
8:26:30 PM #43 CDR -31 File Writer.cpp, Line 333
Unspecified Recorder Error
8:26:30 PM #44 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
8:26:30 PM #45 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
8:26:30 PM #46 SCSI -31 File Cdrdrv.cpp, Line 1416
Sense Code: 0x26
Sense Qual: 0x02
8:26:30 PM #47 CDR -31 File WriterStatus.cpp, Line 163
8:26:30 PM #48 TRANSFER -24 File WriterStatus.cpp, Line 163
Could not perform end of Disc-At-Once
8:26:34 PM #49 Phase 34 File dlgbrnst.cpp, Line 1655
Simulation failed at 1x (1,380 KB/s)
8:26:34 PM #50 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=5.3.1.158, size=23420 bytes, created 16/06/2003 12:37:31 AM
File 'Drivers\viadsk.sys': Ver=3.1.1, size=49644 bytes, created 16/11/2000 2:31:00 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
