Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > very little, yet very annoying problem
Forum Windows XP : Windows XP General Discussion - very little, yet very annoying problem
hi guys
when i change the 'colour correction' settings everything works fine and does what i want, then when i restart the settings are ok for about 10 seconds, then they change back to the default settings for no apparent reason, i make sure the box is ticked which says 'automatically apply settings at startup' and i save the settings, but it still resets itself.
aaaahhhhh, its so annoying!!!!!!!!!
help!!!!!!
thanks
I need a 1.5 Ghz Athlon + 512mb ddr ram to write emails......honestly
Sponsored Links
Under advanced, check change settings without restarting. See what happens then.
Reply to shybull
There are 1432 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
