Tom's Hardware > Forum > Audio > Pro Audio > Tape rewind effect, help
Forum Audio : Pro Audio - Tape rewind effect, help
Archived from groups: rec.audio.pro (More info?)
Anyone know how to make that effect (like rewinding a tape or
backspinning a record on a turntable)? I need it to gradually speeds up
at the beginning and slows down at the end). I own Cubase SX2.
thanks
Sponsored Links
> thanks
Use the Cubase offline pitch shifter effect in graphical mode.
Turn off length compensation.
Set the range to +-15 semitones.
Draw in a curve or whatever.
Hit process.
I guess for a backspin you'd have to reverse the file first.
Reply to Anonymous
> thanks
If you're using ProTools, flip the file in reverse,
speed it up about 4x normal speed and use the Vari-Fi
plug in to speed up / slow down the ends.
John Noll
Retromedia Sound Studios
Red Bank, NJ
jn145_deletethisfirst_@verizon.net
http://www.retromedia.net
Reply to Anonymous
Any way to do this in Peak or Digital Performer?
Reply to Anonymous
Just to clarify the question: Are you looking for simple
play-it-backward, or for the variable-speed effect as well (tape slowing
down, stopping, reversing, coming up to speed on rewind, slowing down
and stopping again, then coming back up to speed forward)?
The former's easy to do in most DAWs. The latter's less common, though
it isn't complicated programming.
Reply to Anonymous
Have you considered the simple expedient of butchering a redundant
cassette recorder - after all, you probably won't want the highest
fidelity for this effect.
~ Adrian Tuddenham ~
(Remove the ".invalid"s and add ".co.uk" to reply)
www.poppyrecords.co.uk
Reply to Anonymous
There are 1291 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
