Tom's Hardware > Forum > Audio > Pro Audio > Help with audio install.
Forum Audio : Pro Audio - Help with audio install.
Archived from groups: rec.audio.pro (More info?)
I would like someone to offer suggestions on the idea. I have the
automotive know how, but have not really delt with that much with audio
modification.
I am planning to install a 5 channel amp and 10" sub in the parcel
holder behind the seats on my 1987 300zx. There is a recess with a
hinged carpeted panel over it. It measures "roughly" 4 feet wide and
12" deep.
I plan on lining the body cavity with body undercoating to reduce
distortion and laying a piece of plywood across the opening with
eurolastimer sealer to seal the gaps. I will cut out the hole behind
the pass. side and mount the amp on the outside of the plywood in the
center (between the seats). That way at a later date I have the
possibility to add a second sub behind the driver. This way I can use
the carpeted cover to hide any signs of the setup. I will attach snaps
of somekind to keep the panel from vibrating.
I know amp sound/deepness depends on the amount of air behind the
speaker, should I split the void between the seats to make two seperate
pockets or leave it as one space?
Mark.
Sponsored Links
"imlosthere" <imlosthere@excite.com> wrote in message
news:1123986301.805200.184710@o13g2000cwo.googlegroups.com...
> modification.
> 12" deep.
> Mark.
got any room left for the mixer, fx rack, and digital workstation?
Reply to Anonymous
There are 1149 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
