Archived from groups: rec.audio.pro (More info?)
I've been using the MotU 896 to make sound recordings for about a year, but
I've always listened to the final output on CD/DVD, not off the MotU itself.
However, recently I connected the outputs of the MotU 896 to our mixing
board and have noticed that it's output is substantially noisier than other
devices like computer sound cards and synths.
The mic preamps are phenomenally quiet, but the playback output amps are
phenomenally noisy. How can this be? Has anyone else noticed this anomaly? I
don't particularly worry about it, since my clients aren't listening to the
output of the MotU, but to the recordings made with the MotU. For that, it's
very much noiseless. But I was rather shocked and surprised that the D/A >
playback amplifier circuits are this noisy. Probably not much better than
65dB, unweighted.
Anyone else find that their MotU playback jacks are a little noisy? Probably
nice and quiet on the AES/EBU outs, but I haven't tried them yet.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
Have you noticed a drop in level also?? Is it only noisy?
"ivis" <ivan40@comcast.net> wrote in message
news:1124241046.539261.320280@z14g2000cwz.googlegroups.com...
The level seems fine. It's only noisy. Rather surprising, since the input
mic preamps are incredibly free of noise. One would think the quality would
be consistent, input to output.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
Mark & Mary Ann Weiss wrote:
*snip*
*snip*
Absolutely not. I've regularly rigged up the inputs and outputs like a
patch bay so i can use hardware as inserts in Cubase. That would certain
be the litmus test to see whether the signal being sent out is returned
noisier than how it left. This is not the case, the original is idential
to the newly bounced/effected signal.
Have you tested all of the analog outputs on the motu? or just the main
outs? I had a problem with an 896 right out of the box where the left
channel was noisy (white noise masking the sound), and the right channel
was much quieter and even noisier. I returned it for a brand new one.
That my only encounter with a noise related issue and that was an out of
box factory defect.
Roach
> *snip*
>> Probably
> *snip*
> box factory defect.
> Roach
I really like the 896, but in my experience it hasn't been the most
reliable box. I'd get it checked by MOTU. I had to get the inputs of
mine fixed...
> box factory defect.
> Roach
I just moved the XLR connectors around to various outputs, not just the
stereo main outs... the hiss is the same on ALL outputs. Considerably
noisier than my Turtle Beach PC sound card and a lot noisier than my
synthesizers.
I threw this question to MotU tech support, but have not received a reply in
three weeks.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
> mine fixed...
The inputs on mine are great. I have no issues there. I can live with the
noisy outputs, since I'm not mastering off of them (analog), but it does irk
me that a $49 PC sound card is much quieter than this $1249 unit.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
"Mark & Mary Ann Weiss" <mweissX294@earthlink.net> wrote in
message
news:q7eOe.1147$I93.356@newsread2.news.atl.earthlink.net
> outputs, not just the stereo main outs... the hiss is the
> same on ALL outputs. Considerably noisier than my Turtle
> synthesizers.
Not a fair comparison. The maximum undistorted output of a
typical consumer sound card is 1.0 volts, per the AC97 spec,
Most audio production audio interfaces have maximum
undistorted outputs in the 3-6 volt range. Therefore their
residual noise can be 10-16 dB greater, and they will still
have the same or greater dynamic range.
What happens when you try to run the RMAA 5.5 audio
benchmark program on your Motu? It's a free download from
http://audio.rightmark.org/download.shtml
In article <q7eOe.1147$I93.356@newsread2.news.atl.earthlink.net> mweissX294@earthlink.net writes:
> synthesizers.
Have you measured signal-to-noise? How much signal do you get out for
a full scale digital recording? Maybe all you need to do is turn your
playback gain down about 20 dB. Sorry if this is too obvious, but I
just pop in and out of this thread and I don't know how much more you
know (or don't) about the gain staging.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
I realize that, which is why I also compared against my Kurzweil K2600RS
rack sampler's balanced TRS outs. The Kurzweil is almost 20dB quieter.
And the fact that I have a temporary unbalanced cable connecting the MotU to
the mixer, it should be -6dB with reference to the Kurzweil, if the noise
levels are the same in both systems.
This is a very interesting and useful test program. First of all, thanks for
bringing it to my attention. I wish I had found this last December when I
was aligning our house sound system with a new crossover loudspeaker
management system. It would have made the process much quicker.
Now about the test, I did a loopback with 25' ProCo microphone cables from
the stereo outputs to the 7-8 channel inputs.
The test graph shows most of the noise to be in the -128dB range with a few
spikes pushing toward -100dB.
I find the numbers hard to believe because this is measuring input to output
s/n ratio and this unit is audibly noisier than the Kurzweil, also a
balanced XLR output that can swing about 10V RMS undistorted.
Given that all the inputs to the board have the same gain structure, it
would suggest that the MotU is producing more quiescent noise than the
Kurzweil.
To be sure it wasn't a difference in input gain, I used input 1 on the board
and did the following:
With K2600RS plugged in, potted 1 up to max (+10dB setting). A barely
audible hiss was present.
Potted back to 0dB and plugged the MotU into that input. More hiss was
audible at 0dB than with the Kurzweil at +10db. When this input was potted
up to +10dB, the hiss was very loud.
So here we have two devices, both have balanced outs, but both are connected
via unbalanced cables (until we have the budget to get some new balanced
cables) connecting them to the board. One device is about 20dB noisier than
the other.
This test software is telling me that over most of the frequency range, the
s/n is about 128dB. If that were so, then I guess the Kurzweil would measure
148dB or so on s/n, but I don't know of any op-amps in existence today that
approach 148dB s/n ratio.
I doubt that the MotU can produce more voltage swing than that Kurzweil, as
both have similar output devices and voltage rail potentials.
Interestingly, the Kurzweil measures -72dB unweighted on my H/P 400E AC
Voltmeter, across pins 2 & 3 of the output.
The MotU measures -54dB across pins 2 & 3.
Yet the test software claims miraculous results. I'm having trouble
reconciling these results.
How can the MotU be that much noisier, yet post such astonishing test data?
We have everything trimmed on the board so that a 0dB "maximum" recording
level produces a uniform level from all devices with the board faders at
0dB. Some devices are just much noisier, and that's what prompted this
inquiry.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
message
news:SIvOe.628$FW1.224@newsread3.news.atl.earthlink.net
>> a typical consumer sound card is 1.0 volts, per the AC97
>> spec,
> Kurzweil K2600RS rack sampler's balanced TRS outs. The
The Kurzweil may have a muting circuit.
The Kurzweil may have an analog-domain gain control with an
exceptional lot of dynamic range.
>> their residual noise can be 10-16 dB greater, and they
>> will still have the same or greater dynamic range.
>> from
> of all, thanks for bringing it to my attention. I wish I
> had found this last December when I was aligning our
> quicker.
20-20 hindsight. BTW I find the loudspeaker testing facility
to be very useful for live sound.
> microphone cables from the stereo outputs to the 7-8
> channel inputs.
> -128dB range with a few spikes pushing toward -100dB.
That is characteristic of all but the very best audio
interfaces. It's better than an Audiophile 24/96, more like
a Card Deluxe or Audiophile 24/192, but short of a LynxTWO.
> measuring input to output s/n ratio and this unit is
> audibly noisier than the Kurzweil, also a balanced XLR
Like I said the Kurweil may be a little more complex than
just a sound card which is typically a DAC chip driving a
buffer amp that is hooke directly to the output terminals.
> structure, it would suggest that the MotU is producing
> more quiescent noise than the Kurzweil.
Agreed. BTW, you can look at the output of the Kurzweil
using the FFT analysis feature of RMA55
> input 1 on the board and did the following:
> setting). A barely audible hiss was present.
There still might be a muting circuit in the Kurzweil.
> More hiss was audible at 0dB than with the Kurzweil at
> +10db. When this input was potted up to +10dB, the hiss
> was very loud.
> both are connected via unbalanced cables (until we have
> the budget to get some new balanced cables) connecting
> the other.
But, they are very different devices. The MOTU is performing
about the way I would expect a device like it to perform. It
costs like a LynxTWO but it has a ton more channels.
> frequency range, the s/n is about 128dB.
Is that the numeric number reported by RMA55?
> If that were so,
> then I guess the Kurzweil would measure 148dB or so on
> that approach 148dB s/n ratio.
I suspect that the Kurzweil is more complex than the MOTU.
> that Kurzweil, as both have similar output devices and
I don't know if the MOTU can put out 10 volts at digital FS.
Got a DVM?
> my H/P 400E AC Voltmeter, across pins 2 & 3 of the output.
That's wideband noise. Noise measurements are only proper
if done over a stated bandwidth, like 20Hz-20 KHz.
So, its 18 dB noisier in this questionable but somehow
indicative broadband noise test.
> having trouble reconciling these results.
I think I need to see some numbers from RMA55.
> "maximum" recording level produces a uniform level from
> all devices with the board faders at 0dB. Some devices
> inquiry.
Well, some devices *are* noisier than others. Got any mics?
In article <q7eOe.1147$I93.356@newsread2.news.atl.earthlink.net>,
> synthesizers.
> reply in
> three weeks.
Have you tried calling them? I see none of these problems on my MOTU896HD,
and I strongly suspect yours is broken. It seems a shame that you're
wasting so much time and energy on it.
In article <SIvOe.628$FW1.224@newsread3.news.atl.earthlink.net> mweissX294@earthlink.net writes:
I can't help but think that you're seeing some of the input coming out
the output of the MOTU. What voltage do you read out of it if you
connect a shorted plug to the input of the channel you're reading?
I strongly doubt the presence of a muting circuit. I would hear a 'gating'
effect on soft passages if that were the case. In fact, I consider the
Kurzweil to be noisy, compared to my Denon CD player. The Denon's output
noise playing a test CD with all digital 0's is below the noise floor of my
mixer (the noise is inaudible with the mixer fader at +10dB and the monitor
volume at 10 o'clock where I have it for the other tests. If I max out the
monitor volume, then the noise level is barely different with the CD player
connected or not connected.
A group of musicians who use Kurzweil K series samplers have also raised the
issue about the hiss. We don't consider that a $7995 sampler should be
noisier than a $350 CD player as being reasonable for the money. And along
comes the MotU, and it's 18dB noisier still. No, the Kurzweil definately
does not mute. If it did, we wouldn't hear any hiss on it's outputs.
> > quicker.
It does have issues with the 24/96 mode though. I can't get it to calibrate
at all. Works okay in 16/44.1 mode.
Did some measurements on the house sound system and got some odd results: no
matter where I placed the mics, the response curve was the same--even if I
moved them from center between the array to a few inches from a subwoofer.
The latter position should have showed a radical roll off after 130hz, but
it didn't. In fact, I could hardly tell the two curves apart from the
wideband test over the whole frequency range.
When I test with white noise, and an FFT analyzer, mic placement makes very
obvious differences in response curve.
The inputs were certainly quiet enough, but I don't believe these numbers,
since they include the output + input noise combined. My only complaint was
the -.6dB rolloff at 20KHz, increasing to -3.6dB at 40KHz. But since I can't
hear anything up there, it's not much of an issue.
The Kurzweil has ten outputs channels in 5 groups. 1 group is Mix outputs
and they are noisier by almost ten dB. The individual bus outputs are the
quietest, but I suspect these are direct off the DACs, whereas the Mix have
an additional mixer stage. But I do not consider the Kurzweil to be quiet.
My Denon CD player is much quieter than this.
I suppose I could. I'll have to fashion a test setup. Of course, it will
involve the MotU, but I trust the input stages at least.
Strongly doubt it. It's too noisy to have a muting circuit and I don't hear
any evidence of it coming out of a muted condition when signal is ramped up.
> > was very loud.
> > the other.
I will have to do more experiments, using normalized audio to max out the
MotU output levels and do some listening tests.
That is the graph chart I was describing.
This is the text output:
Frequency response (from 40 Hz to 15 kHz), dB: +0.05, -0.45 Good
Noise level, dB (A): -103.0 Excellent
Dynamic range, dB (A): 103.0 Excellent
THD, %: 0.0008 Excellent
IMD + Noise, %: 0.0035 Excellent
Stereo crosstalk, dB: -100.7 Excellent
IMD at 10 kHz, %: 0.0037 Excellent
> > If that were so,
Not from the output stage, but from the fact that it is much more than a
DAC, being a sampler, synth, ROM playback device with sophisticated control
capability, but no, the output configuration, aside from having ten
channels, is pretty conventional.
> Got a DVM?
I have an RMS voltmeter. Only challenge is getting a sine tone out of the
Kurz. I think there is a diagnostic mode that does this, but I have to dump
all my sample memory (requires reset) to get to it and I don't want to do
that right now.
If you figure the rail voltage of +/- 15VDC, the op amps will typically
swing +/- 13.5 and .707 of that is 9.54 vrms.
Yes, but as a relative test, it confirms what my ears tell me. I guestimated
close to 20dB noiser than the K2600RS. The meter told me it was 18dB
noisier.
Relative comparison, backing up what I heard.
Well now you've got them.
> > inquiry.
Yeah, but there isn't an acoustic space quiet enough to reveal the self
noise in the mics or the MotU preamps.
I can only verify that by digitally normalizing the recording. Failing to do
that, and relying on the MotU output stage gain, boosting the level in the
analog domain only brings up a lot of hiss. But in the digital domain,
normalizing a recording whose peak level was -54dB to 0dB in SoundForge,
results in pickup of a lot of ambient noise, but still no audible hiss.
That's why I find the MotU outputs to be noisy. Relative to the inputs +
mics, that is.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
Doesn't matter if the inputs are turned all the way down. In fact, for my
test, the inputs were muted. Monitor mode is only invoked when recording
software is running and in record mode. But during this test, nothing
connected to the inputs was heard on the outputs.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
I finally did get a response via e-mail. However, they want to register the
unit and require a sales receipt before they'll issue and RMA. I don't
consider the issue to be one that warrants sending the unit out (although
the $45 flat repair fee is incredibly reasonable), only to be told that
there is nothing wrong with it. The RightMark Audio Analyzer's spectrum
graph shows that the total loop output to input s/n ratio is about 128dB
over most of the frequency range, with a few spikes dipping toward 100dB. If
MotU uses a similar test, then they will say that it's meeting specs.
I'm trying to understand why it's so much noisier than any other piece of
equipment in this studio, when all devices have been trimmed in the mixing
desk for 0dB with digital full scale signals.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
Well this is interesting...
I generated a 0dB sine wave in SoundForge and output it to the MotU channels
1-2. The MotU meters are registering -6dB, not even -1dB, the last segment
before [overload]. So the Analog Outs are not even being driven to full
output. Very curious indeed.... now wondering if these meters respond the
same as a broadcast transmitter modulation monitor, that being, you can
never get 100% modulation with a sinusoidal wave...
Nope... just tried a square wave and got the same -6dB reading on the Analog
Out meters.
Quite a mystery.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
channels
Analog
> Out meters.
> Quite a mystery.
One mystery is solved:
I did some poking around in Windows and found that I could use the Volume
Control app to go to advanced properties and select something other than the
internal PC sound card, so I selected each of the MotU outputs and set the
volume from halfway to maximum.
This gives me 6dB more output, so now it's 6dB hotter than the Turtle Beach
card (as trimmed on the board), but it still has higher hiss levels overall.
6dB is a long way from where things need to be.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
message
news:twPOe.989$FW1.539@newsread3.news.atl.earthlink.net
>> an exceptional lot of dynamic range.
> would hear a 'gating' effect on soft passages if that
> were the case. In fact, I consider the Kurzweil to be
> noise floor of my mixer (the noise is inaudible with the
> mixer fader at +10dB and the monitor volume at 10 o'clock
> with the CD player connected or not connected.
> have also raised the issue about the hiss. We don't
> consider that a $7995 sampler should be noisier than a
> along comes the MotU, and it's 18dB noisier still. No,
> the Kurzweil definately does not mute. If it did, we
>>> First of all, thanks for bringing it to my attention. I
>>> wish I had found this last December when I was aligning
>>> quicker.
>> facility to be very useful for live sound.
> get it to calibrate at all. Works okay in 16/44.1 mode.
> some odd results: no matter where I placed the mics, the
> response curve was the same--even if I moved them from
> subwoofer. The latter position should have showed a
> radical roll off after 130hz, but it didn't. In fact, I
> could hardly tell the two curves apart from the wideband
> placement makes very obvious differences in response
> curve.
Thats not how it has worked for me.
>> like a Card Deluxe or Audiophile 24/192, but short of a
>> LynxTWO.
> believe these numbers, since they include the output +
Right, but if the input is *that* (i.e., > 10 dB) much more
quiet, then its contribution to the output noise numbers is
close to zip.
> My only complaint was the -.6dB
> since I can't hear anything up there, it's not much of an
> issue.
Agreed. This looks like a typical 24/96 curve.
>> terminals.
> group is Mix outputs and they are noisier by almost ten
> dB.
Consistent with being the sum of 5 other things, each
contributing a bit of noise.
>The individual bus outputs are the quietest, but I
> have an additional mixer stage. But I do not consider the
> Kurzweil to be quiet. My Denon CD player is much quieter
> than this.
A CD player can't have more than about 98 dB dynamic range -
that comes with the 16 bits. It can mute and be quieter, and
indeed most do. But that isn't really the same as having
more dynamic range for playing music.
> course, it will involve the MotU, but I trust the input
> stages at least.
> circuit and I don't hear any evidence of it coming out of
I'm thinking of a muting circuit that knows when there is no
signal. Any signal, and its off.
>>> was very loud.
>>> but both are connected via unbalanced cables (until we
>>> have the budget to get some new balanced cables)
>>> noisier than the other.
>> performing about the way I would expect a device like it
>> to perform. It costs like a LynxTWO but it has a ton
>> more channels.
> audio to max out the MotU output levels and do some
> listening tests.
I'm quite sure that if you set levels with music playing
just below clipping, and then remove the music, you aren't
going to hear any hiss from the MOTU unless you do something
crazy like put your ear next to the speaker.
No, its telling you that the noise in each FFT bucket
is -128 dB. Sum them all up over a reasonable range to get
the true noise level.
> +0.05, -0.45 Good Noise level, dB (A): -103.0
> Excellent Dynamic range, dB (A): 103.0 Excellent
Looks fine to me.
>>> If that were so,
>> MOTU.
> much more than a DAC, being a sampler, synth, ROM
> playback device with sophisticated control capability,
I'll be confident of what it really has inside when I see a
schematic (which I expect never to see!) ;-)
>>> than that Kurzweil, as both have similar output devices
>> FS. Got a DVM?
> tone out of the Kurz. I think there is a diagnostic mode
> that does this, but I have to dump all my sample memory
> (requires reset) to get to it and I don't want to do that
> right now.
> will typically swing +/- 13.5 and .707 of that is 9.54
> vrms.
Right, about +22 dBm
>>> output.
>> proper if done over a stated bandwidth, like 20Hz-20 KHz.
> tell me. I guestimated close to 20dB noiser than the
> K2600RS. The meter told me it was 18dB noisier.
You lucked out.
They show relatively good performance for a mid-priced audio
interface.
>>> inquiry.
> mics? ;-)
> reveal the self noise in the mics or the MotU preamps.
Exactly.
> recording. Failing to do that, and relying on the MotU
> output stage gain, boosting the level in the analog
> domain, normalizing a recording whose peak level was
> -54dB to 0dB in SoundForge, results in pickup of a lot of
> ambient noise, but still no audible hiss. That's why I
> + mics, that is.
I doubt that will be true in an apples-to-apples comparison.
One thing about the MOTU inputs which must have gain
controls if they have mic preamps. What are the input gain
controls set to?
> Best Regards,
> Mark A. Weiss, P.E.
> www.mwcomms.com
Hmmmm
I would just send it in. Get it looked at for $45. If it comes back and
they say "no, that's how it is", put it on ebay and get something which
doesn't bug you so much.
If it comes back and there was a problem, it will be solved.
In article <dOPOe.940$_84.354@newsread1.news.atl.earthlink.net> mweissX294@earthlink.net writes:
This may be only a difference in interpretation of how 0 dBFS is
calibrated. I think the that current version of the definition is that
the meters should read 0 when the peak of a sine wave is at full
scale, but the meters may be indicating something else. If they read
-3, that would be easier to explain. Maybe Sound Forge and MOTU are
each compensating in the same direction.
> Out meters.
OK, so they're reading the average value of a square wave. It must
have something to do with the response time.
But the real question is, with your monitor gain set to its normal
position and with that FS 1 kHz tone playing, did you blow out your
speakers? Could you stay in the same room?
How many analog volts come out when playing the FS tone?
"Mark & Mary Ann Weiss" <mweissX294@earthlink.net> wrote in message
news
OPOe.940$_84.354@newsread1.news.atl.earthlink.net...
> channels
> Analog
> Out meters.
> Quite a mystery.
> Best Regards,
> Mark A. Weiss, P.E.
> www.mwcomms.com
Are the Motu meters properly calibrated?
Mikey
Nova Music Productions
> Hmmmm
It is tempting to send it in, but since the hiss is on the playback end and
doesn't appear on the SACDs that I produce, it's not a serious issue. It's
more of a curiousity than anything else as to why a piece of gear with such
emphasis on quiet preamps would have so much noisier output amps.
Given the results that RightMark analyzer reported, I suppose I have to
conclude that there is nothing wrong with the unit.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
> Mikey
I believe so. Why? Because, after discovering a volume control app in
Windows that could be set to control the MotU outputs and setting it to full
scale, the meters now display full scale with a 0dB digital sine wave from
SoundForge. So I am satisfied that the output level is correct.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
message
news:ly8Pe.1654$_84.1535@newsread1.news.atl.earthlink.net
>> Mikey
> control app in Windows that could be set to control the
> MotU outputs and setting it to full scale, the meters now
> correct.
What effect does this change have on the observed signal and
noise measurements, both with the meter and also with RMA55?
channels
segment
Nope. It's a senseless design flaw in Windows which causes the MotU output
levels on all 8 channels to default to -6dB, requiring that I open the
Control Panel, click on sound devices and select each pair of MotU channels,
one at a time, and open the Volume Control app for each pair and set the
volume from half back to maximum. Then it outputs 0dB.
Analog
> > Out meters.
Nope. I have the studio monitors turned WAY down, for it is like the whine
of a 50HP siren if they are up too loud. I read the levels on the board.
Musically speaking, I CAN hear hiss when the house system is set to a level
where, let's say, rock music peaks at 118dB at listener position. I'd
estimate the hiss is producing an SPL of 25dB under those conditions.
Under this condition, the RMS voltmeter reads:
+18dB
6.25vrms
Incidentally, my K2600RS reads:
+21dB
8.7vrms
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
message
news:gVdPe.1585$FW1.184@newsread3.news.atl.earthlink.net
> causes the MotU output levels on all 8 channels to
> default to -6dB, requiring that I open the Control Panel,
> channels, one at a time, and open the Volume Control app
> for each pair and set the volume from half back to
The default settings for the windows volume control are set
by the device driver installation process. IOW, blame MOTU.
>>> reading on the Analog Out meters.
>> wave. It must have something to do with the response
>> time.
>> its normal position and with that FS 1 kHz tone playing,
>> did you blow out your speakers? Could you stay in the
>> same room?
> is like the whine of a 50HP siren if they are up too
> loud. I read the levels on the board. Musically speaking,
> position. I'd estimate the hiss is producing an SPL of
If you hear a 25 dB SPL noise in a room, that's really a
pretty fine room.
I suspect that reality might be a bit more like the 30s.
93 dB dynamic range which is what your example works out to,
is really pretty fair dynamic range for an audio interface.
I suspect that now that you found another 6 dB of output,
you'll be back to the 98 dB dynamic range that RMAA found.
If you want appreciably better dynamic range, rip out that
MOTU and put in a pair of LynxTWOs. They will cost you
almost $2k, but they will be quieter. They slave together
very nicely to provide 8 channels.
> +18dB
> 6.25vrms
Very typical for a audio production computer audio
interface.
> +21dB 8.7vrms
Pretty typical, as well.
I'll have to register a software update request/feature change with them, if
that's the case. I shouldn't have to set the levels every time I turn on the
audio interface. They should remain where I left them last session.
> pretty fine room.
We're in rural country. With the computers off, all you hear is the blood
rushing through your eardrums. It is DEAD quiet in here. Our custom-built
10kW sound system has a dynamic range better than 130dB and even the 17dB
hum/hiss from the amplifiers is audible, if within 3' of the array. Not bad
though, for a system capable of 800 acoustical watts. We spent a lot of time
last winter, tuning it for quietest noise floor through gain staging and
redressing of wiring (using a mic planted in front of each driver, one at a
time, driving a headphone amp and listening on headphones to the noise
floor, amplified so that one could hear changes as adjustments were made to
the wiring.) Prior to that, for the longest time, the system emitted a 40dB
hum.
What I find curious then is why my Denon CD player is quieter *with my
recordings* when I play it from the CD. It seems that when I need to hear
the cleanest reproduction, I have to burn a CD and go play it in the Denon.
Same SPL with music, but no hiss during quiet passages, for instance, when
the conductor raises his baton, just a second before the orchestra plays the
first note is often the quietest point in my recordings. Played on the MotU,
there's a small amount of hiss audible. Take the digital file, transfer to a
CD and play on the Denon and it's all there, but without the hiss. Same SPL
at crescendo levels. Very odd indeed.
It's not worth it, since we only care about the record side. The playback
side is more of a curiousity, rather than a problem that we can't deal with.
Since it does what we need with a laptop PC in the field, it's getting a
fine job done. It was only recently that we even bothered to hook the MotU
outputs up to our mixing desk. And that's when everyone said "hey, this box
is noisy!"
> > +18dB
> > 6.25vrms
> interface.
> > +21dB 8.7vrms
I used to design broadcast equipment whose audio would swing 12vrms. It
seems that these devices are running at a much lower rail voltage than I
estimated, or they are not making use of the full dynamic range of the
op-amps employed.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
message
news
xuPe.2091$_84.95@newsread1.news.atl.earthlink.net
>> set by the device driver installation process. IOW,
>> blame MOTU.
> change with them, if that's the case. I shouldn't have to
> set the levels every time I turn on the audio interface.
Agreed. The usual deal is to remember the last settings.
Agreed.
>>> to a level where, let's say, rock music peaks at 118dB
>>> at listener position. I'd estimate the hiss is
>> pretty fine room.
> hear is the blood rushing through your eardrums. It is
> DEAD quiet in here.
Lucky you.
> Our custom-built 10kW sound system
> the array.
Well that's really wonderful, but with such a remarkable
tool, you still have to fit in with the rest of the world.
> Not bad though, for a system capable of 800
> acoustical watts. We spent a lot of time last winter,
> and redressing of wiring (using a mic planted in front of
> each driver, one at a time, driving a headphone amp and
> listening on headphones to the noise floor, amplified so
> system emitted a 40dB hum.
Ironically, 40 dB of hum in a system that is capable of 130
dB is 90 dB dynamic range which is generally really pretty
good.
>> to, is really pretty fair dynamic range for an audio
>> interface. I suspect that now that you found another 6
>> dB of output, you'll be back to the 98 dB dynamic range
>> that RMAA found.
> quieter *with my recordings* when I play it from the CD.
The laws of physics say that 16 bits can't do much more than
96-98 dB dynamic range, and on a good day a decent 24 bit
audio interface should be able to do that.
> It seems that when I need to hear the cleanest
> Denon. Same SPL with music, but no hiss during quiet
> passages, for instance, when the conductor raises his
> baton, just a second before the orchestra plays the first
> on the MotU, there's a small amount of hiss audible. Take
> the digital file, transfer to a CD and play on the Denon
> and it's all there, but without the hiss. Same SPL at
I think you need to look at gain staging from the MOTU. Like
I said, we just found a *free* 6 dB worth of dynamic range
in the windows mixerf, and there might more lying around,
hiding some place.
>> that MOTU and put in a pair of LynxTWOs. They will cost
>> you almost $2k, but they will be quieter. They slave
>> together very nicely to provide 8 channels.
> side.
Thatr begs the question why all the worrying about the Motu?
Obviously you care about it, at least a little.
>The playback side is more of a curiousity, rather
> than a problem that we can't deal with. Since it does
> a fine job done. It was only recently that we even
> bothered to hook the MotU outputs up to our mixing desk.
> And that's when everyone said "hey, this box is noisy!"
>>>> tone?
>>> +18dB
>>> 6.25vrms
>> interface.
>>> +21dB 8.7vrms
> swing 12vrms. It seems that these devices are running at
> a much lower rail voltage than I estimated, or they are
> not making use of the full dynamic range of the op-amps
> employed.
I think you already did the math for +15/-15 power supplies.
Most op amps are ok with +18/-18, and the OPA604 and 2604
are rated for more like +/- 24.
However, maximum outputs in the 6-7 volt range are pretty
typical for computer audio interfaces.
>op-amps employed.
Sadly this is typical today. Everyone is obsessed with lower rail voltages,
lower power consumption, and going to unipolar supplies to save power supply
costs.
My console, on the other hand, can swing more than 70V output, from the
+/-48V rails.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
> > correct.
Didn't retest RMA55, but if that test suite doesn't have control of the
volume (override), then maybe I should retest with that program and see if
the results increase by 6dB.
It has no effect on the static noise level at the outputs however, as
measured with a H/P 400E.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
> Agreed.
Since that is what every other sound device I have in our DAWs
does--remember the settings.
> > DEAD quiet in here.
> Lucky you.
No. A matter of choice. It was initially cheaper to come out here 40 years
ago.
> > the array.
That's another reason why we're out here, and not someplace with neighbors.
They don't call me "Bass Pig for nothing. :-)
> good.
Yes, the numbers look good, but when you're trying to listen to a soft
pianissimo passage in, say, Stravinsky's Firebird Suite, that hum and hiss
are pretty distracting.
> >> that RMAA found.
I'm fully aware of these laws, and that's why I find it a matter of academic
curiousity why my 24-bit interface generates so much more noise than my
16-bit Denon CD player.
> hiding some place.
Things have gotten better with the additional 6dB, but I am hard--pressed to
find any remaining unused dynamic range. Any thoughts or suggestions would
be welcome.
> > side.
Academic curiousity. When you buy a somewhat expensive audio interface and
go a year without ever critically listening to it's output (because you hear
the results only through other audio playback D/A systems, and one day you
connect it to your board and notice that it has about 20dB more hiss but is
not 20dB louder than your other devices on competing channels, you kinda'
wonder about that..
> > employed.
And PC sound cards max out at less than 2vrms.
If the hiss were proportionately smaller, the s/n ratio should remain
reasonably good.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
> >op-amps employed.
voltages,
supply
> costs.
> +/-48V rails.
> --scott
You mean this is all because of the 'green' movement?
It seems a small thing to ask of MotU, whose main power is consumed by the
digital electronics, not the op amps.
Best Regards,
Mark A. Weiss, P.E.
www.mwcomms.com
message
news:qPsQe.3548$9i4.608@newsread2.news.atl.earthlink.net
>>>> out to, is really pretty fair dynamic range for an
>>>> audio interface. I suspect that now that you found
>>>> another 6 dB of output, you'll be back to the 98 dB
Compared to the Motu, its maximum output is more like 2
volts than 7. That is another approx 10 dB differnce.
>> than 96-98 dB dynamic range, and on a good day a decent
>> 24 bit audio interface should be able to do that.
> matter of academic curiousity why my 24-bit interface
> generates so much more noise than my 16-bit Denon CD
> player.
It looks to me like the Motu isn't enough better than the
Denon in terms of actual dynamic range, to overcome the
approx 10 dB difference in maximum output.
>> supplies. Most op amps are ok with +18/-18, and the
>> OPA604 and 2604 are rated for more like +/- 24.
> should remain reasonably good.
It isn't. IME the very best consumer sound cards (example
M-Audio Revolution 7.1) have a little worse dynamic range
than the Motu.
message
news:mGsQe.3512$_84.1931@newsread1.news.atl.earthlink.net
>>> correct.
>> and noise measurements, both with the meter and also
>> with RMA55?
> control of the volume (override),
It doesn't.
> then maybe I should
> retest with that program and see if the results increase
> by 6dB.
Agreed.
> however, as measured with a H/P 400E.
That would be a good thing. This time we're trying to
improve dynamic range by increasing the maximum output.
I'm wondering if the .wav files you play through the Motu
have good, high peak levels (i.e., within a dB or so of FS)
There are 1188 identified and unidentified users. To see the list of identified users, Click here.
