Hi,
My monitor screen started freezing lately. All of a sudden it would not respond to mouse or keyboard commands and would not respond to Ctrl + Alt + Del either. I had to pull the plug and restart it. It would then work for a little while or sometimes freeze immediately after starting.
I am no computer expert so I thought it was my OS and I was thinking about reinstalling Windows. I have a P III 500 Compaq Presario dual boot system with Win 98 SE and Win XP (Pro) on a 40 GB hard drive with 5 partitions and 192 MB ( 128 + 64 MB ) RAM. I called a local service centre and they suggested it might be a hardware problem rather than software and I should leave the system with them for a day and then they would tell me what the problem is. I then asked a friend and he thought it could be RAM so I took out the extra module of 128 MB that I had purchased from a local store and the system hasn’t frozen at least for the day while running Win 98. Obviously I couldn’t run even a Word application in XP. I put that RAM back again and tried to run XP and it started freezing again.
I bought 128 MB RAM about 18 months ago.
My question is :
Is it just the RAM and should I go out and get more RAM or there could be something else too?
Does RAM go out so quickly? I did take Precautions about static.
Could installing some software damage the RAM?
Could virus damage RAM?
Could virus damage motherboard or any other hardware?
I recently installed Cd burning software Easy Cd & DVD creator by Roxio which is about 800 MB. I was able to burn first couple of CDs successfully but now when I try to burn web pages it does not burn Graphics, only text and I am not able to solve that puzzle but only clue that I am getting is that every time I try to open a web page from recently burned cd it gives a message in taskbar “ Opening Page file” or “downloading picture” then I wait but nothing happens. Is RAM the culprit for this problem too?
Win 98 SE says don’t flirt with page file and let Windows manage it where as Win XP shows 288 MB of its partition for page file and none for 3 other data partitions. Should I allocate some hard disk space for page file for each partition? In XP I did try to raise it to 800 MB for OS partition but that didn’t help burning the Cd, may be due to Bad RAM again?
I would really appreciate any suggestions.
Thanks,
Greg
My question is :
Thanks,
Greg
