jwilliams3@audioupgrades.com wrote:
> Use 2 power one 24 volt supplies. Tweak up the voltage adjust to about
> 28 volts. Reverse the one feeding the negative supply.
> Jim Williams
> Audio Upgrades
Thanks Jim,
I thought of trying something like that. I have a Lambda
28 VDC supply and could get another.
My concern is that there is a common ground connection
on the modules. Connections are Common, +28 and -28. If
the second PS is reversed with the - connected to the
-28, the + connection would connect to the common
ground? Wouldn't that create a problem having +28 VDC
connected to the common ground?
"John Noll" <jn145_deletethisfirst_@verizon.net> wrote in message
news:4304A077.6020003@verizon.net...
>> Jim Williams
>> Audio Upgrades
> Thanks Jim,
> I thought of trying something like that. I have a Lambda 28 VDC supply and
> could get another.
> My concern is that there is a common ground connection on the modules.
> Connections are Common, +28 and -28. If the second PS is reversed with
> the - connected to the -28, the + connection would connect to the common
> ground? Wouldn't that create a problem having +28 VDC connected to the
> common ground?
yes.. that's the problem with doing it this way. You can order a dual
supply from Power One.
Make sure each 28V DC supply is ground-free, ie floating. This is crucial.
If one side is pre-grounded in the PSU, there may be a removable link to
isolate it. When satisfied that they are floating, join -ve of one to +ve of
other to make the common (centre) rail. Anyway, the grounding ought to be
done as near the 0V in the audio circuitry as poss.
Jim
>> Jim Williams
>> Audio Upgrades
> Thanks Jim,
> could get another.
> common ground?
> John Noll
"nap" wrote ...
> "John Noll" wrote ...
>>> adjust to about 28 volts. Reverse the one feeding the negative
>>> supply.
>> the modules. Connections are Common, +28 and -28. If the
>> second PS is reversed with the - connected to the -28, the +
>> connection would connect to the common ground? Wouldn't
>> common ground?
> order a dual supply from Power One.
Except that most of those generic power supply modules
have floating outputs where NEITHER the positive nor
the negative are tied to ground. They are designed so that
you can use them with either side grounded. It is trivial
to check/confirm floating output with a $5 ohmmeter.
Power One was one of the first places I looked. They
have some 24V Dual supplys that can be trimmed up to 26V
but nothing in the 28 volt range as far as I can tell.
John Noll <jn145_deletethisfirst_@verizon.net> wrote:
>I'm have a hard time trying to find a +/- 28VDC power
>supply to power up some Quad Eight modules. I've tried
>Mauser, DigiKey, eBay, etc with no luck.
>Any suggestions? Thanks.
So get two +28V ones.
Or get some +24V ones and crank them up a little bit... most will go
a little bit higher and +26V is probably close enough for the job.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
news:43048FB2.1010005@verizon.net...
> I'm have a hard time trying to find a +/- 28VDC power supply to power up
> some Quad Eight modules. I've tried Mauser, DigiKey, eBay, etc with no
> luck.
> John Noll
You really need to know how much current those modules draw.
Or else just buy a big honkin' solution and "brute-force" it.
Here are a some suitable 24v supplies with floating outputs.
Two of them would make the bipolar supply you need....
Condor F24-12-A 24VDC @ 12A or 28V @ 10A (linear) $100
http://www.mpja.com/productview.asp?product=15698+PS This one is advertised as adjustable to 28V, but some of the
others may be also. OTOH, we don't know how critical it is
to run those particular modules at +/- 28V vs the more commonly
available +/- 24V
Note that this is a big honkin' and heavy unit and requires
some air flow when running anywhere near the maximumm
ratings (and remember you need two of them) But seems
unlikely that the modules will want even half the rated 10A
at 28V.
>> up some Quad Eight modules. I've tried Mauser, DigiKey, eBay, etc
>> with no luck.
> You really need to know how much current those modules draw. Or else
> Here are a some suitable 24v supplies with floating outputs. Two of them
snip....
Thanks to all for the insightful advice and links. I've
put together a pair of 28 VDC supplies with floating
grounds as suggested and i'm now getting the proper +/-
voltages.
As for the Quad Eight modules themselves (pair of CL22
compressors) - the schematics have no mention of
current draw so I'm "brute forcing it". Now if I could
just get them to function. I can't get them to compress.
The expand and output gain controls make the meter move
and there is working output gain adjustment, but no
actual compression or expansion. These units have dbx
202 VCA's and now I'm in the process of checking their
functionality by swapping in a known good one from a dbx
165a.
On Thu, 18 Aug 2005 13:44:39 GMT, John Noll
> Google accopian
It's Acopian with one c. That, Power One and Lambda
were the first places I looked. Off-the-shelf bi-polar
28 VDC supplies don't seem to exist. Nonetheless as I
mentioned in an earlier post, I used a pair of Lambda 28
singles with floating grounds as instructed by several
posters here. It's working fine now. I still come here
to learn a few things and often succeed with the help of
some of the those around here who are smarter than me.
After two days I sorted out the confusing pinouts and
the CL-22's are now ready to squeeze.
John Noll
Retromedia Sound Studios
Red Bank, NJ
