Sound Card
Hello,
I have a SoundMax Integratd Digital Audio, but it is very low when I use Windows Media Player. How ca I lleivate this poblem
2 answers Last reply
More about sound card
  1. check in windows to make sure your volume level is all the way up and also check the program if the volume is up in there (like on the youtube video too)
    you can also check in control panel and sound to see if there are any levels you can adjust to make it louder
  2. Do you have the SoundMax software installed?
    If the volume is max in the sound panel, try the Soundmax software and set that to max as well. Also you can try to uninstall the Soundmax software and re-install.
Configuration Audio Sound Cards Media Player Windows 7
