The Realm <bluesky@knology.net> wrote:
>I am looking into buying one of these stereo mics for drum OHs.
>I am wondering if anyone has heard a comparison of the two for this
>application and what your opinions are....i mostly do rock music...
I don't think I'd pick either. Why do you want this? Are you trying
to soften cymbal sounds?
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
I use the Royer SF-24 (the active stereo mic) on drums and I've used the
Royer 122's for overheads on many occasions. They give you a sound that is
definitely a "character" kind of sound. For some kits and styles of music,
you'll likely LOVE it. For others, not so much. I don't have much
experience with AEA's mics.
In any case, I'll often add a bit of top end to help the cymbal sound. They
are ultra-smooth mics and the top end is usually a bit lacking (as compared
to comparable quality condensers), but they can be fantastic microphones in
the right situation.
please remove "nospam" upon reply
"The Realm" <bluesky@knology.net> wrote in message
news:bubeg1pvhau109qedhjddpgqbq0ntih984@4ax.com...
> thanks
In article <bubeg1pvhau109qedhjddpgqbq0ntih984@4ax.com> bluesky@knology.net writes:
A stereo ribbon mic can make a pretty good overall drum pickup (not
overhead, but rather out front) if you have a good drummer in a good
room, but the conventional "overhad" job is usually more appropriately
handled by a pair of condenser mics. If you already have plenty of
mics, sure, give it a try, but I'd suggest renting first to see what
it does for you.
But if you have to make a choice, the Royer is smaller and lighter.
Buy the AEA and you'll probably want to invest in a larger and heavier
stand than what you have now in order to protect your investment in
the microphone.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
