Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > I have problems with my ethernet card/XP
Yesterday I bought an Acorp 10/100Mbps Fast Ethernet Adapter I installed it into a PCI slot. BUT the XP not said "a new hardware found"... I try to install the drivers manualy but there aren't any XP drivers on the disk or on the Acorp's site... So I try to install some WinME/2000/98 drivers... It doesn't work... Some driver said that it's installed correctly... but the hardware isn't appears (it's said that it's not installed into the computer)...
Thanks your help, and sorry for my english:
Andras Nemeseri (izemize@yahoo.com)
Sponsored Links
first make sure its seated properly in the PCI slot
than go into device manager and than check the dial-up adapters and than let it detect itself... if that doesnt work try swapping it into other PCI slot and see if it works.... if u need more help lemme know
THE MAIN CAUSE FOR GLOBAL WARMING- MY KICK ASS ATHLON XP ;)
Reply to ANGEL14
There are 1204 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
