Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Need Advice On First Laptop BUILD!!! What Parts should i get
Forum Laptops & Notebooks : General Laptops & Notebooks - Need Advice On First Laptop BUILD!!! What Parts should i get
This would be my first lappy build. Im very very experienced at working with desktops for literally like ever.
Figure it should be easy for me.
Heres what i want kuz i like to brag about owning a name laptop.
http://cgi.ebay.com/NEW-Alienware- [...] dZViewItem
As you can see its a barbone lappy. Excluding the listed parts it contains.
I'm looking for suggestions on what i should get its going to be a gaming/School/business Lappy, because i have 2 do all three =)
heres what im looking at.
http://www.newegg.com/Product/Prod [...] 6827152073
for the CD/DVD Reader and Burner.
http://www.newegg.com/Product/Prod [...] 6820231116
For the Memory modules.
http://www.newegg.com/Product/Prod [...] 6822149059
2 of these HD's In Raid 0
and know idea what wireless card i should get or anythign else i may need.....
Please let me know if that sounds good or let me know what i should get or even if this set up is worth it....
THANKS!
Sponsored Links
What are you going to use it for?
That laptop only supports Centrino, not the dual core models. Add to that the fact that it only has a GeForce 6800 which at this points is 2 generations behind.
If you are set on that laptop you also need:
wireless(like you said)
CPU
OS
Reply to lostandwandering
yea i know it only supports single core...=(
I'd like to use it for gaming, and school mostly
Reply to die_for_me666
If you want to game you may want something better than the 6800. For the most part, building your own laptop doesn't save you as much money as building a desktop. I would recommend that you just buy a pre-built laptop.
There are 641 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
