Does anybody in the NG need a portable 6 volt gel cell battery supply rated
at 12 AH. I built 2 units to power my Tascam DA-P1 and Grace Lunatec V3 for
portable field recording. Come to find out that one supply was more then
enough capacity for both the recorder and preamp. They both have 2 XLR
receptacles wired the same as the Echo-Charge battery supplies are with pin
3 hot + and pin 2 ground -. They both weigh about 8 lbs. If your interested,
send me an e-mail and I'll send you a picture and cost.
George
geoleyatcovad dotnet
