Tom's Hardware > Forum > Audio > Pro Audio > G4 iBook 12" with a Digi 002 rack? can anyone help?
Forum Audio : Pro Audio - G4 iBook 12" with a Digi 002 rack? can anyone help?
Archived from groups: rec.audio.pro (More info?)
Hi
I'm hoping for help before I go out and buy a laptop.
I'm using Pro Tools LE from a Digi 002 rack, and I want to try and make
it portable. Funds are limited unfortunately.
At the moment I'm thinking of buying a G4 iBook with only 12" monitor
(cos it's a couple of hundred pounds cheaper basically), and with RAM
upgraded to 1GB and a 60GB hard drive. This comes in at around £850
GBP.
This laptop is listed on the digidesign website as compatible with
protools LE systems, but what I'm wondering is whether I should take
that with a pinch of salt?
I'd like to be able to use all 8 Digi 002 inputs simulataneously to
record drum kit etc., so does anyone know if the iBook will start to
crack up at this point or would it cope ok?
I have an external firewire drive too if that will affect things.
Thanks very much
Paul
Sponsored Links
There are 1113 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
