Latest Reviews & Articles
Overclocking Core 2 Duo: Power Versus Performance
Intel's fastest Core 2 Duo, the E8600, runs at 3.33 GHz. But if you're a performance-hungry power user, we found that you can actually increase the chip's efficiency by overclocking it, thanks to 45 nm manufacturing and plenty of built-in headroom. Read more
Life At 2 GT/s: 6 GB DDR3-2000 Memory Kits Compared
Memory vendors put a lot of effort into drumming up excitement over high-end memory kits, but many of those products turn out to be vaporware. We test six DDR3-2000 kits that enthusiasts can actually buy today, and push them as far as they'll go. Read more
DDR3 Memory Scaling On AMD's Phenom II X4
DDR3 memory is available in speeds ranging from DDR3-800 to DDR3-2133. Which is the best memory choice for AMD’s Phenom II X4? We tested as many speeds as possible using aggressive and conservative timings to find the sweet spot for your next build. Read more
Intel Core i7-975 Extreme And i7-950 Reviewed
Today Intel launches two high-end processors that take the place of its i7-965 and i7-940 CPUs. More speed? Same price points? We’ll take it! But are the new chips compelling enough to warrant spending more than you would on an i7-920? Read more
All the Reviews & Articles
Tom's Hardware > Forum > Audio > Pro Audio > Small diameter condensers for guitar....?
Archived from groups: rec.audio.pro (More info?)
Small-diameter condenser mics for recording guitar...
Hello all -
I'm thinking about buying a small-diameter condenser mic to add to my [small]
collection of mics I use for non-commerical home recording.
It will be used to record dreadnought-sized guitars, also mandolin and perhaps
banjo (though I've heard that a large-diameter condenser works best for
banjo), in a simple home environment. I use a Mac g4, a Presonus Firebox (has
nice solid-state preamps, is not a tube-type pre), and Cubase.
I don't want an overly-bright mic, but rather seek detail, and warmth in the midrange.
The mics I'm considering:
Audio Technica Pro-37r
Audio Technica ATM33a
Audio Technica AE5100
Audio Technica AT3031
I've got another AT mic (AT2020) that seems to be a very good performer for
the money.
Any comments regarding one or more of the above?
Any others in the $100-250 price range worth considering?
Thanks,
- John
Sponsored Links
Also consider:
oktava mk012
MLX 603e
The later is brighter but I have found on a Martin HD28 it is the best.
On a taylor 614 I think the oktava is better in most cases. Both or
these are on the cheap.
Reply to Anonymous
"John Albert" <j.albert@snet.net> wrote in message
news:431349AE.35F31C1B@snet.net
I inherited two of these from the previous sound guy at
church. They are well-known for their coldness and
roughness.
Reply to Anonymous
On 8/29/05 1:45 PM, in article 431349AE.35F31C1B@snet.net, "John Albert"
> the money.
AKG C535
SHURE Sm81
Reply to Anonymous
the midrange.
AT's are known for their crisp top-end, and not for a warm midrange. Rode
NT5 is the mic you describe, but they're $400 for a pair and aren't sold
individually.
Reply to Anonymous
"Zigakly" <no@no.no> wrote in message
news:df0a62$grg$1@domitilla.aioe.org...
> the midrange.
> individually.
For some dreadnoughts (notably Taylors) the Oktava MC012 is nice. In my
experience they get along less well with Martins; for those, usually, I like
a large diaphragm.
On the other hand, contrary to what you've heard, my preference is almost
universally for a small diaphragm on banjos. Usually the MC012 is nice
there, especially with the hypercardioid capsule.
Peace,
Paul
Reply to Anonymous
"Danny Taddei" <palmtreedreamer@aol.com> wrote in message
news:1125340366.693742.5050@g44g2000cwa.googlegroups.com
> Also consider:
> oktava mk012
> MLX 603e
I have a number of MXL 603s that do yoeman duty. It's a
fairly warm sensitive mic that I've used (with a pop filter
and attenuation) for vocals, for instruments like guitars,
and in the form of both spaced and coincident pairs, for
area pickup. It's a fat cardioid with less than average
proximity effect.
Reply to Anonymous
On Mon, 29 Aug 2005 17:45:18 GMT, John Albert <j.albert@snet.net>
>Hello all -
>the money.
>Thanks,
>- John
Of the ones you mention, I'm only familiar with the AE5100 which is a
pretty decent mic. I think Ty Ford has commented on these from time
to time in this NG. I have one but it tends to get loaned out a lot
and I use others. Worth auditioning.
For the amount you mention, with a little patience you should be able
to pick up a used AT-4051a or AT-4053a on e-bay. Loads better than
any of those you mention. Do a google search in this NG for those
mics and you will see quite a few laudatory comments. Much more even
response than some of the less expensive SD mics. These can play with
the Neumann KM140s and Josephson mics. I think they are less bright
than either the KM140 or the C42 if that is what you are looking for.
I havepairs of both AT mics as well as the Josephson C42s (which are
very nice, but outside your pricing) and am quite happy with them.
You can check out a review of better SDs here to give you more basis
for comparison:
http://emusician.com/mics/emusic_smokin_condensers/
Another possibility if you can find one is a Beyer MCE 93 (or 94).
Nice, clean, useful SD that never caught on here in the states as far
as I can tell. They show up on E-Bay from time to time. I think they
listed at @$400 each, but I have a couple pairs that I picked up for
@$75-125 each on E-Bay. No one here knows what they are so no one
bids on them. The MCE94 will take a battery for phantom power.
There is a review here:
http://www.soundonsound.com/sos/ju [...] yermce.htm
Other decent alternatives include the previously mentioned AKG c535eb,
which is also a decent vocal mic should you want to use it for that
purpose as well. The Groove Tubes GT-44 or AM-40 (same mic, different
distributors) is great acoustic guitar condenser mic. It is a tube
mic and is a bit warmer than the other mics mentioned so far. Nice
detail with this mic. I have a couple of these also. It is really a
mid sized diaphragm mic (3/4" I believe). Banjo Mart was blowing them
out for $200 earlier this year. They were once about $800 list. They
show up on E-bay fairly frequently and typically go for @$250 or so.
A real sleeper IMNHO.
Have fun!
Reply to Anonymous
In article <431349AE.35F31C1B@snet.net>,
> Hello all -
> perhaps
> midrange.
> the money.
> Thanks,
> - John
It ain't small, and it ain't a condenser, but it is very close to your
price range, and I love mine for the uses you list: EV re-20.
David Correia
www.Celebrationsound.com
Reply to Anonymous
- 0 +
Well I have a small collection, so here's my experience.
2 AKG 451EB
2 Marshall 603s
2 AT 4041
2 Josephson C42
1 Octava MC012
I tend to use the MC012 on Hyper at the neck and a AT 4050 behind the
bridge at the body for a big stereo sound.
Otherwise I like the MC012 in omni at the neck or even close to the
sound hole for a mono sound.
The Marshall and Josephson work great as well, the MXL (Marshall) is
very similar in sound to the Octava in cardioids.
The AKG 451 or AT 4041 get used if I want the guitar to have an
aggressive forward sound.
Reply to Paul
There are 819 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
