Tom's Hardware > Forum > Audio > Pro Audio > Phantom power
Phantom power
Forum Audio : Pro Audio - Phantom power
Archived from groups: rec.audio.pro (More info?)
Hello,
I have bought a Sennheiser evolution 906 for recording. I was
wandering if anyone has had experience with one of these, do I need to
run it with 'phantom power'?.
I have just taken the first step on to the recording ladder (bought a
behringer preamp as well) so I'm looking forward to starting.
Thanks for any help
Sponsored Links
guitar.is.g...@gmail.com wrote:
> Hello,
No. It's a dynamic mic and no power is required.
Reply to Anonymous
Thanks, thats a great help. So much to learn, but I will get there.
Reply to Anonymous
guitar.is.good@gmail.com wrote:
> Hello,
> Thanks for any help
You will need phantom power for condenser microphones. Yours is a
dynamic and doesn't require any special power. If you are a beginner in
recording, I suggest gettting an M-Audio FastTrack USB (if you have USB
ports on your computer) interface. You can plug in a dynamic microphone
in the back, plug the FastTrack to a USB port on your computer and
start recording on pretty much any recording software. It's a great
little unit for beginners who aren't looking to record anything
professional or spend serious money. It also has line in for
instruments such as guitars, RCA outs so you can listen on your stereo,
headphone jack and volume controls. If you upgrade your microphone to a
condenser, you'll need a preamp or a mixer with phantom power(Mackie
and Behringer make good quality mixers which have phantom powered
preamps and EQ built in for a great price).
Reply to Anonymous
Thanks very much for your help as well. I actually bought an
M-audiophile 2496 a couple years ago, but struggeled to get good
sounds from it (source was direct from the back of an effects unit) but
now I have bought the mic and the behringer tube ultragain (I like the
more vintagy things, I really dont like most digital effects), which
I'm hoping will interface nicely with my 2496. They sent me the mic and
preamp but the cable I ordered was out of stock :(, so just waiting for
the XLR cable then I shall be raring to go. I'm flying solo, so I
though I would buy a goodish preamp instead of what would be a cheapish
mixer at the same price. Giving serious consideration maybe buying a
second microphone sometime, I hear you can nicely E.Q. an amp buy
multiple placements of mic's (sound from my amp / all cabs is really
directional). Or maybe a pair of monitor speakers, hmm.. so much to buy
and so little money! I prefer though to save up for a while tho and buy
better things gradually over time.
Thanks.
Reply to Anonymous
On Tue, 30 Aug 2005 16:07:52 -0700, guitar.is.good wrote:
> I have bought
> the mic and the behringer tube ultragain (I like the more vintagy things,
I don't want to burst your bubble, but the Ultragain (and really, just
about any mic pre with a toob in it under $1000) is about as vintage as
a bottle of last week's Thunderbird. It's essentially an IC based amp with
an underpowered toob stage intended to add distortion, which the marketing
department hopes to convince people with little or no experience is the
same thing as "warmth", (whatever that means). If you can bypass the toob
stage altogether, the main solid state part of the preamp is probably
about equal to what Behringer puts in their compact mixers (not really all
that bad for the price. You might even find the toob stage to be a cool
effect for guitars, or as a bass direct box, but it's primarily an effects
box, not a real tube preamp.
> I'm flying solo, so I though I would buy a goodish
> preamp instead of what would be a cheapish mixer at the same price.
> Giving serious consideration maybe buying a second microphone sometime,
> I hear you can nicely E.Q. an amp buy multiple placements of mic's
> (sound from my amp / all cabs is really directional). Or maybe a pair of
> monitor speakers, hmm.. so much to buy and so little money!
Whoa, cowboy! You might need to buy some asbestos pocket liners first.
Unless you're only recording solo electric guitar, you might do well to
get a mic like a Shure SM57 or an EV 635a, which are both inexpensive &
decent on a variety of sources. The 906 is made specifically for guitar
amps, plus it's pretty pricey & I'm not convinced it's that much better
than the much less expensive 609. At this point, you need experience more
than you need gear. Look for versatile & cost effective stuff & after you
work with it a while, you'll be in a better position to decide what your
real needs are.
> I prefer
> though to save up for a while tho and buy better things gradually over
> time.
Now your talking. Enjoy!
Reply to Anonymous
Yeah , you'll get more by " doing " & listening as you go
i.e; does it work without phantom ? then you don't need it
[ for that mic ] wherever money is involved , there is marketing
so question & listen to all decisions and don't overspend until
you can make a solid decision with imformed opinion [ your own ]
regards Greg
"Agent 86" <maxwellsmart@control.gov> wrote in message
news:pan.2005.08.31.02.21.56.208344@control.gov...
> > I have bought
things,
> real needs are.
> > I prefer
> > time.
Reply to Anonymous
Yeah I did realise this but I thought the warmth dial / tubes add a
little more without spending big money.
Haha, yeah - problem is the internet makes it so easy without going in
the ole pockets! I'm a student so cant actually afford much more. I
thought about the shure SM57 but the e906 was only ~£30 pound more,
and since it was designed specifically for guitar amps and it is much
newer I took a leap of faith. Plus I have a soft spot for german
engineering (I'm from the UK). I'm guitar through and through,
although I may sometime record a keyboard through an amp but it is
unlikely. The one thing that worried my about the shure was it picks
up a wider angle of sound doesnt it, i.e. the e906 is focused forward
on the amp and not a general surrounding - I dont have a home studio :(
- yet!
> > I prefer
> > time.
Thanks, and I will!
Reply to Anonymous
Thanks, yeah like learning by doing but I was afraid of blowing up the
mic! Yeah, I think I have a pretty alright starters setup now (far
better than a pc mic or a direct jobby), so going to stop and learn!
Reply to Anonymous
There are 886 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 paesan won the Freshman badge
  • 01:00 -pcaddict- won the Freshman badge
  • 01:00 impreza won the Freshman badge
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
