Yes No
Ads
Tom's Hardware > Forum > Home Audio > Pro Audio > audio compression like Zip?
Forum Home Audio : Pro Audio audio compression like Zip?
Archived from groups: rec.audio.pro (More info?)
Hallo!
Is there an algorithmus/programm like Zip to compress several
Audiofiles and put them into one file? Audio has a lot of redundance,
so a lossless(!) compression of audio, especially raw material of
single tracks, should be possible.
Faktor 5 until 10 depending on level (often you don't need 24bit) and
programm (e.g. quiet parts beetween single bassdrum hits).
I do not mean mp3 or other compression algorithm with actual data
reduction.
Greetings Thomas
Reply to Anonymous
in article 1125929677.533814.84700@z14g2000cwz.googlegroups.com, Thomas
Thiele at jana.luetz@gmx.de wrote on 9/5/05 9:14 AM:
> Hallo!
> reduction.
> Greetings Thomas
Check out Win RAR
http://www.rarlab.com/index.htm
Tom Jancauskas
Imedia
Reply to Anonymous
"Thomas Thiele" <jana.luetz@gmx.de> wrote in message
news:1125929677.533814.84700@z14g2000cwz.googlegroups.com
> Hallo!
> several Audiofiles and put them into one file? Audio has
> a lot of redundance, so a lossless(!) compression of
> audio, especially raw material of single tracks, should
> be possible.
> need 24bit) and programm (e.g. quiet parts beetween
Sure lots of them:
http://www.firstpr.com.au/audiocomp/lossless/
http://www.lossless-audio.com/comparison.htm
Reply to Anonymous
> Is there an algorithm/program like Zip to compress
> several audiofiles and put them into one file?
It's spelled "audiophiles" and I don't think they'd like that...
Oh, wait. Sorry. You meant "audio files".
Yes, there is such a program. It's called Zip.
Zip works with any tpe of file. A compression program specifically designed
for musical redundancies might produce greater compression, but Zip will
work.
Reply to Anonymous
I'd like to try to compress some audiophiles!!! Nice idea! hehehe
What program would you suggest on Mac?
"William Sommerwerck" <gizzledgeezer@comcast.net> ha scritto nel messaggio
news:ovudnZF_Psq7woHeRVn-gQ@comcast.com...
designed
> work.
Reply to Anonymous
>but Zip will work.
No, it doesn't!
The compression is not high enough.
It takes much more time to compress the audio files as to burn some
additional DVDs.
Reply to Anonymous
Arny Krueger:
>Sure lots of them:
Thanks.
Reply to Anonymous
"Thomas Thiele" wrote ...
> >but Zip will work.
> No, it doesn't!
> to burn some additional DVDs.
Which is why there are things like FLAC, etc.
Reply to Anonymous
>> but Zip will work.
> No, it doesn't!
> additional DVDs.
But it does work. It just doesn't work the way you want.
Reply to Anonymous
For lossless audio compression use Flac, Monkey's Audio, etc.
On most material, the compression factor will be closer to 2
than to 10.
André Majorel <URL:http://www.teaser.fr/~amajorel/>
(Counterfeit: dupohezow@uptake.com mepad@fleawort.com)
"La presse doit diffuser des idées saines." -- Serge Dassault,
propriétaire de la Socpresse.
Reply to Anonymous
There's some info on "Lossless Real Time Coding" on the Merging site
(the guys who make Pyramix). www.merging.com - look for LRC
Al
Reply to Anonymous
"William Sommerwerck" <gizzledgeezer@comcast.net> wrote in message
> designed
> work.
Then the is (was?) WaveZip . Optimised for audio type data.
geoff
Reply to Anonymous
William Sommerwerck:
Same with Behringer stuff and Alesis digital EQ...
Reply to Anonymous
Tue, 6 Sep 2005 20:10:25 +1200, geoff@nospam-paf.co.nz suggested:
: "William Sommerwerck" <gizzledgeezer@comcast.net> wrote in message
: news:ovudnZF_Psq7woHeRVn-gQ@comcast.com...
:>> Is there an algorithm/program like Zip to compress
:>> several audiofiles and put them into one file?
:> It's spelled "audiophiles" and I don't think they'd like that...
:> Oh, wait. Sorry. You meant "audio files".
:> Yes, there is such a program. It's called Zip.
:> Zip works with any tpe of file. A compression program specifically
:> designed
:> for musical redundancies might produce greater compression, but Zip will
:> work.
: Then the is (was?) WaveZip . Optimised for audio type data.
FLAC is good for the compression part, but it only compresses single
files, it doesn't create archives. I suppose you could squash all of your
files with FLAC and then Zip them in 'fast' mode. Two-part process,
though.
agreenbu @ nyx . net andrew michael greenburg
Reply to Anonymous
> :> designed
> :> work.
> though.
Rar in multimedia mode gives pretty good compression on wav files, and
will create archives. It's also got some neat recovery features.
My preferred choice for multiple files is to use flac then create a
tarball. There's no compression with tarballs so you don't have to wait
ages or risk actually making the files bigger. (Compressing compressed
data can make bigger files than you started with!)
Reply to Anonymous
In article <1125954365.217017.134120@g47g2000cwa.googlegroups.com>,
> Al
whatever happened to Zap? that thing that emagic developed.
Reply to Anonymous
There are 2121 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Should I turn my speakers off to avoid damage?
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
Best offers
Top experts
