Tom's Hardware > Forum > Audio > Pro Audio > Adobe Audition and voice and audio, how to? Help??
Forum Audio : Pro Audio - Adobe Audition and voice and audio, how to? Help??
Archived from groups: rec.audio.pro (More info?)
Hello, hoping someone can help me.
I am using Adobe Audtion. I want to create an audio track using the
multi track view.
I have imported a .wav file and have inserted it into track2 and have
moved it to where I want it to start.
On track 1 I have pressed the red R to arm it to record...and then i
record using a microphone. Now I want to be able to do something like
this.
I want to talk into the mcrophone saying for example. Now take a
listen to this...and then I want track 2, my .wav file to play.
The .wav file does play but I do not hear it at all when I export the
audio as an mp3. so I dont think it is getting recorded into the whole
track. How do I fix this?
Also as soon as the .wav file is done or even about 2 seconds before I
want to be able to start talking into the mic and have my voice fade
into it.
So basically I want the audio tracks that are loaded into the other
tracks to be heard in the final product how do I do this?
thanks
Sponsored Links
<paul814@excite.com> wrote in message
news:1126462336.729004.8690@z14g2000cwz.googlegroups.com
> track using the multi track view.
> track2 and have moved it to where I want it to start.
> record...and then i record using a microphone. Now I
> want to be able to do something like this.
> Now take a listen to this...and then I want track 2, my
> .wav file to play.
> I export the audio as an mp3.
First you have to do a mixdown. There are two ways to do
this. One is File, save mixdown as, and the other is Edit,
Mixdown to...
Reply to Anonymous
Do you have Audition 1.5? In the Help system, look at the
Tutorials. There's one that walks you through exactly what you want
to do.
Reply to Anonymous
There are 1276 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
