Tom's Hardware > Forum > Storage > DVD/CD Writers > CDR drive door stuck
Forum Storage : DVD/CD Writers - CDR drive door stuck
I manually pushed my Plextor Plexwriter 48/24/48A door to close it yesterday. Now it won't open when I hit the button on the drive. I tried to push a pin into the little hole that would normally cause the drive door to open but nothing happens. Is there some other way that I can open my door? The light on it goes on when I pushed the button and when I pushed a pin into the little hole.
Thank you.
Sponsored Links
Try going into My Computer and opening it through the CDROM Icon, right click.
If that doesn't work, get a thin blade screwdriver, and pry outward with a slight amount of assisting pressure, on the tray itself, and push the open button at the same time, sometimes that works.
<b><font color=purple>Listing your system specs, will greatly aid us, in being able to help you solve your problem.</font color=purple></b>
Reply to 4ryan6
Thank you much. I did just like you said. With the added pressure from the blade, it opened up. :) I really appreciate your responding to my post. I am not such a knowledgeable person about computer things and this has helped me to get my system going agian.
Reply to Keleneki
Your Welcome, I had a friend with the exact same problem, don't know why it happened, but once it finally was pried open, its worked good ever since.
Reply to 4ryan6
There are 1192 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
