Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Need Help!!!!!! Shut down
Forum Windows XP : Windows XP General Discussion - Need Help!!!!!! Shut down
My computer does not shut down automatically after selecting shut down
in the windows xp pro rather it shows a message that it is safe to
turn off ur comp . So i ve to manually press the power button after
this message.Although in Windows ME i don't encounter this problem.
My pc's spec.
P3 933eb
384 sd ram
Soltec / TRigem comp. Ventura I815 ep mainboard
Pheonix bios rev 1.10
atx mid tower casing 250 watt
ASus V7700 PRO (gf2 mx400)
40 gb seagate HD
52x cd rom
32x cdrw
Sponsored Links
This might help:
<A HREF="http://www.aumha.org/a/shtdwnxpz.htm" target="_new">WINDOWS XP SHUTDOWN & RESTART TROUBLESHOOTING</A>
Toejam31
<font color=red>First Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=17935" target="_new"><font color=green>Toejam31's Devastating Dalek Destroyer</font color=green></A>
<font color=red>Second Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=15942" target="_new"><font color=green>Toey's Dynamite DDR Duron</font color=green></A>
__________________________________________________________
<font color=purple>"Some push the envelope. Some just lick it. And some can't find the flap."</font color=purple>
Reply to Toejam31
sounds like acpi isnt enabled in bios, or the board isnt fully acpi compliant - seen this a few times, onyl way round that I've found is to enable it if not enabled, or flash the bios if the current one isnt acpi compliant, either way, never avoided a reinstall :(
If they squeeze olives to get olive oil, how do they get baby oil?
Reply to CALV
CALV, this is a multiple post - I've already been working with this guy in the mobo forum.
Poster: If you want to post in multiple forums, please indicate that in your posts. Thank you.
<i>It's always the one thing you never suspected.</i>
Reply to jlanka
There are 1316 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
