Tom's Hardware > Forum > Audio > Pro Audio > Fun project: help me put together audio workstations
Forum Audio : Pro Audio - Fun project: help me put together audio workstations
Archived from groups: rec.audio.pro (More info?)
Dear helpful and intelligent readers,
I work for Michigan State University as the audio digitisation
specialist for the computational humanities department. I'm also an
Electrical Engineering student. My department is moving to a bigger,
better building, and we have been given more grant money to expand and
take on more projects. I have been given the assignment of putting
together our new audio room. It will consist of multiple workstations,
each of which can be used to digitise from analog sources, edit, burn
cds, encode to streaming media, upload to internet.
Students will be using these workstations as part of classes
(linguistics, speech sciences, audiology, and sociology students), so
they should be well suited to that (that is, fairly easy to use after
an introductory lesson).
I have already done a few weeks of research on this, but I would gladly
accept opinions.
First, I was to find the best way for students to do field recording.
For that, I have found:
-M-Audio Microtrack 24/96 - meets our 24-bit 96kHz standards set by the
library of congress, accepts compactflash, and looks user friendly and
sturdy enough for non-audio-nerd students. Out of all the flash
recorders I looked at (the Marantz line, Edirol R1), this was both the
least expensive and the closest to our requirements.
-Sennheiser MKE 2 lav mics for recording interviews, also to be used
for the video documentaries and interviews which we also do here.
-Shure ULX wireless lav mic system - I was against the wireless mics
but the professors really wanted them "so that elderly people don't
trip over the wires". whatever.
-some PZM's... Is there a hugely noticable difference between the 30D
or 6D and the cheapy $70 one? These will largely be used as backup
mics, in case a lav fails, and also to pick up the interviewers'
questions, ambient sounds, etc.
-For both our video and audio interviews, Rode NTG-2's
Now for preamps...
After looking at nearly every preamp on the market, I think our best
bet is the Grace Design 101. The preamp needs to be small and
portable, accurate, low coloration, low self noise, and under $2k. The
101 seems to have all of these attributes, with 2 channels just over a
grand. The preamps are to be taken with the student to interviews, in
a pack with the flash recorder and mics, or by our video team to
interviews.
Others that I looked at: Langevin DVC (a bit too expensive), Sytek
MPX4aii, FMR RNP.
Mixers.
I am having trouble with this one. In our current audio workstation we
have a Behringer Eurorack 2004A 16-channel. I was told that on the
mini-stations only 8-12 channels are necessary. But I have
reservations about every 8-10 channel analog mixer I look at. I'm
really just not as knowledgable/comfortable with mixers as other parts
of the chain.
Right now I'm leaning to the Behringer Eurorack MXB1002 10-channel,
just because of its similarities to the 2004A.
The mixer will just need to accept balanced line inputs from the tape
decks (for ex, tascam br-20 into ch 1&2, tascam 122 into ch 3&4, etc),
send to compressor and ADC, and to output the audio from computer to
powered monitors.
Vocal processor.
We need a 2 channel compressor/limiter. We're currently using a
Behringer multicom Pro, which I dont especially like or dislike, I'm
kind of meh about it. I've heard good things about the FMR RNC, but
I'm not sure if that would really suit our purposes, which is just to
keep the source below 0dB before the ADC stage.
A/D converters
We currently use lucid 2496 ADCs, but these only have S/PDIF outputs.
As I found out in a different thread in this forum, firewire would be a
better bet to get stuff into the computer. I have not seen anything
that has both kinds, and I have not seen anything similar to the lucids
but with firewire. We have a motu 896 but that would certainly be
overkill for the mini stations, wouldn't it?
In addition each station will have a cassette deck and cd duplicator
(thinking microboards QD-123), and a set of monitors and headphones.
These stations will not be sonically separated from each other which is
why the headphones are necessary, but we need also some decent but
inexpensive small monitors.
For monitors I'm looking at Edirol MA-20D, Event Tuned Reference 6, and
Roland Ds-7. As the material will be solely speech, the only important
thing with the monitors is accuracy, and bass response is not pertinent
as we roll off everything below about 300 anyway.
For headphones we'll probably get some more sennheiser eh2270 which is
what we currently have.
I apologize for the ultra-long post. My object is to get some ideas
and opinions from others, who if you're like me, think doing this is
really fun. So, opine away.
Thank you,
Kayte Revitte
Sponsored Links
Kayte, I'm in the E.L. area, @ Marshall Music. Just wanted to let you
know that we carry many of the lines you've mentioned and I'd love to
put a package together for you. I can offer you some good solutions
and/or alternatives, and a package discount as well. Give me a call @
337-9700 ext. 400 M/W/Fr/Sat. Or email:
christopherubin@hotmail.com
Chris Diener
Reply to Anonymous
> Chris Diener
No thanks... haha, I should have guessed a response like this.
Reply to Anonymous
> > Chris Diener
Heh, good luck getting timely service when Marshall's becomes your
authorised warranty service provider.
-John O
Reply to Anonymous
Good call
A good standard
How are students going to learn not to trip the elderly when they go to work
using wired lav's? (and they will)
The 6D is a little smaller which doesn't impact the sound much, but the
built-in cable isn't as robust as the 30D's full-size XLR connector, and the
185 is too chinsy. For field use I'd go with the 30D for sure.
I like almost every Rode mic I've tried, but haven't tried this one.
> Now for preamps...
> interviews.
> MPX4aii, FMR RNP.
I think the FMR RNP is as far as you need go, I'd even call it overkill for
ENG. It's an outstanding value.
> Mixers.
> of the chain.
> powered monitors.
The MXB1002 is a lower grade of gear from the rest of what you're looking
at, but it is well-suited to the task with its multiple stereo inputs and
tiny footprint, and I can't think of anything similar but better...
> Vocal processor.
The RNC is not a limiter, so it doesn't offer the fool-proofing you seek.
The DBX 1066 is fairly standard, the DBX 166XL is rather cheap like the
Behringer Multicom. Frankly I think the compression should be applied in
the computer, so you can see the whole waveform and anticipate high levels,
rather than "oops - one more time from the top".
> A/D converters
I think a standalone ADC is overkill. A $250 M-Audio Firewire Solo gets you
in and out of the computer at 24/96, and the converters are more than
adequate.
You should consider just packing the computers with 4 burners each (extra
ATA controller card would be required), which can burn the same content to
four CD-R's simultaneously with Nero. The whole computer would cost less
than the duplicator, and other work can be done while they're burning.
I imagine most brand-name small monitors will suit your needs.
Those are aimed at home users, Sony MDR-7506's are pretty standard in the
pro field, and cheaper, no doubt they'll serve your needs.
Reply to Anonymous
"Kayte" <k.revitte@gmail.com> wrote in message
news:1127230966.591133.179370@g43g2000cwa.googlegroups.com...
Well, I'll comment anyway ... :-)
> Mixers.
> powered monitors.
Is there a specific reason for this mixer (eg battery operation)? If not,
I'd suggest you consider one with balanced outputs, to help avoid hum
problems.
> Vocal processor.
When would you use this? Are you sure that in the hands of inexperienced
users, it won't cause more sound problems than it solves? And with the
24-bit recording you've speciified, I'd have thought there was no need to
use compression to ensure level remains below 0dB. I suggest you get an
opinion from an experienced recording engineer who has supported a student
environment.
(You can always do compression in software, after recording.)
> A/D converters
However, if people are plugging the Firerire in and out, there's a
possibility of causing problems. Some Firewire equipment has instructions
to power things off when plugging in. You *know* people aren't going to do
that every time! I have experience of only one Firewire device (an external
hard disk) which my son uses at University - and he has twice lost data when
connecting the Firewire interface.
You won't have that particular problem; but I suggest you ask for
experiences with people who use Firewire in a student environment - some
devices have a four-pin connection, some have a six-pin (incoluding power).
It may be that the problems only occur with one type of connector.
Don't forget you'll need USB2 for the M-Audio file transfers.
I'd suggest you should also include card readers, so you can include
photographs with the audio files.
Tim
Reply to Anonymous
> > Mixers.
> > powered monitors.
> problems.
The MXB1002 has balanced outputs, not that it would fix a hum problem, and
isn't really necessary for runs under ~10'.
Reply to Anonymous
Um (OP), you mention going with 24 bit 96k... You also mention rolling
off everything below 300 hz. This seems contradictory to me. There is
a whole lot of information (even in the humnan voice) betwween 300 Hz
and say 60Hz.
Re: Mixers - you may want to check out the Soundcraft M4 or M8 or the
Allen & Heath MixWizard 3 line.
Re: Compression - I agree with the person who said you may not need
dynamics proccessing if you're in the 24 bit world. ..As long as the
users know how to correctly set levels.
You may want to look into the Apogee Mini Pre something or other. It
should have a decent pre, good conversion (spdif) and might even have
the soft-limit feature which would give some room for error with hot
levels. It is also very portable.
Dan Fox
Reply to Anonymous
and say 60Hz.
Dan Fox
Reply to Anonymous
Tim Martin wrote:
> > Vocal processor.
> environment.
I'm sorry, I should have explained this better. There are several
functions that these stations will be used for. The students will just
USB their interviews in from the microtracks, but myself and other
audio technicians also occasionally digitise library collections. This
is what the compressor/limiter and ADC section is for. The students
will only be using the stations after I give them an introductory
lesson and tell them not to touch the racks. There will probably be
big signs.
> > A/D converters
Yes i know this from the video station! Big signs, again. Maybe if we
tell the students that if they touch the racks they will get 60,000 V
or something...
Yes, thank you.
Reply to Anonymous
> Good call
> A good standard
> > Now for preamps...
> > interviews.
> > MPX4aii, FMR RNP.
> > Mixers.
> > of the chain.
> > powered monitors.
> > Vocal processor.
> > A/D converters
> adequate.
Thank you very much. I am sending warm fuzzies your way. Allow 5-10
business days for delivery. :)
Reply to Anonymous
> and say 60Hz.
I often disagree with our best practices and policies (96/24 I think is
way unneccessary, 44.1/16 would be fine and everything would go much
faster and storage would be much cheaper).
I would only point a finger at the library of congress who has set
these standards for us. That's what they tell me anyway.
But I should have mentioned, we always make 3 versions of everything:
archival is 24/96 and NOTHING is changed, nothing is eq'd, compressed,
nothing, just straight in from the tape. Optimised copy is at 16/44.1
and this is where we roll off bass, get rid of a/c's cars and planes if
we can, and make it more listenable. The third is the internet
distribution copies which are realmedia files for streaming.
Here's our standards, if you're interested.
http://www.aodl.org/audio.php
> Dan Fox
Thank you I am adding these to my "look at" list. :)
Reply to Anonymous
Hasn't really hit the market yet, but initial reports look good.
Is this really just for interviews? If so, I'd suggest a pair of lavs
(Sennheiser is fine, but you might also look at Countryman) and one good
omni interview mic (E-V RE50, AKG D230, etc.) The others you list are
probably going to create more problems than they solve in an interview
environment.
> Now for preamps...
> interviews.
> MPX4aii, FMR RNP.
The preamps in the MicroTrack should be more than adequate for this
task, and it provides phantom power. Adding an external preamp
dramatically increases your cost and increases the probability that an
inexperienced field recordist will botch things up.
> Vocal processor.
Why not record uncompressed, and muck with the dynamics later in software?
> A/D converters
What is the application for the ADC, just transferring the analog tapes?
How many active channels at a time do you need?
Accuracy is indeed paramount, and without good monitors (and a decent
room for them to work in) you will be unable to judge the effects of
your changes in recording technique. Take some of that microphone
budget and spend it on better monitors. Maybe Genelec 8030A's or the
Tannoy Active Reveals?
Reply to Anonymous
> field recording. For that, I have found:
> standards set by the library of congress, accepts
> compactflash, and looks user friendly and sturdy enough
> was both the least expensive and the closest to our
> requirements.
> interviews, also to be used for the video documentaries
> wireless mics but the
> don't trip over the wires". whatever.
This kinda surprises me, because you start out with a
portable recorder, and then you essentially kick its
portability in the teeth by tacking on a line-operated,
somewhat bulky wireless mic receiver.
Why not just hook the mics up to the recorder directly?
Reply to Anonymous
> environment.
Could you elaborate? What problems?
Well... I agree with you. The professor I showed the microtrack info
to said "I understand the key here is preamps. We need external
preamps." He didn't really let me say another word after that, he just
added external preamps to my list...It stinks, but that's what they
want, and what they want they shall get. Perhaps later, after I've
gathered all the info, but before they make any purchases, they will
ask me my opinion. I'm not sure if they will.
> > Vocal processor.
Yes, that's the plan. LIKE i said before, the c/l is for analog
sources before they're sent into the computer. As above, there are 2
processes going on: student field recordings, and digitisation of
library tapes. The students will just send their recordings in via
USB. (Boy am i getting tired of typing this again... ;)
> > A/D converters
See above, 2 channels.
Thank you.
Reply to Anonymous
> > requirements.
Why not indeed. I disagree with the wireless setup, I think it will
complicate things, introduce noise, and be much more likely to fail.
If you have more info to help me demonstrate this point I would most
appreciate it.
Thanks.
Reply to Anonymous
news:1127332477.113860.175740@g14g2000cwa.googlegroups.com
>>> this was both the least expensive and the closest to our
>>> requirements.
> think it will complicate things, introduce noise, and be
> much more likely to fail. If you have more info to help
> me demonstrate this point I would most appreciate it.
The most likely part of any wireless mic setup to fail would
be the battery.
I've had a ULX for about two years and its a wonderful
thing. But its more complex and trouble-prone than a short
mic cable.
Reply to Anonymous
>> environment.
Handling noise, extended LF response, and durability to start with.
Improper setup is likely.
It might be nice to have a good stereo pair for recording music or
special ambiance conditions, but for that I'd look to something like the
Josephson C42 (under $1000 for a matched pair, very durable, and quite
transparent.)
If you can, ask him why (given the ambient noise level and application)
external preamps?
If he really insists on top-notch preamps, why not drop the MicroTrack
and get a Sound Devices 722? Excellent preamps and a state of the art
recorder in one easy to use package.
<http://sounddevices.com/products/722.htm>
>>> Vocal processor.
Am I reading this correctly? You want to compress the analog tape
before you digitize it?
>>> A/D converters
How about a Lynx L22? <http://lynxstudio.com/lynxl22.html> You're going
to have to spend $1500 or more on an outboard converter to get better
sound quality, and it reduces the clutter in your work areas.
Reply to Anonymous
> appreciate it.
The MicroTrack is not much bigger than a wireless transmitter and will
fit in the pocket of the interviewee. I have several teachers doing
this with Edirol R-1s and they have had excellent results.
If you absolutely have to have a wireless, and you can't spend the
$2000-$3000 a good one costs, you ought to look seriously at the
Sennheiser Evolution G2 series.
Reply to Anonymous
news:1127332345.897962.12390@g44g2000cwa.googlegroups.com
>> a pair of lavs (Sennheiser is fine, but you might also
>> look at Countryman) and one good omni interview mic (E-V
>> RE50, AKG D230, etc.) The others you list are probably
>> interview environment.
>> adequate for this
>> preamp dramatically increases your cost and increases
>> the probability that an inexperienced field recordist
> microtrack info to said "I understand the key here is
> preamps. We need external preamps." He didn't really let
> me say another word after that, he just added external
> after I've gathered all the info, but before they make
> any purchases, they will ask me my opinion. I'm not sure
> if they will.
I'm beginning to suspect that the grautitous mic preamps are
for some prof's DAW, and the gratuitous wireless mics are
for the lecture halls in your department. ;-)
Reply to Anonymous
news:1127332477.113860.175740@g14g2000cwa.googlegroups.com...
> appreciate it.
I don't know what information you're recording, but it seems to me that some
of your subjects might be concerned about electronic eavesdropping if you
use wireless mikes.
Wired mikes may make them feel more secure.
Tim
Reply to Anonymous
> transparent.)
I'll look at those. We'll never be recording music, but if there are
more than 3 people being interviewed at one time it would probably be
better to do stereo micing.
> external preamps?
I printed out that information, but I'm going to guess that they'll say
that is too expensive for students to use. Thanks very much for the
microtrack article emailed-- that is very good to know. Perhaps I
should try to talk them more toward a Marantz unit.
> >>> Vocal processor.
Hmm.. I'm not sure what's wrong with this?
We need to limit to below 0dB before we digitize or it will clip.
Right now there is a behringer compressor/limiter in the signal path
before the adc's. If it wasn't there we would have to ride the gain
during capture and that would be really sloppy and bad.
Reply to Anonymous
> >> adequate for this
> > if they will.
Could be. But I doubt it. They're just like kids, they want the
"cool" stuff whether or not it's what they need. ;)
Reply to Anonymous
> >> adequate for this
> > if they will.
"cool" stuff whether or it's what they need or not. ;)
Reply to Anonymous
one more try:
Whether it's what they need or not.
sorry.
Reply to Anonymous
> appreciate it.
I seem to remember some reference to the Library of Congress earlier on
in this thread, that the LofC guidance was what was driving this
further and further into nonsense. You're doing oral history. The best
thing your collectors can do is be aware of the acoustic environment
and control it to the extent feasable if it's bad enough to affect the
reoording. The best mic preamp in the world won't improve a recording
made with a TV blasting in the next room or the neighbor running his
lawnmower.
I've done some work with the LC Folklife Center and in their "Field
School" they emphasize reliability and common sense over technology.
Their standard rig is a Marantz portable cassette recorder and rugged
dynamic mics.
Reply to Anonymous
> appreciate it.
lawnmower.
dynamic mics.
Reply to Anonymous
This whole thread is maddening. Someone please tell me why all of this
gear is necessary for doing field interviews?
Get a Marantz recorder with a RE50 and start recording. Get one that
records digitally and you don't have to worry about conversion later.
Heck, can't you even get one that burns to a CD? I know they have a
few different models, just choose the one that is the outcome you're
after. Whatever the recording medium, just dump that into the computer
and do all your conversions and processing there.
Don't worry about the compression or limiting. Set your levels
correctly and go.
Just to recap what's been said. You want a portable recording rig, so
you want a recorder, external mic pre, wireless mic, mic transmitter,
backup PZM mic, compressor/limiter along with the cables and media
associated with these. Oh...then back at the studio....a mixer,
dedicated ADC, monitors,etc, etc, etc....
Not very portable anymore.
later,
m
Reply to Anonymous
> correctly and go.
> later,
> m
I've gotten the general impression of "buy it just in case we need it"
around here. For example we have a digi001 sitting on the shelf that
has never been used. Also, I am just assembling this info. On Monday
I will be presenting it to the professors who gave me the assignment of
what they wanted, and that's my opportunity to explain to them why they
shouldn't get what they asked for, and what they should ask for
instead. I asked you's guys because I knew you'd have opinions on all
this stuff (and you've been very helpful).
Thanks, everyone.
Reply to Anonymous
So, call Harris-Allied and ask them for a six-pack of EV 635A mikes.
I think you get six for $500 still. Sooner or later you'll need them.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
>> transparent.)
Depends on the arrangement of the interviewees and the room they are in.
Four lavs into a mixer is not uncommon, but you might want to consider
a hypercardioid on a boom or even a plant mic on the table in the middle.
>> external preamps?
It's $2600 as I recall. By the time you buy the Grace and the
MicroTrack and the external battery pack and the cables and the charger,
you're going to be close to that. You could also look at the Edirol
R-4, which has four channels with preamps and could handle larger
groups. $1500 or less as I recall.
> Perhaps I should try to talk them more toward a Marantz unit.
For basic interviews, even a PMD660 will be quite sufficient. If there
are occasional events which require exceptional recording quality, buy
one really good setup and use it for those.
>>>>> We need a 2 channel compressor/limiter ... which is just to
>>> the c/l is for analog sources before they're sent into the computer.
>>> ... digitisation of library tapes.
It's certainly not what any of us would do for an archival transfer.
Just set the levels correctly and leave them alone. There's over 90 dB
of dynamic range on almost any interface these days (116 dB with the
Lynx L22!) and the best you're ever going to see off tape is a mere
fraction of that. If you have problems with level control, they can be
addressed easily in software, and you get the chance to go back and do
them over as many times as needed -- much faster than realtime. Less
wear on the tape.
BTW, are you doing regular alignments and cleanings on your tape machines?
Reply to Anonymous
Agreed, because the storage medium has far more dynamic range than does
the cassette source, compression here is not sensible. We have an open
and empty fifty gallon barrel and a pitcher of water. Do we need a
funnel to get the water into the barrel?
Damn, so simple, but that way one doesn't get to buy anything. <g>
ha
Reply to Anonymous
Thanks, I didn't know that about the dynamic range.
I'm a student! I didn't know anything about audio archival before
working here, but I am trying to find out! Thanks for helping. All of
this information will make its way up the academic ladder, and
hopefully we will have a more sensical audio setup.
Reply to Anonymous
There are 1230 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
