Tom's Hardware > Forum > Audio > Pro Audio > Recording System advice
Forum Audio : Pro Audio - Recording System advice
Archived from groups: rec.audio.pro (More info?)
I'm trying to get started with a new music/recording project and
figuring out what I should purchase. I've done music for years, mostly
guitar and a fair amount of studio recording, and have used and fixed
computers quite a bit, but still don't own one myself. I can replace
most everything in a PC, but I still get confused with alot of terms
and numbers (bus speed, d-dram, sdram, socket types, etc)
What I'm doing will involve taking old records, mostly children's 45's
and other odd sound affects and such, many of them from old 78 records,
record entire songs into the computer in stereo, and then either
manipulate it with FX (I have a processor that I would maybe like to
use in an FX loop if possible), speed changes, splicing, sampling from
bits of other records, overlapping other tracks from records, turing it
all backwards etc, along with possibly recording other instruments over
top (guitar, drum machine, bass, xylophone and other things that will
need a MIC input)
I will then want to put these tracks onto a web site, burn them to
Audio CDs, and maybe send off files to make a real manufactured CD
from. I will not be using any of this for any live performance.
So I wanted to see what others out there would recommend I get as far
as a system (I'll be going with a PC for various pre-determined
reasons), software (someone said Adobe makes something I might want),
and hardware (I'm guessing I'll need a card with 2 RCA inputs, 2 XLR
mic inputs, and 2 quarter inch inputs). My budget is probably around
$1000 total (I have a monitor already but thats it). I don't imagine
I'll need more than 16 tracks, but of course the more the better as
long as it's affordable.
Sponsored Links
<gregf@kcls.org> wrote in message
news:1127260836.925889.195000@g14g2000cwa.googlegroups.com
> project and figuring out what I should purchase. I've
> done music for years, mostly guitar and a fair amount of
> studio recording, and have used and fixed computers quite
> a bit, but still don't own one myself. I can replace most
> terms and numbers (bus speed, d-dram, sdram, socket
> types, etc)
These days its hard to buy a new computer that can't be
tuned to be a good computer for doing audio, as long as you
aren't really stretching the limits like trying to record 96
tracks at a time.
> children's 45's and other odd sound affects and such,
> many of them from old 78 records, record entire songs
> into the computer in stereo, and then either manipulate
> sampling from bits of other records, overlapping other
> tracks from records, turing it all backwards etc, along
> with possibly recording other instruments over top
> that will need a MIC input)
Software that will do all these jobs without add-ons: Adobe
Audition.
> burn them to Audio CDs, and maybe send off files to make
> a real manufactured CD from. I will not be using any of
> I get as far as a system (I'll be going with a PC for
> various pre-determined reasons), software (someone said
> Adobe makes something I might want), and hardware (I'm
> guessing I'll need a card with 2 RCA inputs, 2 XLR mic
As far as audio production computer interfaces go, all you
can count on is the two quarter inch inputs. However, its
simple and effective to add a small mixer to provide the
other inputs and a head phone jack for monitoring those
inputs. One good inexpensive mixer for this task is the
Behringer MXB 1002.
> around $1000 total (I have a monitor already but thats
> it). I don't imagine I'll need more than 16 tracks, but
> of course the more the better as long as it's affordable.
You can start out with two tracks and add more as you need
them.
Reply to Anonymous
The first thing you're going to need is a *lawyer* to handle all the issues
that come from reproducing published recordings and publishing recordings of
copyrighted works.
Peace,
Paul
Reply to Anonymous
In article <iIudnU6obdFMWq3eRVn-oQ@comcast.com>, arnyk@hotpop.com says...
>Behringer MXB 1002.
My Roland VM3100pro + R-BUS card is an audio production computer interface that
has two XLR pre-amps going straight to ADCs. It also has a Hi-Z 1/4" input for
guitars, eliminating the need for a DI box. These days a lot of computer
interfaces are being built into mixers, the ones that connect with firewire
being the most versatile, but also the most unreliable. Still, why bother
getting a seperate interface and mixer? VM-3100pro, which is a fully
functional 8bus digital mixer on its own, with R-BUS runs about $400 on ebay,
and it's a lot of bang for the buck (it originally retailed for around $1200 5
years ago, and was routinely discounted as competitors released similar
products, up until it stopped being manufactured a couple years later), the
only limitation being the 44.1khz maximum sampling rate. It
also has two internal DSP effects channels with zillions of editable presets
for every kind of effect, amp simulation, etc. Has two digital ins and outs.
It even comes with a version of Logic tuned to it, which I don't use, but it is
pretty much all someone starting out would need to immediately get the
opportunity to produce professional recordings. As I mentioned in another
post, I sold my CardDeluxe to get this, and it's been one of the best decisions
I've made. I'd have had to buy 3 more CardDeluxes's just to get the same
amount of analog inputs and outputs. It's weird that Roland designs a product
then discontinues it a couple years later when releasing a new product to take
it's place while a company like DAL designs a new soundcard every 10 years.
CardDeluxe is already at least 5 years old, so I don't think it's a very good
deal, considering it has only dropped in price by $100 since its release.
>them.
Yeah, with the CardDeluxe you can do that, very expensively. Or you can do
what I just described that I do, very inexpensively!
Reply to Anonymous
In article <5J7Ye.64186$qY1.23539@bgtnsc04-news.ops.worldnet.att.net>,
pstamlerhell@pobox.com says...
>copyrighted works.
No he doesn't, until a lawyer contacts him complaining about it, which would
only happen if his recording was considerably profitable.
Reply to Anonymous
In article <C0eYe.299606$on1.74345@clgrps13>, chevdo@chevdont.com says...
>>them.
By the way, 16 'tracks' (analog inputs/outputs) with the CardDeluxe would cost
$3200, and you'd need some weird expensive motherboard with 8 PCI slots, but if
you chain two R-BUS cards and Vm-3100pros 16 tracks would cost
$800. I suppose you could cut down your cost on the CardDeluxes by throwing
Flying Cows on the digital bus, then you'd only need 4 PCI slots, but who
knows if all that would stay in sync.
Reply to Anonymous
"Chevdo" <chevdo@chevdont.com> wrote in message
news:C0eYe.299606$on1.74345@clgrps13
>> you can count on is the two quarter inch inputs.
>> However, its simple and effective to add a small mixer
>> to provide the other inputs and a head phone jack for
>> monitoring those inputs. One good inexpensive mixer for
>> this task is the Behringer MXB 1002.
> computer interface that has two XLR pre-amps going
> lot of computer interfaces are being built into mixers,
> the ones that connect with firewire being the most
> bother getting a seperate interface and mixer?
Here's a proposed bill of materials:
(1) Berhinger MXB 1002 - $99
(2) Behringer DI box - $30
(3) M-Audio 1010LT (10 24/96 channels, 8 analog) $229
Reply to Anonymous
- 0 +
Most of these will be from works that are now public domain. Ok, I did
say most and not all. But I will dare anyone who owns the recordings to
even recognize the use of their own material in this case, that is if
anyone ever even hears about this project in the first place.
> >copyrighted works.
Reply to GregF
- 0 +
I was assuming that the tracks would have to do with the software not
the hardware. I don't mean 16 tracks of input or output, I mean 16
seperated tracks of recording in the software. Would this require so
many PCI slots?
> >>them.
Reply to GregF
- 0 +
How about for speakers?
Reply to GregF
There are 1200 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
