Tom's Hardware > Forum > Audio > Pro Audio > Digital audio connections help?
Forum Audio : Pro Audio - Digital audio connections help?
Archived from groups: rec.audio.pro (More info?)
Hey-
Was wondering if anyone knew anything here about digital audio
connections on audio systems? My system has both optical (fiber optic)
as well as coaxil. I want to connect my DVD player up digitally to the
system. Which digital connection is better, optical or coaxil? I
thought I heard somewhere that coaxil is a 'slower' connection and
optical gets the signal thru faster?
Can anyone confirm this?
Thanks.
P.S. Any difference is sound quality between the two as well?
Sponsored Links
1) It's spelled "coaxial".
2) In consumer equipment, I believe they're running at the same data
rate and sending exactly the same bits. Use whichever one's available
and/or convenient.
Reply to Anonymous
Either one is fine. Both should be bit-for-bit accurate.
Use whichever you have a cable for lying around.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
"Sseadoubleyou" <Sseadoubleyou@yahoo.com> wrote in message
news:1127343952.853006.213100@o13g2000cwo.googlegroups.com
> Hey-
> audio connections on audio systems? My system has both
> digitally to the system.
Good idea, this will make things simpler and avoid possible
redundant conversions between digital and analog
>Which digital connection is better, optical or coaxial?
Either it doesn't matter, or the optical connection is
better because it helps you avoid grounding problems.
> I thought I heard somewhere that coaxil is a
> 'slower' connection and optical gets the signal thru
> faster?
You hear lots of weird stuff. For a cable as short as one
finds in a home stereo, the time delay due to the cable
itself is totally forgettable.
Reply to Anonymous
> Hey-
Neither is better since digital is an on-off " it's there or it isn't "
kind of system so an interface doesn't have any quality issues per se. Very
long cables would introduce problems though due to signal 'degradation',
the waveform would lose integrity.
> I
Very early Toslink optical diodes had only around 6 MHz bandwidth which was
'just enough' to do the job. Current ones are have greater bandwidth. This
doesn't affect the quality of the recovered audio though. I expect this is
what's been most likely used to cast doubt on optical connections. Again,
it's realy only an issue with long interconnects.
Graham
Reply to Anonymous
In article <uOadnTR2N-UNmq_eRVn-2A@comcast.com>, arnyk@hotpop.com says...
Those optical cables are far more susceptible to damage though, they're pretty
fragile.
Reply to Anonymous
"Chevdo" <chevdo@chevdont.com> wrote in message
news:g6XYe.266899$HI.265892@edtnps84
> though, they're pretty fragile.
In general you're right because toslink tends to be stiff.
However I lucked out the last time I needed a bunch of
toslink cables, and caught a close-out at Radio Shack.
Those cables were almost as limber as regular coax such as
is used for digital audio.
Reply to Anonymous
There are 1113 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
